Firedog(at)visi.com Guest
Posted: Sun Mar 17, 2013 2:46 pm Post subject: GPI bladder fuel tanks |
Yaksters...
Kelley Monroe and I just installed a set of GPI bladder fuel tanks in my CJ. We are now at the fuel level calibration stage. My interpretation of the 'dialing in" instructions suggest that the pilot will only be able to tell how much fuel is in each tank(s) when their respective levels are below 63 litres...and that the gauge will not show or display the full 113 litre or 30 gallon available. How have the rest of you (~50 kits sold to date) addressed this problem? Send the fuel gauge out to be renumbered? Ignore the lack of real time fuel consumption data and stay cool until the needle starts to move off the "6"? Please give me some guidance.
All the best,
Robert
N6343U
MIC based...Minnesota...home of the cold and untanned!
Dr. Robert A. Schroeder
Schroeder Fire Inc.
612.922.2349
wlannon(at)shaw.ca Guest
Posted: Sun Mar 17, 2013 6:07 pm Post subject: GPI bladder fuel tanks |
From your numbers the bladder holds 36 litres more than the standard tank. The fuel level sending unit is a float type and senses the vertical position of the fuel surface. The fuel guage shows a maximum of 60 litres in the standard tank (probably because that is the maximum travel of the float arm in that particular sending unit) and with it installed in the larger tank it will also show 60 litres when the fuel surface is at the same height. The actual fuel quantity in the bladder will be something more than 60 litres. Whatever that number is it will represent the maximum guage reading for that particular system.
It would be necessary to calibrate the system by adding fuel in 5 (or 10?) litre increments and noting the guage reading for each increment. With that information a calibration card could be produced showing the actual fuel quantity for each guage reading. That information could also be used to fabricate a new dial plate for the guage.
In any case I doubt that the sending unit range is adequate to read the full fuel quantity.
Walt
PS: I note your spelling is in proper accordance with the King’s English!!!!!!
Sent: Sunday, March 17, 2013 3:44 PM
Subject: GPI bladder fuel tanks
Yaksters...
All the best,
Robert
N6343U
Schroeder Fire Inc.
612.922.2349
href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
jan.mevis(at)informavia.b Guest
Posted: Sun Mar 17, 2013 11:17 pm Post subject: GPI bladder fuel tanks |
We installed Dennis' fuel bladders in our Yak 52. It is great, having an
additional 50 extra liters.
But for the fuel senders: the bladders are deeper, so the first 8
centimeters (more or less, I don't remember exactly) are not measured.
When the indicators are in the red, there's still some 40 liters on board.
This also means that there's no simple linear and accurate modification, so
we think about installing a fuel flow meter.
Then the fuel gauges merely serve as a quick check.
Jan
PS: the installation of these fuel bladders has been discussed with the
Yakovlev Design Bureau, and they did not see any problem because nothing
changed on the balance.
The only limitation is that we must not do any aerobatics with more than 120
liters of fuel.
But it is not an "officially "accepted modification by YDB.
As far as I know, they will never officially accept a foreign modification.
Reply-To: "yak-list(at)matronics.com" <yak-list(at)matronics.com>
Date: Monday 18 March 2013 03:04
Subject: Re: GPI bladder fuel tanks
| Quote: | From your numbers the bladder holds 36 litres more than the standard tank.
particular system.
fuel quantity.
Walt
PS: I note your spelling is in proper accordance with the Kingąs
English!!!!!!
From: Dr. Robert Schroeder <mailto:Firedog(at)visi.com>
To: yak-list(at)matronics.com
Yaksters...
tjyak50
Posted: Mon Mar 18, 2013 5:57 am Post subject: Re: GPI bladder fuel tanks |
The indicating system is not a simple resitance value to the indicator?
If it was you could use parallel or series resistors to make the needle show full / empty then reface the indicator.
It may be a different type or I guess this would already have bewn tried.
Posted: Mon Mar 18, 2013 6:18 am Post subject: GPI bladder fuel tanks |
The Yak fuel gauge system is quite sophisticated. It's made by the
military for the military.
I think that someone described it some time ago on this list. (Rob ?).
Jan
On 18/03/13 14:57, "tjyak50" <tomjohnson(at)cox.net> wrote:
http://forums.matronics.com/viewtopic.php?p=396463#396463
tjyak50
Posted: Mon Mar 18, 2013 6:39 am Post subject: Re: GPI bladder fuel tanks |
Jan I think we are talking only about the Nanchang fuel indicating system, which is different from the Yak fuel indicating system on account of its an indigenous design.
Posted: Mon Mar 18, 2013 6:55 am Post subject: GPI bladder fuel tanks |
The CJ bladders which were referred to in the original post use a
totally new fuel sender. Unlike the Yak 52 bladders which use the
original fuel senders. The CJ6 fuel senders do require calibration for
both full and a low fuel level determined by the owner/installer.
Therefore, the tanks will have to be filled and then drained down to the
low level desired and the potentiometers set on the fuel senders.
Fuel instruments are not intended to be precise fuel remaining
indicators, just like in automobiles with Full, 3/4, 1/2, 14, Empty
marks. These instruments show approximately how much fuel remains in
the tank. Once the new CJ fuel senders are calibrated, the pilot knows
the approximate amount of fuel remaining in the tank by 1 - reading the
fuel instrument and 2 - by the light coming on which the owner/installer
set during the calibration. Lets say 15 liters.
If one wants a more accurate reading, then I always recommend installed
a JPI FS450G fuel flow instrument (or similar instrument), calibrating
the K factor during the first 4-5 fill ups, and now one will know within
a couple of tenths of a liter how much fuel has been used and how much
fuel remains in the tanks, plus of course instant fuel flow based on the
current power setting.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 3/18/2013 9:15 AM, Jan Mevis wrote:
Jan
Posted: Mon Mar 18, 2013 7:14 am Post subject: GPI bladder fuel tanks |
Sorry, I missed the line of the topic.
Jan
Posted: Mon Mar 18, 2013 8:27 am Post subject: GPI bladder fuel tanks |
Hi Dennis;
I had assumed from Robert's post that he was considering re-calibration of
the existing CJ6 fuel senders. I was not aware that the bladders came with
a new sending unit.
Walt
Posted: Mon Mar 18, 2013 8:36 am Post subject: GPI bladder fuel tanks |
Hi Walt,
Totally understand that. Perfectly logical assumption. If I did not
know they came with new fuel senders, I would have assumed the same thing.
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
On 3/18/2013 11:23 AM, Walter Lannon wrote:
Hi Dennis;
re-calibration of the existing CJ6 fuel senders. I was not aware
that the bladders came with a new sending unit.
Walt
gill.g(at)gpimail.com Guest
Posted: Mon Mar 18, 2013 9:44 am Post subject: GPI bladder fuel tanks |
All
G&C CJ6 bladders are supplied with capitance fuel level sender probe which
provides accurate level measurement within its calibration range. It
provides a resistance value in the circuit that the fuel gauge reads. Not
all the fuel can be measured because of the dihedral wing in which the fuel
cavity is located. The original metal tanks had the same measurement
limitation in that the first 15 liters were not measured by the float level
sender. The recommended use for the senders in the bladders allows that the
additional are not measured and only the last 60 liters is measured because
that what CJ pilots are used to. It is possible to reface the gauge to
reflect more of the fuel and calibrate the sender accordingly, but as the
system designer I have not checked the linearity of the gauge in its
response to the signal from the sender. A quick look at the gauge face
suggests that the gauge is not totally linear in its response. It would be
easier to install a digital gauge/display or do as Dennis suggests, all of
which are available. Dennis' approach will account for all the fuel but not
by individual bladder.
Gill
Posted: Mon Mar 18, 2013 10:51 am Post subject: GPI bladder fuel tanks |
Now that is straight from the designer of the CJ bladders! Thanks Gill.
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
On 3/18/2013 12:41 PM, Gill Gutierrez wrote:
All
Gill
N13472(at)aol.com Guest
Posted: Mon Mar 18, 2013 11:59 am Post subject: GPI bladder fuel tanks |
I have had Gill's tanks and level senders for seven years. My recommendation is leave the gauge
alone
after modifying the wiring per the instructions and calibrating the Capacitance sender the accuracy
is outstanding
far better than any span can I have ever owned. When I pull into the gas pit 98% of the time I can
tell within +- 1 gallon
how much fuel it will take to top off. I have checked this over several hundred hours of operation.
As to calibration as you only need to set the full and empty points leave the senders out of the
tank and
get beaker jar or a tall flower vase fill with fuel and you can very quickly Cal. and verify the
sender.
Without the pain in the ass of draining and filling the tanks several times.
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV
89019
Cell 541-297-5497
N13472(at)AOL.COM
