rvdave
Posted: Sat Feb 16, 2013 12:27 pm Post subject: Mounting PC680 on firewall |
Looking to mount second battery on firewall with aluminum tray from Hawker. Thinking about letting bottom of tray/battery rest on engine mount with baffle material on mount. Anyone foresee a problem or better location?
109.91 KB |
4951 Time(s) |
104.28 KB |
4951 Time(s) |
_________________ Dave Ford
Cadillac, MI |
Tim Olson
Posted: Sat Feb 16, 2013 1:07 pm Post subject: Mounting PC680 on firewall |
I'd never do it.
On Feb 16, 2013, at 2:27 PM, "rvdave" <davidbf(at)centurytel.net> wrote:
Posted: Sat Feb 16, 2013 1:26 pm Post subject: Mounting PC680 on firewall |
I modified the stock battery mount to hold two PC625 batteries (batteries
are mounted at 90 degrees to the axis of the plane (back to back with a 1/4"
spacer), and both are held down by the one stock battery clamp). The PC625
has a little more CCA power than the PC680, a pound lighter and has a better
form factor for this application.
The batteries normally operate in parallel, but are split in the event of a
component failure (e.g. alternator). When split half the panel runs on the
one, the other half on the other, or both sides can run on one or the other
battery in the event a battery (or more likely master solenoid) itself
failed.
Carl
Posted: Sat Feb 16, 2013 2:39 pm Post subject: Mounting PC680 on firewall |
I'm with Tim. Keep it of the engine mount at a minimum.
Here is my dual battery set up. I have a 3rd (smaller) battery that exclusively supports my D100 in case of a total electrical failure.
Robin
62.89 KB |
4942 Time(s) |
rvdave
Posted: Sun Feb 17, 2013 4:36 pm Post subject: Re: Mounting PC680 on firewall |
I know that vans sells a firewall mount for the PC680, wondering if anyone has used that or another mount and where it is located?
Cadillac, MI |
jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Mon Feb 18, 2013 5:33 am Post subject: Re: Mounting PC680 on firewall |
Dave, just a comment about letting the battery box rest on the engine mount. Consider that over time dirt and oil will work its way into the interface between the box and the engine mount. This slurry under pressure does a good job of sanding away at your engine mount. This situation is a bit different than using cushion clamps to hold something to the engine mount because the firewall and engine mount flex differently so there is more potential for relative movement. I would favor just mounting the box to the firewall, maybe with a backing plate to help reinforce. I have no first hand experience with mounting a battery on the firewall, but the practice is common in two seat RV's. Consider heat, and vibration as cons, cable length and weight as pros. No comment from me on W&B as I have no idea what else is being installed and where. It is worth while to run a W&B calc based on the two locations and see what difference it will make.
Thanks - Jason
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
Kelly McMullen
Posted: Mon Feb 18, 2013 6:36 am Post subject: Mounting PC680 on firewall |
I've been watching this discussion and wondering......having stuff on the firewall, more than absolutely required seems to be undesirable, both in limiting access to work on changing oil filter and maintaining the magnetos, and would not seem to be an advantage for W&B given that the original plans give a c.g.range that works. Maybe if extra stuff like air conditioning is going in the back it might be helpful.
I've just worked on two many planes that you have to remove the battery box from firewall to be able to service a magneto, etc. Granted the PC680 is smaller, but I still think it would be a maintenance annoyance.
On Mon, Feb 18, 2013 at 6:33 AM, jkreidler <jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)> wrote:
[quote] --> RV10-List message posted by: "jkreidler" <jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)>
Thanks - Jason
Jason Kreidler
http://forums.matronics.com/viewtopic.php?p=394484#394484
le, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
arplnplt(at)gmail.com Guest
Posted: Mon Feb 18, 2013 6:39 am Post subject: Mounting PC680 on firewall |
I use the BC100-1 from B&C Specialty products. Stand it on its side in the standard Van's try with no modification.Plenty of power.
David Leikam
RV10
On Feb 18, 2013, at 7:33 AM, jkreidler wrote:
[quote]--> RV10-List message posted by: "jkreidler" <jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)>
Thanks - Jason
Jason Kreidler
- The RV10-List --> &n========================
