Posted: Tue Mar 12, 2013 10:56 am Post subject: GPS Shelf FWF |
Someone on the RV-10 list shared a photo of their GPS shelf mounted FWF that had 4+ GPS antenna mounted. I recall the shelf was painted black and connected the firewall with the motor mount? Can the owner share the photo again with the group? I need something similar for my 8A and cannot locate the post.
Robin
schmoboy
Posted: Tue Mar 12, 2013 11:06 am Post subject: GPS Shelf FWF |
Here's the post in the forums with a bunch of options including the one
you are referring to.
http://forums.matronics.com/viewtopic.php?p=392689#392689
-Sean #40303 (FAB)
On 3/12/13 1:55 PM, Robin Marks wrote:
Robin
Posted: Tue Mar 12, 2013 1:07 pm Post subject: GPS Shelf FWF |
Just curious ..... why not put the GPS antennas on the glareshield???
Linn
On 3/12/2013 2:55 PM, Robin Marks wrote:
Robin
Checked by AVG - www.avg.com
03/12/13 [b]
bruce1hwjohnson(at)yahoo. Guest
Posted: Tue Mar 12, 2013 1:31 pm Post subject: GPS Shelf FWF |
For me it was just assedics, they work well under the cowl and are out of sight.
Bruce 151BJ in the paint shop
Sent: Tuesday, March 12, 2013 2:05 PM
Subject: Re: GPS Shelf FWF
Linn
[quote] Someone on the RV-10 list shared a photo of their GPS shelf mounted FWF that had 4+ GPS antenna mounted. I recall the shelf was painted black and connected the firewall with the motor mount? Can the owner share the photo again with the group? I need something similar for my 8A and cannot locate the post.
Robin
03/12/13
Jim Combs
Joined: 24 Jan 2010 Posts: 141 Location: Lexington, Ky
Posted: Tue Mar 12, 2013 3:58 pm Post subject: GPS Shelf FWF |
Here is my solution.
Jim Combs
N312F - Flying 460+ Hours
On Tue, Mar 12, 2013 at 2:55 PM, Robin Marks <robin(at)painttheweb.com (robin(at)painttheweb.com)> wrote:
Robin
699.34 KB |
8076 Time(s) |
517.61 KB |
8076 Time(s) |
_________________ RV-10 -> N312F - Flying as of 12/2008 |
Posted: Tue Mar 12, 2013 7:33 pm Post subject: GPS Shelf FWF |
Lynn,
I dislike anything on the glare shield. I won't even fly (build) with a dash or pole mounted compass. RV's have such great visibility why gunk it up with random odds & ends. Over time you will add, remove antenna and I prefer to do that out of sight. Just keeping it clean!
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bruce Johnson
Sent: Tuesday, March 12, 2013 2:31 PM
From: Linn <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)>
Linn
Robin
03/12/13 |
| Quote: | | -=================== |
==============[/b][/quote] V10-List Email Forum -[/b][/quote] >[/b][/quote] :p>[/b][/quote] /o:p>[/b][/quote] tor?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b][/quote] ==============[/b][/quote] bsp; - MATRONICS WEB FORUMS -[/b][/quote] :p>[/b][/quote] tp://forums.matronics.com[/b][/quote] ==============[/b][/quote] bsp; - List Contribution Web Site -[/b][/quote] e> bsp; -Matt Dralle, List Admin.[/b][/quote] bution">http://www.matronics.com/contribution[/b][/quote] ==============[/b] [/quote]
r>
Posted: Tue Mar 12, 2013 9:17 pm Post subject: GPS Shelf FWF |
Thanks Robin. I feel as you do .... wanted to not install the front cabin top brace for the same reason. I learned from others that they use it a lot .... so in it goes.
One problem I have flying my traumahawk ..... there's nothing to use to 'aim' the airplane to keep it on track. I have two small pucks for GPS antennas .... and was thinking of mounting them on the glareshield as a 'sight'.
Again, thanks for the reply.
Linn .... still learning
On 3/12/2013 11:32 PM, Robin Marks wrote:
[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
Lynn,
Robin
Posted: Tue Mar 12, 2013 10:14 pm Post subject: GPS Shelf FWF |
Lynn,
I recall the brace conversation. I as much as just about anyone didn’t want the brace there till I flew the 10. The brace is invaluable for getting in and out, for stabilization during turbulence and for routing wires from my overhead console. I'm embarrassed to say I love the brace now.
Might I suggest you consider installing flush defrost fans and use those as your aiming device and move the small GPS pucks to the FWF? Occasionally I can see the reflection of my black computer fan grills on the windscreen. It looks kind of like a machine gun site.
Another option is to press the Heading button on the AP and not worry about the site. Over time you will be comfortable flying a plane you built with your own hands w/o the need for a site line.
Good luck with your choices.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn
Sent: Tuesday, March 12, 2013 10:17 PM
Lynn,
Robin
r>
Posted: Wed Mar 13, 2013 4:32 am Post subject: GPS Shelf FWF |
Posted: Wed Mar 13, 2013 6:56 am Post subject: GPS Shelf FWF |
32 years ago I built my Pitts S-1 ..... and it never stays on heading more than a few seconds ..
I was planning on fans ..... and promptly forgot them. Thanks for the reminder!!!!
You also reminded me about those hardpoints on the wings .........
Linn
Lynn,
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Linn
Lynn,
Robin
============== V10-List Email Forum - > :p> /o:p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============== bsp; - MATRONICS WEB FORUMS - :p> tp://forums.matronics.com ============== bsp; - List Contribution Web Site - e> bsp; -Matt Dralle, List Admin. bution">http://www.matronics.com/contribution ==============
r>
03/12/13 [b]
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27801 Location: Toledo Washington (KTDO) USA
Posted: Wed Mar 13, 2013 8:44 am Post subject: GPS Shelf FWF |
At 11:55 AM 3/12/2013 Tuesday, you wrote:
| Quote: | Someone on the RV-10 list shared a photo of their GPS shelf mounted FWF that had 4+ GPS antenna mounted. I recall the shelf was painted black and connected the firewall with the motor mount? Can the owner share the photo again with the group? I need something similar for my 8A and cannot locate the post.
Robin
Hi Robin,
Here are some pictures of how I did the GPS antenna installations on my RV-8. Works great. Blast tubes keeps them cool. No unsightly pucks on the dash!
Matt
Status: 140+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
157.24 KB |
8054 Time(s) |
161.73 KB |
8054 Time(s) |
91.12 KB |
8054 Time(s) |
221.9 KB |
8054 Time(s) |
206.17 KB |
8054 Time(s) |
167.25 KB |
8054 Time(s) |
121.71 KB |
8054 Time(s) |
270.56 KB |
8054 Time(s) |
169.39 KB |
8054 Time(s) |
141.96 KB |
8054 Time(s) |
_________________ Matt Dralle
Robin
Hi Robin,
Matt
157.24 KB |
8054 Time(s) |
161.73 KB |
8054 Time(s) |
91.12 KB |
8054 Time(s) |
221.9 KB |
8054 Time(s) |
206.17 KB |
8054 Time(s) |
167.25 KB |
8054 Time(s) |
121.71 KB |
8054 Time(s) |
270.56 KB |
8054 Time(s) |
169.39 KB |
8054 Time(s) |
141.96 KB |
8054 Time(s) |
Posted: Wed Mar 13, 2013 8:45 am Post subject: GPS Shelf FWF |
Robin
Hi Robin,
Matt
157.24 KB |
8054 Time(s) |
161.73 KB |
8054 Time(s) |
91.12 KB |
8054 Time(s) |
221.9 KB |
8054 Time(s) |
206.17 KB |
8054 Time(s) |
167.25 KB |
8054 Time(s) |
121.71 KB |
8054 Time(s) |
270.56 KB |
8054 Time(s) |
169.39 KB |
8054 Time(s) |
141.96 KB |
8054 Time(s) |
wgreenley
Joined: 09 Jan 2010 Posts: 100 Location: Dowagiac, MI
Posted: Wed Mar 13, 2013 9:51 am Post subject: GPS Shelf FWF |
Would there be any temperature concerns for the antennas being located in
the engine compartment?
Posted: Wed Mar 13, 2013 11:12 am Post subject: GPS Shelf FWF |
have 110 hours on mine and had the same set up in my RV-4 for 350 hours with no issues. Not saying it won't be a problem, but no issues for me so far. YMMV
-Mike Kraus
RV-4 sold
RV-10 flying
KitFox SS7 Radial building
On Mar 13, 2013, at 1:51 PM, "William Greenley" <wgreenley(at)gmail.com> wrote:
Dick Sipp
Posted: Wed Mar 13, 2013 4:58 pm Post subject: GPS Shelf FWF |
750 hours in RV4 470 so far in a 10 so far so good.
Dick Sipp
