mrspudandcompany(at)veriz Guest
Posted: Sun Mar 10, 2013 2:12 pm Post subject: contactor not contacting! |
I have a 1977 Cessna Cardinal, and recently it is necessary to flip the master on and off several times in order to power up the panel. It seems that the master is OK because I can hear the contactor activating and deactivating as the master is turned on and off. After several tries it will finally power up the panel. Once the contactor has activated and supplying power, I have never lost power again until physically turning the master off. I am making a wild assumption that the problem is due to a faulty contactor, perhaps corrosion or some kind of crud (technical term used extensively by electrical engineers) on the contacts. Is this a common problem? Is changing the contactor the right way to fix it? Comments, suggestions, please!!
Roger
I am using the Free version of SPAMfighter.SPAMfighter has removed 341 of my spam emails to date.Do you have a slow PC? Try a free scan! [quote][b]
JLuckey(at)pacbell.net Guest
Posted: Sun Mar 10, 2013 2:48 pm Post subject: contactor not contacting! |
May I suggest a little testing.
The next time you turn-on the master and hear it click (or clunk as you case
may be) but the panel does not "power up", take a voltmeter and see if there
is voltage on the load side of the contactor. If not, then you've got some
form of contact failure.
If you have power on the load side then your problem is elsewhere - I'd
start looking for loose connections by putting a wrench on the connections
down stream of the contactor to make sure they are tight.
Then report your findings here for more assistance based on your test
results.
_____
From: owner-aeroelectric-list-server(at)matronics.com
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of R. curtis
Sent: Sunday, March 10, 2013 14:11
Subject: contactor not contacting!
Roger
_____
Posted: Sun Mar 10, 2013 3:17 pm Post subject: contactor not contacting! |
The next time you turn-on the master and hear it click (or clunk as you case may be) but the panel does not “power up”, take a voltmeter and see if there is voltage on the load side of the contactor. If not, then you’ve got some form of contact failure. | Quote: |
There seems to be no intermittent connections because once it is on it stays on, and the starter cranks the engine just fine. I'll put a meter on it next time I'm at the airport, but highly suspect the contactor.
Roger |
If you have power on the load side then your problem is elsewhere – I’d start looking for loose connections by putting a wrench on the connections down stream of the contactor to make sure they are tight.
I am using the Free version of SPAMfighter.SPAMfighter has removed 342 of my spam emails to date.Do you have a slow PC? Try a free scan! [quote][b]
Posted: Sun Mar 10, 2013 5:13 pm Post subject: contactor not contacting! |
At 05:10 PM 3/10/2013, you wrote:
| Quote: | | I have a 1977 Cessna Cardinal, and recently it is necessary to flip the master on and off several times in order to power up the panel. It seems that the master is OK because I can hear the contactor activating and deactivating as the master is turned on and off. After several tries it will finally power up the panel. Once the contactor has activated and supplying power, I have never lost power again until physically turning the master off. I am making a wild assumption that the problem is due to a faulty contactor, perhaps corrosion or some kind of crud (technical term used extensively by electrical engineers) on the contacts. Is this a common problem? Is changing the contactor the right way to fix it? Comments, suggestions, please!! |
Based on the facts (1) you can hear it operate
whether it connects or not and (2) once connected
it stays connected is a strong indicator of a
bad contactor. I believe all the Pawnee Plant
aircraft went 28v in '78 so your airplane probably
has the legacy 12v PMB/Stancore/White-Rogers contactor.
Does it look like this?
If so, you could get a 'test' replacement from
Newark for about $25. (Cat# 35M2084 which is a
4-terminal device. You'll have to add your own
jumper between coil-hot and BAT terminal)If
that 'cures' the problem, you can go for the
holy-watered part.
If it's some other part, post a picture of
it and we can probably identify it's generic
roots.
I'd like to have your failed part to do a tear
down inspection and report to be posted her
on the List and archived on the website.
Bob . . . [quote][b]
Posted: Tue Mar 12, 2013 8:17 am Post subject: contactor not contacting! |
WHITE RODGERS70-902
<http://www.newark.com/productimages/nio/standard/4298109.jpg>
holy-watered part.
roots.
Bob,
Thanks for the reply. I have a 3 terminal continuous
duty 12V contactor that I will put in as soon as the
weather cooperates for some outdoor maintenance.
Will mail the junk contactor to you as soon as it is liberated.
Roger
_____
<http://www.spamfighter.com/len>
Posted: Tue Mar 12, 2013 9:08 am Post subject: contactor not contacting! |
| Quote: | Bob,[/b]
[/b]
Thanks for the
reply. I have a 3 terminal continuous [/b]duty 12V
contactor that I will put in as soon as the [/b]weather
cooperates for some outdoor maintenance.[/b] [/b]
Will mail the
liberated.[/b] [/b]
Great! I'll tear down, photograph, analyse and share . . .
