jonlaury
Posted: Fri Feb 22, 2013 10:38 am Post subject: Eye Beam Mini LED / RF interference |
Listers.
I posted this about a year ago, but now I'm down to the short list of squawks so this has moved to the front burner.
I have installed an EyeBeam mini LED cabin light in my composite airframe. Unfortunately I do not have a schematic of the unit, but it uses capacitance (touch) to control the on/off function and dimming.
The LED is powered by shielded, twisted pair power and ground wire cable. In the same small enclosure on the ceiling there is a 4 ohm 1.25" x 1.75" cabin speaker and it's power and ground comes from 180 deg away from the wires feeding the LED with no parallelism or overlap. The shield for the LED is grounded at the ship's single point ground bus.
The problem:
When I key the microphone, the EB turns on. If I key it again, the EB begins flashing uncontrollably. It is unresponsive to the dimming control and the on/off switch. The only way to stop the flashing is to disconnect the EB from power. The EB works as intended when connected to battery power independent of the ship's electrical system. The LED also turns on if I power up the audio panel with the speaker selected. Yesterday it turned on when my hand got near it.
Attempts at a solution:
Thinking that the the magnetic field of the speaker magnet may be causing the problem, the speaker was disconnected and the mic was keyed. The EB exhibited the same uncontrollable flashing upon keying the microphone. I installed elongated ferrite donuts on the LED cable at various locations and on the speaker wires to no effect.
I contacted the manufacturer and their solution was some huge boss hog thing that I'm sure would prevent ET from phoning home.
If co-located with the LED, it needs to be small enough to fit in about a 1/2" high x 1.25"OD cylinder
Any ideas on what's happening and/or how to fix it?
Posted: Fri Feb 22, 2013 1:15 pm Post subject: Eye Beam Mini LED / RF interference |
Without more details on how it's made, I wouldn't have
a clue. Touch-sensitive switches are not well suited
to a strong rf/noise environment. Unless the product
was subjected to at least a rudimentary investigation
of it's vulnerabilities, anything we might attempt
is just throwing darts.
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Sat Feb 23, 2013 6:02 am Post subject: Re: Eye Beam Mini LED / RF interference |
Ditto what Bob N. says. I couldn't even make my capacitive-touch desk lamp work reliably.
Also no "Clapper" switches.
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
james(at)etravel.org Guest
Posted: Sat Feb 23, 2013 6:18 am Post subject: Eye Beam Mini LED / RF interference |
| Quote: | Also no "Clapper" switches.
That made me laugh so much!
N38CW
Joined: 16 Apr 2008 Posts: 57 Location: Winston-Salem, NC
Posted: Sat Feb 23, 2013 8:29 am Post subject: Re: Eye Beam Mini LED / RF interference |
| jonlaury wrote: | ...I have installed an EyeBeam mini LED cabin light in my composite airframe... Any ideas on what's happening and/or how to fix it?
John |
Jon, Is this the product you have installed? I'm curious because I was planning on using these also. Thanks.
http://www.aveoengineering.com/index.php/product-info-eyebeam-mini
_________________ Bill Settle
RV-8 Fuselage |
jonlaury
Posted: Sun Feb 24, 2013 8:07 am Post subject: Re: Eye Beam Mini LED / RF interference |
[/quote]
http://www.aveoengineering.com/index.php/product-info-eyebeam-mini[/quote]
Bill,
Yes, the same. But I don't know what they mean when they say "no external power source required". That would be some trick!
Aside from the issue I'm having, it works really well when I don't have other devices on. Undimmed, the light is very bright and white. Mine is mounted on the ceiling (attached) of my Glasair in the center and the eyeball range of motion is excellent for reading (pilot or pass) and panel illumination.
Allow about 3/4" for clearance above the spec drawing for range of motion of the ribbon cable, hence the housing I made.
91.6 KB |
20195 Time(s) |
42.78 KB |
20195 Time(s) |
deej(at)deej.net Guest
Posted: Sun Feb 24, 2013 8:57 am Post subject: Eye Beam Mini LED / RF interference |
On Feb 24, 2013, at 11:07 AM, "jonlaury" <jonlaury(at)impulse.net> wrote:
| Quote: | But I don't know what they mean when they say "no external power source required". That would be some trick!
I think it means it doesn't have an external "box" to attach for power. You just attach the light fixture directly to the airplane power.
-Dj
Posted: Sun Feb 24, 2013 12:14 pm Post subject: Eye Beam Mini LED / RF interference |
Bill,
[/quote]
Do the offer a 'dumb' version? It's not hard
to build an airplane-friendly knob-operated
on/off/dimmer.
sam.marlow
Posted: Sun Feb 24, 2013 12:54 pm Post subject: Eye Beam Mini LED / RF interference |
Ok Bob, I have an LED cabin litght that needs a on/off/white/red/dimmer
switch, any ideas?
Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
> Bill,
on/off/dimmer.
[/quote]
N38CW
Posted: Sun Feb 24, 2013 3:55 pm Post subject: Re: Eye Beam Mini LED / RF interference |
I don't believe so Bob. They offer that one and one that is a bit larger.
RV-8 Fuselage |
Posted: Sun Feb 24, 2013 4:22 pm Post subject: Eye Beam Mini LED / RF interference |
At 02:53 PM 2/24/2013, you wrote:
<sam.marlow(at)roadrunner.com>
on/off/white/red/dimmer switch, any ideas?
Separate red and white lamps?
Uncle
Posted: Mon Feb 25, 2013 5:34 am Post subject: Eye Beam Mini LED / RF interference |
Sam,
Here's what I came up with for kneeboard lights to do what you're talking about.
William
--- On Sun, 2/24/13, Sam Marlow <sam.marlow(at)roadrunner.com> wrote:
| Quote: | From: Sam Marlow <sam.marlow(at)roadrunner.com>
Subject: Re: Re: Eye Beam Mini LED / RF interference
Date: Sunday, February 24, 2013, 3:53 PM
--> AeroElectric-List message
posted by: Sam Marlow <sam.marlow(at)roadrunner.com>
Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
also. Thanks.
>> Bill,
some trick!
> on/off/dimmer.
> Bob . . .
[/quote]
| Quote: | AeroElectric-List Email Forum -
| Quote: | - MATRONICS WEB FORUMS -
| Quote: | List Contribution Web Site -
-Matt
Dralle, List Admin.
 Download |
| Filename: |
Pilot_&_Co-Pilot_KB_Light_(02-25-13).pdf |
14.91 KB |
| Downloaded: |
705 Time(s) |
_________________ William E. Buckley |
jonlaury
Posted: Wed Feb 27, 2013 8:36 am Post subject: Re: Eye Beam Mini LED / RF interference |
Joe,
Not sure if the the little eyeball sold by VAn's (and Spruce) is incandescent, but the light output compared to the EB Mini is like comparing a match to the sun. The EB also is dimmable. The little eyeball needs to be fairly close to the target to provide meaningful light, but they are inexpensive and smaller.
Posted: Wed Feb 27, 2013 9:38 am Post subject: Eye Beam Mini LED / RF interference |
At 10:36 AM 2/27/2013, you wrote:
| Quote: | --> AeroElectric-List message posted by: "jonlaury" <jonlaury(at)impulse.net>
Joe,
Not sure if the the little eyeball sold by VAn's (and Spruce) is incandescent, but the light output compared to the EB Mini is like comparing a match to the sun. The EB also is dimmable. The little eyeball needs to be fairly close to the target to provide meaningful light, but they are inexpensive and smaller. |
Those were originally incandescent. They would no doubt
benefit from an LED upgrade. some builders have ordered
red or white LED fixtures from our website
One of these mounted on both sides of the canopy frame
were used to flood the panel on RV3/4/8 projects.
They proved to be bright enough . . . in fact needed
to be dimmed for navigation in full darkness.
Bob . . . [quote][b]
Eric M. Jones
Posted: Thu Feb 28, 2013 11:47 am Post subject: Re: Eye Beam Mini LED / RF interference |
Perihelion Design sells an extremely versatile LED light too.
See: www.PerihelionDesign.com
These are made from the Loc-Line snap together coolant line parts. Dimmers are available too.
 Download |
| Filename: |
LED_Goosenecks.pdf |
76.61 KB |
| Downloaded: |
681 Time(s) |
113 Brentwood Drive
(508) 764-2072
