fireflier
Posted: Wed Mar 06, 2013 11:41 am Post subject: Back up instruments |
Hello
Looking for suggestions as to what back up ASI and Altimeter to buy as back up instruments to my dynon skyview?
I have been looking at the mingda altimeter (BG3E) and ASI (Bk15) does anyone have thoughts on these instruments?
I might have to re think the ASI as its only marked up to 160 kts and the VNE off the xs tri gear is 165kts.
I look forward to hearing your thoughts and suggestions
Many thanks for your help.
Kind regards
Donald
_________________ Fireflier |
Paul M 383
Joined: 19 Mar 2012 Posts: 102 Location: United Kingdom
Posted: Wed Mar 06, 2013 12:35 pm Post subject: Re: Back up instruments |
I have a Skyview too and bought the 2 1/4 ASI from Europa (because it comes with the white, green & yellow arcs & Vne red line already marked); and the 2 1/4 Winter 0-5,000 Alti from Transair http://www.transair.co.uk/sp+Winter-Instruments-Altimeters-Winter-Altimeter-Single-Needle-Millibar-Scale+1018
They will both fit neatly above and to the right of the 7" Skyview.
I know some recommend the 1 1/2 turn ASI to give greater resolution at low airspeeds, but the Skyview is my PFD and if that failed in flight I'd be looking out below about 60 kt.
Likewise, the Alti I bought only reads to 5,000 ft on one turn, but if I can't figure in VMC whether I'm at, say, 2,000 or 7,000 ft, then I have no business in the top left hand corner of any aircraft...
HTH
Paul M
383
Mono XS 912S
23.86 KB |
4533 Time(s) |
84.61 KB |
4533 Time(s) |
Posted: Wed Mar 06, 2013 12:42 pm Post subject: Back up instruments |
You may want to look at the MGL "smart singles" they have several single
hole units that are ASI \ ALT for example in one unit
LCD display though so they do need power unlike a standard ASI or ALT
Good luck
craig
trevpond(at)aol.com Guest
Posted: Wed Mar 06, 2013 12:55 pm Post subject: Back up instruments |
I have a Skyview backed up with Trutrak Ai, Winter Altimeter, Winter ASI, all 2 1/2" and a Precision Card compass.
Trev Pond
G-LINN
On 6 Mar 2013, at 19:41, "fireflier" <fireflier(at)btinternet.com> wrote:
Hello
Kind regards
Donald
Fireflier
http://forums.matronics.com/viewtopic.php?p=395755#395755
