skidmk
Joined: 19 Nov 2007 Posts: 171 Location: Ottawa, Ontario
Posted: Sun Feb 24, 2013 3:19 pm Post subject: oil cooler overhaul |
Looking like the oil cooler is starting to leak. Overhaul time. Any recommendations out there? Cheaper to replace? Thoughts?
Mike
CJ6A Housai equipped
_________________ Mike "Skidmk" Bourget
Ottawa, Ontario |
dougsappllc(at)gmail.com Guest
Posted: Mon Feb 25, 2013 8:23 am Post subject: oil cooler overhaul |
Mike and all,Back in the office today after a short break from the cold and snow.
Mike, I have both new and used coolers in stock.
Best,
Doug
On Sun, Feb 24, 2013 at 1:19 PM, skidmk <skidmk(at)gmail.com (skidmk(at)gmail.com)> wrote:
[quote] --> Yak-List message posted by: "skidmk" <skidmk(at)gmail.com (skidmk(at)gmail.com)>
Mike
Ottawa, Ontario
http://forums.matronics.com/viewtopic.php?p=394955#394955
rget="_blank">http://www.matronics.com/Navigator?Yak-List
le, List Admin.
Harv
Posted: Tue Feb 26, 2013 6:19 am Post subject: Re: oil cooler overhaul |
Talking of oil coolers for the CJ6....
Has anyone replicated it in modern materials or come up with an off the shelf usable alternative?
I removed mine for internal cleaning and was absolutely staggered by the weight of it..... Its brass and probably weights about 25kg!
You'd gain some good performance if a firm like 'MOCAL' would replicate it in aluminum.
Any ideas?
Rgs
Harv
mikspin
Posted: Tue Feb 26, 2013 9:07 am Post subject: Re: oil cooler overhaul |
i have a guy building up a modified cooler for a Yak 52TW. He has experience with a variety of aircraft coolers as well as items such as Mustang radiators. Contact me off list for info.
Mike Hastings
Posted: Tue Feb 26, 2013 10:02 am Post subject: oil cooler overhaul |
Is there a reason you don't feel comfortable putting his name and number
here?
Just curious... nothing bad meant by it.
Mark
rmhou(at)yahoo.com Guest
Posted: Tue Feb 26, 2013 12:33 pm Post subject: oil cooler overhaul |
"... an off the shelf usable alternative?"
I was just thinking about the same thing for my CJ recently. However, my motivation is not for weight saving. I was thinking mounting the oil cooler inside the engine cowling. The advantages seem to be a shorter run of the oil hoses, easier hose replacement and possible cabin heat using the oil cooler. What do you think?
To: yak-list(at)matronics.com
Sent: Tuesday, February 26, 2013 6:19 AM
Subject: Re: oil cooler overhaul
--> Yak-List message posted by: "Harv" <martin.harvey(at)kbr.com (martin.harvey(at)kbr.com)>
Any ideas?
Rgs
Harv
http://forums.matronics.com/view -Mat===============
Posted: Tue Feb 26, 2013 12:53 pm Post subject: oil cooler overhaul |
I have not done the numbers but I am afraid that you would have to add a ton of weight to the tail to off set moving the oil cooler to the firewall.
Doug
On Tue, Feb 26, 2013 at 12:28 PM, Robin Hou <rmhou(at)yahoo.com (rmhou(at)yahoo.com)> wrote:
[quote]"... an off the shelf usable alternative?"
From: Harv <martin.harvey(at)kbr.com (martin.harvey(at)kbr.com)>
Any ideas?
Rgs
Harv
samira.h(at)shaw.ca Guest
Posted: Tue Feb 26, 2013 4:09 pm Post subject: oil cooler overhaul |
Mike,
some time ago I have met a guy who
was not happy with the performance
of the oil cooler in his CJ.
He told me he installed a Broussard/Stearman
oil cooler instead and it works like a charm.
Can't remember his name but he might
read this list and tell us more.
cheers
Elmar
wlannon(at)shaw.ca Guest
Posted: Tue Feb 26, 2013 6:47 pm Post subject: oil cooler overhaul |
Hi Mike;
See if you can determine where it's leaking from. If from a fitting that is
likely repairable without too much trouble. If leaking from the core it will
need overhaul or replacement.
There are two overhaul facilities I know of. Ultimate Oil Cooler in
Winnipeg (in the Aero Recip. facility) and Pacific Oil Cooler in the Los
Angeles area. Been meaning to look up the contact info. at the hangar but
keep forgetting. I have used both over the years. I suspect there are more
in the far east (Toronto or Montreal) but don't know.
A core leak can be very expensive to repair so if that is the problem you
may want to get a new one from Doug.
Cheers;
Walt
skidmk
Posted: Wed Feb 27, 2013 1:58 pm Post subject: Re: oil cooler overhaul |
Thanks fella,,, we'll take it out this weekend and check it for problem. Given the cost of shipping, and then finding out it will cost a ton to repair. We'll probably just pony up and send Doug some spring cash
M
Ottawa, Ontario |
