pic
flying-nut(at)cfl.rr.com
PostPosted: Wed Mar 06, 2013 7:53 pm    Post subject: pic Reply with quote
Gary .... I guess that's a pic from an AA-5 ..... but it would be nice to have a description for us that are -5 ignorant!!
Linn
On 3/6/2013 10:43 PM, Gary wrote:
</b></font></pre></body></html>
Checked by AVG - www.avg.com
teamgrumman(at)yahoo.com
PostPosted: Wed Mar 06, 2013 9:45 pm    Post subject: pic Reply with quote
Linn,
Sorry, but, I am afraid I don't know what pic you are talking about. I don't remember sending a pic. When was it sent? What was it?
Gary
On Mar 6, 2013, at 7:53 PM, Linn <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
[quote] Gary .... I guess that's a pic from an AA-5 ..... but it would be nice to have a description for us that are -5 ignorant!!
Linn
PostPosted: Wed Mar 06, 2013 9:49 pm    Post subject: pic Reply with quote
Oh, I see now. That was to go to me. Ooooppps.
Ok, it's the rear console cover for my Tiger. It's made of fiberglass; 4 layers of glass with 1/4 foam core on top.
Gary
Linn
BARRY CHECK 6
PostPosted: Thu Mar 07, 2013 4:33 am    Post subject: pic Reply with quote
Hi Linn:
It looks like an OooPsy cover.  It is covering the the cables that goes down the centerline of the plane to the tail.  It is so clumsby people don't step on them.  OooPsy!
But then again the floor sure looks nice - Painted Maybe?  So it could be just a paint shield so the cables and the color coding on them do not get obliterated.  It does look like the spar has a paper cover?    But, if the floor is painted and the cables are not - How come the small area between the OooPsy cover and the spar - Where the cables show - The cables are not painted?  TRICK PHOTOGRAPHY?  And why not paint the spar?  UNLESS?  The spar is painted a different color!  Gary, are you getting into Fung Shway and home decorating?
More energy flow through the centerline of the plane could equate to more forward speed.
Wink
Barry
On Wed, Mar 6, 2013 at 10:53 PM, Linn <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
Linn
PostPosted: Thu Mar 07, 2013 9:53 am    Post subject: pic Reply with quote
Speaking of Fung Shway
Sent: Thursday, March 7, 2013 4:33 AM
Subject: Re: Re: pic
Hi Linn:
Wink
Barry
Linn
 Filesize:  2.23 MB
 Viewed:  8895 Time(s)
 Filesize:  1.82 MB
BARRY CHECK 6
PostPosted: Thu Mar 07, 2013 10:20 am    Post subject: pic Reply with quote
Gary:
That sure looks gorgeous.  Will the owner appreciate it?
And have you been checked for OCD?
Smile
Barry
On Thu, Mar 7, 2013 at 12:52 PM, Gary L Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:
[quote] Speaking of Fung Shway
From: FLYaDIVE <flyadive(at)gmail.com (flyadive(at)gmail.com)>
To: teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)
Hi Linn:
Wink
Barry
Linn
PostPosted: Thu Mar 07, 2013 10:39 am    Post subject: pic Reply with quote
It's CDO. It needs to be in alphabetical order.
Sent: Thursday, March 7, 2013 10:19 AM
Gary:
Smile
Barry
Hi Linn:
Wink
Barry
Linn
n26390(at)AOL.COM
PostPosted: Thu Mar 07, 2013 1:43 pm    Post subject: pic Reply with quote
I don't know if everyone noticed but there is a modification to the canister vacuum filter installation in the first picture. It is probably one of the best things you can do for yourself or your mechanic (it's described on the AuCountry website). Now if Gary could come up with something for the garter vacuum filter I'd be a happy camper.
Roger Rucker
AA5A '78 HWO
BARRY CHECK 6
PostPosted: Thu Mar 07, 2013 2:56 pm    Post subject: pic Reply with quote
VERY GOOD - VERY GOOD, Gary - - -
You have me laughing really hard.
Barry
Abrry
On Thu, Mar 7, 2013 at 1:38 PM, Gary L Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:
[quote]It's CDO.  It needs to be in alphabetical order.
Gary:
Smile
Barry
Hi Linn:
Wink
Barry
Linn
st" target="_blank">http://www.matronics.com/Navigator?TeamGrumman-List
tp://forums.matronics.com
BARRY CHECK 6
PostPosted: Thu Mar 07, 2013 3:11 pm    Post subject: pic Reply with quote
Roger:
I can't see it... Does it have a Wingnut?  Indicating removable from the inside?
I don't know where I first heard of that - Gary if it was you, THANKS!  I did that after my first Annual 14 years ago.  GREAT IDEA!
Now - If you want the Mod for the Garter Filter... EASY.
All you have to do in put a spacer on the INSIDE between the fixture and the firewall.  I did this with a large brass nut - I just happen to have.  All it has to do is give you room to slide on and off the filter.  The only issue is you have to remove ALL the hoses so the fixture is spaced away from the firewall.  NOW - Thinking back.  You maybe able to do the spacing using a piece of heavy wall PVC (Sked 40) and making a 'C' shape just to snap over feed through part of the fixture.  About 3/8" thick.
Two other tricks to get things to fit:
1 - Remove the Sound Proofing around the fixture - It helps a little, or
2 - Flatten it down by installing a thin sheet of aluminum - It also helps a little.
I went with the EASY method.
Barry
On Thu, Mar 7, 2013 at 4:42 PM, <n26390(at)aol.com (n26390(at)aol.com)> wrote:
[quote] I don't know if everyone noticed but there is a modification to the canister vacuum filter installation in the first picture.  It is probably one of the best things you can do for yourself or your mechanic (it's described on the AuCountry website).  Now if Gary could come up with something for the garter vacuum filter I'd be a happy camper.
Roger Rucker
AA5A '78 HWO
n26390(at)AOL.COM
PostPosted: Thu Mar 07, 2013 4:42 pm    Post subject: pic Reply with quote
Yep, the wingnut is there. I had to click on the pic and zoom-in to see it. Thanks for the ideas on the other filter.
Bests,
Roger Rucker
AA5A '78 HWO
PostPosted: Fri Mar 08, 2013 10:01 am    Post subject: pic Reply with quote
When I put the firewall blanket on, I made a cutout for the Vacuum filters. Then, I glued the patch back into the hole. It helps some. Just not a lot.
Sent: Thursday, March 7, 2013 1:42 PM
Roger Rucker
AA5A '78 HWO
PostPosted: Fri Mar 08, 2013 10:02 am    Post subject: pic Reply with quote
hadn't thought of that. good idea.
Sent: Thursday, March 7, 2013 3:10 PM
Roger:
Barry
Roger Rucker
AA5A '78 HWO
grumpyparts
PostPosted: Fri Mar 08, 2013 10:31 am    Post subject: pic Reply with quote
Hi Gary
What product is that firewall blanket, it almost looks original.
Ian Matterface
From: owner-teamgrumman-list-server(at)matronics.com [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of Gary L Vogt
Sent: 08 March 2013 18:01
Roger Rucker
AA5A '78 HWO
PostPosted: Fri Mar 08, 2013 10:00 pm    Post subject: pic Reply with quote
It is the original type. I got it at WagAero.
On Mar 8, 2013, at 10:30 AM, "Ian Matterface" <i.r.m(at)btinternet.com (i.r.m(at)btinternet.com)> wrote:
[quote]v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--><\/b><\/pre><\/di"; panose-1:0 0 0 0 0 0 0 0 0 0;} (at)font-face {font-family:"Script MT Bold"; panose-1:3 4 6 2 4 6 7 8 9 4;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {margin:0cm; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman","serif";} a:link, span.MsoHyperlink {mso-style-priority:99; color:blue; text-decoration:underline;} a:visited, span.MsoHyperlinkFollowed {mso-style-priority:99; color:purple; text-decoration:underline;} pre {mso-style-priority:99; mso-style-link:"HTML Preformatted Char"; margin:0cm; margin-bottom:.0001pt; font-size:10.0pt; font-family:"Courier New";} p.MsoAcetate, li.MsoAcetate, div.MsoAcetate {mso-style-priority:99; mso-style-link:"Balloon Text Char"; margin:0cm; margin-bottom:.0001pt; font-size:8.0pt; font-family:"Tahoma","sans-serif";} span.HTMLPreformattedChar {mso-style-name:"HTML Preformatted Char"; mso-style-priority:99; mso-style-link:"HTML Preformatted"; font-family:Consolas;} span.EmailStyle19 {mso-style-type:personal-reply; font-family:"Calibri","sans-serif"; color:#1F497D;} span.BalloonTextChar {mso-style-name:"Balloon Text Char"; mso-style-priority:99; mso-style-link:"Balloon Text"; font-family:"Tahoma","sans-serif";} .MsoChpDefault {mso-style-type:export-only; font-size:10.0pt;} (at)page WordSection1 {size:612.0pt 792.0pt; margin:72.0pt 72.0pt 72.0pt 72.0pt;} div.WordSection1 {page:WordSection1;} --> <![endif]--> <![endif]-->
Hi Gary
Ian Matterface
From: owner-teamgrumman-list-server(at)matronics.com (owner-teamgrumman-list-server(at)matronics.com) [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of Gary L Vogt
From: "n26390(at)AOL.COM (n26390(at)AOL.COM)" <n26390(at)AOL.COM (n26390(at)AOL.COM)>
Roger Rucker
AA5A '78 HWO
