toaster73(at)embarqmail.c Guest
Posted: Tue Mar 12, 2013 5:04 pm Post subject: More on GoPro Mounts |
I found this scheme on Van's Air Force I think.
The mount is the standard go pro flat adhesive base but with backing still on adhesive. The adhesive pad acts as a paint protector/cushion. A hole is drilled in the mount and countersunk. I have used on the top and the bottom of the wing using a longer fuel tank screw to hold it on. At cruise and in the pattern no issues and pretty stable - sometimes I can tell the automatic stabilization is kicking in on the camera or rather not keeping up with a slight vibe.
-Chris Lucas
N919AR
| Description: |
| Filesize: |
155.84 KB |
| Viewed: |
1061 Time(s) |
| Description: |
| Filesize: |
210.35 KB |
| Viewed: |
1061 Time(s) |
| Description: |
| Filesize: |
187.42 KB |
| Viewed: |
1061 Time(s) |
