Posted: Wed Mar 13, 2013 7:24 am Post subject: Seat adjusters |
They're not as slick as Robin's but these 2" extensions work a lot better than the stock T handle position. They're pretty easy to make. If anybody wants some let me know and we'll make a batch.
--Dave
<pre><b><font size=3D2 color="#000000" face=3D"courier new,courier">
84.29 KB |
14343 Time(s) |
dmaib@me.com
Posted: Wed Mar 13, 2013 8:18 am Post subject: Re: Seat adjusters |
I bought some just like those from Steve Dinieri at IflyRV10.com and they work fine. I originally had the ones that Greg Hale designed. They looked great and worked well, but the thin wall of the lever eventually gave out. I looked at Steve's version of the Greg Hale lever and they are really nice, but won't match the holes I drilled for the Greg Hale lever. So, I settled on the T handle extensions and am satisfied.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Posted: Wed Mar 13, 2013 8:36 am Post subject: Seat adjusters |
Yeah, I made mine but if I knew they were available I'd have just
bought his extensions as well.
Dave Saylor
831-750-0284 CL
On Wed, Mar 13, 2013 at 9:18 AM, dmaib(at)me.com <dmaib(at)me.com> wrote:
David Maib
RV-10 #40559
Transition Trainer
http://forums.matronics.com/viewtopic.php?p=396172#396172
amekler
Posted: Thu Mar 14, 2013 4:51 am Post subject: Seat adjusters |
I'd be interested in a set.
Alan
N668G
On Mar 13, 2013, at 11:23 AM, Dave Saylor <dave.saylor.aircrafters(at)gmail.com> wrote:
| Quote: | They're not as slick as Robin's but these 2" extensions work a lot better than the stock T handle position. They're pretty easy to make. If anybody wants some let me know and we'll make a batch.
<photo.JPG>
--Dave
</b></font></pre>
dhmoose
Posted: Thu Mar 14, 2013 5:48 am Post subject: Re: Seat adjusters |
I'd also be interested, Dave.
_________________ David Halmos
RV-10
Flying!
Portland, OR |
flysrv10(at)gmail.com Guest
Posted: Thu Mar 14, 2013 6:00 am Post subject: Seat adjusters |
Me too.
Rob Kermanj
On Mar 14, 2013, at 8:50 AM, Alan Mekler MD <amekler(at)metrocast.net> wrote:
Alan
N668G
> <photo.JPG>
> --Dave
> </b></font></pre>
johngoodman
Posted: Thu Mar 14, 2013 2:26 pm Post subject: Re: Seat adjusters |
Has anybody thought about a modification where you don't have to painfully remove the four bolts so the whole seat can be removed? Maybe some nutplates or something?
rene(at)felker.com Guest
Posted: Thu Mar 14, 2013 2:35 pm Post subject: Seat adjusters |
I put nutplates on the handle. Makes it a lot easier.
Rene' Felker
N423CF
801-721-6080
Posted: Thu Mar 14, 2013 6:55 pm Post subject: Seat adjusters |
Along the same lines I put helicoils in the handles but I probably wouldn't do that again. If nut plates worked for Rene then I'd try that. It's nice to have the bolt heads on the inside an no other hardware to deal with.
On Thursday, March 14, 2013, Rene Felker wrote:
[quote] --> RV10-List message posted by: "Rene Felker" <rene(at)felker.com>
Rene' Felker
N423CF
[url=tel:801-721-6080]801-721-6080[/url]
jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Fri Mar 15, 2013 3:33 am Post subject: Re: Seat adjusters |
We installed two nut plates where the rear stops are bolted in. This way by removing the two -4 bolts that hold the rear stop the seat can be removed.
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
hotwheels
Posted: Sat Mar 16, 2013 2:03 am Post subject: Re: Seat adjusters |
Photos?
Jay
| jkreidler wrote: | | We installed two nut plates where the rear stops are bolted in. This way by removing the two -4 bolts that hold the rear stop the seat can be removed. |
jkreidler
Posted: Sat Mar 16, 2013 10:33 am Post subject: Re: Seat adjusters |
Sorry, I don't have any photos and will not be able to get any in the near future. So I will offer a better description, the outside seat rails have notched tracks where the pin on the t-handle engages to hold the seat in position. On the aft end of the notched piece there is a stop that keeps the seat from sliding off the back of the rails. It is a stop that the pin from the t-handle hits if you lift up the handle and slide the seat all the way aft. The stop is held on with two AN-4 bolts, the plans call for nuts to be installed under the seat pan. Instead of using nuts we installed nut-plates. So by removing the two bolts the rear stop can be removed, then just lift up on the handle and slide the seat off the rail. Hope that helps - Jason
dmaib@me.com
Posted: Sat Mar 16, 2013 11:00 am Post subject: Re: Seat adjusters |
| jkreidler wrote: | | Sorry, I don't have any photos and will not be able to get any in the near future. So I will offer a better description, the outside seat rails have notched tracks where the pin on the t-handle engages to hold the seat in position. On the aft end of the notched piece there is a stop that keeps the seat from sliding off the back of the rails. It is a stop that the pin from the t-handle hits if you lift up the handle and slide the seat all the way aft. The stop is held on with two AN-4 bolts, the plans call for nuts to be installed under the seat pan. Instead of using nuts we installed nut-plates. So by removing the two bolts the rear stop can be removed, then just lift up on the handle and slide the seat off the rail. Hope that helps - Jason |
That sounds like a great idea. Wish I'd thought about that when I was building. I'm going to take a look next time the seat is out and see if I can perhaps retrofit.
RV-10 #40559
Dorfie
Posted: Sat Mar 23, 2013 9:21 pm Post subject: Re: Seat adjusters |
I am also interested in a set.
Johan
tfarrell839
Joined: 10 Nov 2012 Posts: 27 Location: Watsonville, CA
Posted: Sat Mar 23, 2013 9:32 pm Post subject: Seat adjusters |
We should have a bunch of sets available by the end of next week. I'll post on this thread when they are ready. Thanks,
Aircrafters
831-722-9141
On Mar 23, 2013, at 10:21 PM, "Dorfie" <jdorfling(at)msn.com> wrote:
_________________ Tim Farrell
Aircrafters
831-722-9141 |
