Tricycle W. & B. wheel distances A.O.D.
rlborger(at)mac.com
PostPosted: Sat Mar 23, 2013 3:59 pm    Post subject: Tricycle W. & B. wheel distances A.O.D. Reply with quote
Jonathan,
My measurements are 70.25" for the mains and 15.25" for the nose gear.
I'll send you a copy of my W&B spreadsheet.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Mar 23, 2013, at 6:45 PM, jonathanmilbank <jdmilbank(at)yahoo.co.uk> wrote:
Because there is a short time before my inspector comes to do my weight and balance check on Tues 26th March, I'm repeating here the last request I made under a different heading:
"More help please anyone. Today I did a provisional measurement of the wheels aft of datum and tomorrow I'm going to do it again with even greater accuracy, hoping that my first effort wasn't too wildly wrong.
Please look at the measurement for your trigear aircraft and give me your figures. My nose wheel is 14.6" AOD (371mm) and the mains are 69.75" AOD (1772mm).
With any luck, your data will be close to mine. Interestingly though is that when my left door sill was level, the joggle where engine lower cowl meets fuselage isn't perfectly vertical. It's tilted a degree or two "nose down" on both sides."
The weather in Scotland is very cold and snowy for March and I'm trying to save my inspector from suffering too long in a freezing hangar. Ideally I'd like to have all the spadework done so that he only needs to read the weights on his three scales, then go to the clubhouse for coffee while completing the paperwork. He isn't so young any more and shouldn't be asked to endure the cold any longer than really necessary.
Your help in this matter will be gratefully received. Many thanks.
JonathanMilbank
PostPosted: Sat Mar 23, 2013 4:23 pm    Post subject: Re: Tricycle W. & B. wheel distances A.O.D. Reply with quote
Thanks for such a quick response, Bob (sorry I got your name wrong; it was late when I replied). I look forward to receiving that data from you.
If anyone else can supply with their figures by Monday evening UK time, that would also be really helpful to get an idea of the average distances.
It's interesting that my nose wheel and main wheel figures differ from yours Rick by about half and inch i.e. the approximate width of the joggle.
I'm going to check again tomorrow anyway, because today I did a somewhat "rough and ready" trial. I dangled my plumb bob from the rear corner of the joggle where the lower cowling rear edge ends.
I wonder whether anyone, like Europa in Yorkshire, has ever collated these measurements for general reference.
Last edited by JonathanMilbank on Sun Mar 24, 2013 12:05 am; edited 1 time in total
rlborger(at)mac.com
PostPosted: Sat Mar 23, 2013 4:41 pm    Post subject: Tricycle W. & B. wheel distances A.O.D. Reply with quote
Jonathan,
My measurements are from the aft edge of the joggle. I can see where there could be 1/2" or more difference between tri-gear installations. Very small differences in gear angles can easily produce that at the axle. The important thing is that both main gear should have the same distance measurement.
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
On Mar 23, 2013, at 7:23 PM, jonathanmilbank <jdmilbank(at)yahoo.co.uk> wrote:
Thanks for such a quick response, Rick. I look forward to receiving that data from you.
AirEupora
PostPosted: Sun Mar 24, 2013 7:06 am    Post subject: Re: Tricycle W. & B. wheel distances A.O.D. Reply with quote
I'll add my W&B form
N120EJ W&B rev 2.xls
 Filename:  N120EJ W&B rev 2.xls
 Filesize:  30 KB
 Downloaded:  287 Time(s)
JonathanMilbank
PostPosted: Mon Mar 25, 2013 11:24 am    Post subject: Re: Tricycle W. & B. wheel distances A.O.D. Reply with quote
Many thanks for your replies, including those by email. I got four, one each from Bob, Svein, David and "Air Eupora". For general interest the average distances including my own were Nosewheel 14.7" and Mains 69.9". So my figures of 14.75" and 69.75" should be good enough for my inspector tomorrow, I hope.
