jimbean6(at)optimum.net Guest
Posted: Mon Feb 25, 2013 1:31 pm Post subject: Parking brake check valve |
I have misplaced the drawing on the dual check valve used for a parking
brake on our RV's.
I have a hazy recollection that the lever is perpendicular to the fluid
flow when the check valves are operating.
Anyone have this information or a steer to where I could download the
drawing?
thanks
Jim Bean
RV-8 81110 MN
Ed Godfrey
Posted: Mon Feb 25, 2013 1:46 pm Post subject: Parking brake check valve |
Jim,
If you are referring to the Matco parking brake valve, you can find
the information at
http://www.matcomfg.com/PARKINGBRAKEVALVEDUAL-idv-3579-8.html
Ed Godfrey
40717
On 2/25/2013 3:29 PM, James Bean wrote:
parking brake on our RV's.
fluid flow when the check valves are operating.
drawing?
thanks
Jim Bean
RV-8 81110 MN
Posted: Mon Feb 25, 2013 1:57 pm Post subject: Parking brake check valve |
Which valve?
If I recall correctly, there are two. I have one installed on my 6A - don't remember the brand though. I'll see if I can dig out the documentation.
Ralph
Posted: Mon Feb 25, 2013 2:14 pm Post subject: Parking brake check valve |
This is not the one that I have - I'll continue looking.
Posted: Mon Feb 25, 2013 3:24 pm Post subject: Parking brake check valve |
Generally the lever blocks flow when it's perpendicular to the line, open when it's parallel. I recall that it doesn't require a full 90* motion to open the valve. It's most likely either made by Matco or Grove.
On Monday, February 25, 2013, James Bean wrote:
| Quote: | --> RV-List message posted by: James Bean <jimbean6(at)optimum.net>
I have misplaced the drawing on the dual check valve used for a parking brake on our RV's.
I have a hazy recollection that the lever is perpendicular to the fluid flow when the check valves are operating.
Anyone have this information or a steer to where I could download the drawing?
thanks
Jim Bean
RV-8 81110 MN
target="_blank">http://www.matronics.com/Navigator?RV-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
Dave Saylor
831-750-0284 CL
bicyclop(at)pacbell.net Guest
Posted: Mon Feb 25, 2013 5:56 pm Post subject: Parking brake check valve |
The Matco valve that I have, earlier version than the one on the Matco site, wants the lever at 45 degrees to the body for both open and closed positions. I verified this by blowing through it while operating the lever. This orientation makes it easier to rig the cable, too. Make sure you have positive stops at both positions. Somebody I know didn't and the fire dept wound up opening his bleeder valves to get him off the taxiway so the jets could get by when he couldn't release the brakes.
Ed Holyoke
On 2/25/2013 3:19 PM, Dave Saylor wrote: [quote]Generally the lever blocks flow when it's perpendicular to the line, open when it's parallel. I recall that it doesn't require a full 90* motion to open the valve. It's most likely either made by Matco or Grove.
thanks
Jim Bean
RV-8 81110 MN
MS -
e -
Dave Saylor
831-750-0284 CL
bobbyhester(at)twc.com Guest
Posted: Mon Feb 25, 2013 6:11 pm Post subject: Parking brake check valve |
Here is my Matco parking brake
https://picasaweb.google.com/lh/photo/QZey-IEOJoYkfSdPBSRF4tMTjNZETYmyPJy0liipFm0?feat=directlink
Sent from my Verizon iPhone
On Feb 25, 2013, at 3:29 PM, James Bean <jimbean6(at)optimum.net (jimbean6(at)optimum.net)> wrote:
[quote]--> RV-List message posted by: James Bean <jimbean6(at)optimum.net (jimbean6(at)optimum.net)>
thanks
Jim Bean
RV-8 81110===============================================
http://www.matronics.com/Navigator?RV-Li==================================================http://w====================================================
Posted: Mon Feb 25, 2013 6:15 pm Post subject: Parking brake check valve |
Here is their newer model
https://picasaweb.google.com/lh/photo/FAuf5mb-Ct5eGfu10tZjrtMTjNZETYmyPJy0liipFm0?feat=directlink
vanremog(at)aol.com Guest
Posted: Mon Feb 25, 2013 7:27 pm Post subject: Parking brake check valve |
Attached is the drawing of the Parker Cleveland Valve that I have.
-GV
 Download |
| Filename: |
60-5.pdf |
46.39 KB |
| Downloaded: |
1599 Time(s) |
Posted: Tue Feb 26, 2013 4:28 am Post subject: Parking brake check valve |
This is the one I have - thanks Gary!
Posted: Tue Feb 26, 2013 12:18 pm Post subject: Parking brake check valve |
Thanks all for the replies.
I think I have the older model, have to look in the AC. I haven't
fabricated a linkage for it, have just been using the lever.
It seems that some hard landings can move the lever and give surprise
braking.
It looks like the new one allows the lever to be moved around. The
reason for my not putting on a proper linkage
is that the lever was moving opposite to a convenient cable hook up,
I.E. would require a pull to release the brakes.
I think that the next project is to put on the new valve and a cable.
thanks again
regards Jim Bean
RV-8 N99JA 81110
Posted: Tue Feb 26, 2013 12:35 pm Post subject: Parking brake check valve |
Jim,
Here's mine.....
Hope this helps.....
Ralph
683.18 KB |
6295 Time(s) |
Posted: Tue Feb 26, 2013 4:34 pm Post subject: Parking brake check valve |
Use a locking or ratcheting cable so vibration doesn't move it. Put it
on your side of the cabin so mate doesn't think it's for heat. You can
use the outer cable as the stop on one end and set the other end to be
brakes released when the knob is full forward.
Ed Holyoke
On 2/26/2013 12:15 PM, James Bean wrote:
braking.
thanks again
regards Jim Bean
RV-8 N99JA 81110
