trevorkebb(at)earthlink.n Guest
Posted: Wed Jun 07, 2006 7:40 pm Post subject: Fuselage Fabric Wrinkles |
Hello Folks:
I am an old time member of the Kitfox List from about 8 years ago; just returned to the US and newly signed up. I need some advice.
A few days ago, after having folded the wings on my 310-hour Model IV 1050, I noticed some subtle longitudinal (front-to-back) wrinkles on the top fuselage fabric, in the bay that starts about a foot in front of the vertical stabilizer. I have never seen them before and cannot think of any reason, or abuse to the plane, that could have caused them to appear. The wrinkles smooth out a bit when the wings are swung out for flight. It is surely not temperature related, and no one to my knowledge has ham-fistedly handled the plane in a way that would bend tubing. It is always hangared and my hangar mate's plane has been off getting its annual and some new paint for the last
2 weeks.
My initial thought was that I had a broken weld somewhere, tempered somewhat by the knowledge that I have not heard of this happening to any other Kitfox. I spent an hour yesterday visually looking over, then pulling and pushing on the individual tubes inside the fuselage that I could reach from the opening below the turtledeck and through inspection holes, and pushing against those I could not reach with a wooden stick. I found none loose. Then a Pitts owner and I spent about an hour trying to torque the fuselage weldment any way we could, by the vertical and horizontal tails, pushing down on the fuselage, by the wingtips with wings out, by the wings when folded, etc., and we could not find any combination that would increase or make any visually discernible difference in the wrinkles, nor were there any abnormal airframe sounds or clicking. These crude tests don't eliminate the possibility of a broken weld but do diminish it.
The wrinkles are to me a rather strange anomaly -suddenly there for no apparent reason.
Has anyone on the List come across anything similar? Any advice on further checks I could make?
Thanks in advance.
Robert Beck
PS Hi Ron!
Posted: Wed Jun 07, 2006 8:59 pm Post subject: Fuselage Fabric Wrinkles |
Hi Robert,
I'd immediately assume the same things you did, that
there is some flexing going on there. Usually the
fabric tension doesn't release enough under normal
flex to wrinkle. That would create a problem on our
wings and tail surfaces!
Is that the bay with the lift handle? Just a
thought...
Because that is a small width of fabric back there, a
smaller flex would show quicker, in my opinion.
Not sure if you tried this, but put a straight edge to
the tubing between welds on either side of the
wrinkles and see if they are drawn in. Then push on
these tubes 1/2 way between welds and see if the
fabric shows a change. If the fabric had been too
tight to begin with, the tubes could have curved in
and began flexing over time.
Check with another same model Fox and see how straight
they are so I don't mislead you, if they are meant to
be curved on your model. I think they are nearly
straight between bays?
Those are the only additional raw checks I can think
of.
Kurt S. S-5
--- W & R Beck <trevorkebb(at)earthlink.net> wrote:
| Quote: | Hello Folks:
2 weeks.
Thanks in advance.
Robert Beck
rliebmann(at)comcast.net Guest
Posted: Thu Jun 08, 2006 5:53 am Post subject: Fuselage Fabric Wrinkles |
Hi Robert,
Send me your new e-mail address directly. I'd like to fly to Lewis and see your Fox. I think that the wrinkle is caused by temp & or humidity. I have seen it before.
Ron
DO NOT ARCHIVE
mike Guest
Posted: Thu Jun 08, 2006 5:58 am Post subject: Re: Fuselage Fabric Wrinkles |
I had an area in the rear section behind the rudder cable exits, both sides, I didn't get excited about it and took a little hobby heat gun and run over the area until the area was smooth. Had the same type of thing up on the tank area, did the same thing.
Posted: Thu Jun 08, 2006 1:35 pm Post subject: Fuselage Fabric Wrinkles |
Kurt:
Thanks for your reply.
No, the wrinkles are in the larger bay just in front of the handle, a bit to
the right side longeron, which is quite a long, unsupported tube. The right
longeron shows a tad more bend than the left, both of them having had very
slight bends after fabric shrinkage, since the plane was built. It is
probably that right side top longeron tube. The question is, why does it
suddenly have a bend in it?
I spent another few hours the other day checking every weld I could get to
with either my hand, a push-stick, or a mirror and light, all the way from
the tailwheel to the primary cockpit structure, and could come up with no
squawks.
So today I went flying for 2 hours. No noticeable difference in trim.
It's a mystery.
Robert Beck
temco(at)telusplanet.net Guest
Posted: Thu Jun 08, 2006 2:16 pm Post subject: Fuselage Fabric Wrinkles |
Robert
This may be a bit of a stretch, but, have you looked at the two wooden
stringers along the side of the fuselage that runs from just back of the
doors to near the horizontal stabilizer. Perhaps one of these has warped or
broken causing the fabric ripple.
Just a thought
Ted
Edmonton, Ab
Subject: Re: Fuselage Fabric Wrinkles
Kurt:
squawks.
It's a mystery.
Robert Beck
asq1(at)adelphia.net Guest
Posted: Thu Jun 08, 2006 2:34 pm Post subject: Fuselage Fabric Wrinkles |
Robert,
Was it towed over rough terrain(or road)? Larry
Ceashman(at)aol.com Guest
Posted: Thu Jun 08, 2006 2:53 pm Post subject: Fuselage Fabric Wrinkles |
| Quote: | the right side longeron, which is quite a long, unsupported tube. The right
Hi Robert.
Are you sharing a hangar?
The bend is in the top longeron tube opposite side to the ground moving handle. Could someone have tried to shove the plane with the chocks in place or the tail wheel locked and did not know what he was doing?
Could something heavy have fallen on the side of the plane, any traces of surface paint damage in the area?
Have you had a real heavy tail wheel first three point landing recently?
I believe the fabric can expand if you place too much heat, but that is noticed at the exact moment of shrinking, incorrectly. And the direct sun could not effect it, even though the color is very dark because it would not reach the temperature of expansion.
You must have been flying too close to the sun!
Eric.
Posted: Thu Jun 08, 2006 7:25 pm Post subject: Fuselage Fabric Wrinkles |
Eric:
No, my hangar has been empty but for my plane for the last few weeks as my hangar-mate's Spam Can is up at Kenosha getting an annual. And paint on the repaired lower cowl that was damaged when he hit a goose. I'll bet that woke him up!
Since I always have my wings folded in the hangar it is difficult to conceive of any way that the longeron could have been bent in my absense, as the folded wings pretty much cover that area of the fuselage, and anything falling, or any ham-handed handling of the plane, would have shown up as damage to the wings.
I did have an off-airport landing in a freshly planted cornfield 2 weeks back (a week before the wrinkles arrived) but that landing was kiss-my-hand soft -are we down yet?- compared to any landing I have ever done on pavement.
Flying too close to the sun, Icarus, and no wax to melt but fabric to soften. That must be it.
Robert
| Quote: | Hi Robert.
Eric.
Posted: Thu Jun 08, 2006 9:47 pm Post subject: Fuselage Fabric Wrinkles |
OK Robert,
Maybe one of our engineers can address this better.
I'm getting old....
I think you should make sure that the tubes are not
bent more than half their diameter out of being
straight between welds. That is my rule of thumb
without the math behind it. Straight is much better.
1/2 is the limit and not even nice.
Called "long column bending", a tube really gets weak
in compression if it is not straight. An upper tube
is usually in tension in flight, but compression on
the ground. That means it bent more than normal on
the ground because tension in flight would straighten
it. Only ground contact, inverted flight, or force
bends a top tube. (I think. Maybe a side load on the
tail might do it too.)
Folding your wings contributes to this because it
moves more weight to the tailwheel.
If your fabric tension is too high and a tube is bent
to begin with, it takes less compression to bend it
more.
Very hard to bend a straight tube, but it weakens
rapidly if bent past a certain point. If I remember,
1/2 the diameter is about it before it bends real
easily. Maybe less.
I added 2 cross braces to my Fox in the bay just
behind the baggage area because I didn't like the
bending there after covering. I kept mine under 1/8th
inch off straight. Just a precaution for me. You
might look at doing the same. The braces have to be
mounted so that they will not come lose and poke the
fabric when stressed, so take care for that.
Any engineer comments would be appreciated.
Kurt S.
| Quote: | Kurt:
was built. It is
question is, why does it suddenly have a bend in it?
could come up with no squawks.
difference in trim.
It's a mystery.
Robert Beck
Posted: Fri Jun 09, 2006 5:36 pm Post subject: Fuselage Fabric Wrinkles |
Larry, Ted, and Kurt:
No, it hasn't been towed, and the wood stringers are fine all around.
Kurt, I appreciate your insights on tubing. I suppose at some point I will
cut a hole in the bottom fuselage fabric (Horrors! It's virgin!) and put in
a couple lightweight crossbraces in to take the bit of sag out of those top
longerons.
Thanks again, folks.
Robert
Robert,
Just a thought
Ted
Edmonton, Ab
janderson412(at)hotmail.c Guest
Posted: Fri Jun 09, 2006 11:37 pm Post subject: Fuselage Fabric Wrinkles |
For future builders I built in a hatch cover behind the turtle deck so I could get into the rear fuse to keep a good eye. To large a are not to be able to check over the life of the fabric....John A.
Date: Fri, 9 Jun 2006 19:47:13 -0500
--> Kitfox-List message posted by: "W & R Beck" <trevorkebb(at)earthlink.net>
Kurt, I appreciate your insights on tubing. I suppose at some point I will cut a hole in the bottom fuselage fabric (Horrors! It's virgin!) and put in a couple lightweight crossbraces in to take the bit of sag out of those top longerons.
Robert
[quote]--> Kitfox-List message posted by: "Larry Huntley"
Posted: Fri Jun 09, 2006 11:45 pm Post subject: Fuselage Fabric Wrinkles |
For future builders I built in a hatch cover behind the turtle deck so I could get into the rear fuse to keep a good eye. To large an area not to be able to check over the life of the fabric....John A.
Robert
| Quote: | --> Kitfox-List message posted by: "Larry Huntley"
Read the latest Hollywood gossip at XtraMSN Entertainment
