Paul M 383
Joined: 19 Mar 2012 Posts: 102 Location: United Kingdom
Posted: Thu Feb 07, 2013 5:32 am Post subject: Woodcomp Prop diameter |
I'm thinking of ordering a Woodcomp SR3000/3 for my 912S-powered XS Mono.
The preferred prop size seems to be 1625 mm... The factory offered 1625 or 1650, and I think 1625 is best for ground clearance reasons. Anybody got any better ideas?
I am also going for the SR3000/3 - again, unless somebody tells me I simply *must* have the 3000/3W.
All answers gratefully received...
Paul M
XS Mono 912S
christoph.both(at)acadiau Guest
Posted: Thu Feb 07, 2013 5:47 am Post subject: Woodcomp Prop diameter |
I installed the SR3000-2 blade, scimitar. It is sized 1650mm, so the
1625mm seems to make sense for the 3-blade. Saved 9 pounds weight, though
up front, with the 2 blade.
Christoph Both
#223 Wolfville, Nova Scotia, Canada
Paul M
XS Mono 912S
http://forums.matronics.com/viewtopic.php?p=393767#393767
frans(at)privatepilots.nl Guest
Posted: Thu Feb 07, 2013 6:42 am Post subject: Woodcomp Prop diameter |
On 02/07/2013 02:32 PM, Europaul383 wrote:
Quote: | I am also going for the SR3000/3 - again, unless somebody tells me I
I would go for the /W, because for the Europa cruise speed the inner
portion of the blades has a much better profile. It increases
efficiency, speed, and cooling. (The latter because the inner portion of
the blades throws more air into the cooling system). I'm unaware of any
advantage of the "normal" version over the /W version. The /W version is
simply a prop better suited for the speed range of the Europa airplane.
Also I would go for the 2-blade version. This for the same reason as why
for a fast airplane a single plane wing is better than a bi-plane. With
two blades instead of three you cut down 33% of the leading edge,
blade-tip vortexes, weight, etc. The result is higher efficiency and
higher speed, lower gyroscopic effects, better glide ratio, etc. The /2W
prop has more than enough area to fully utilize the power of the Rotax
engine; you don't need more blades for this amount of power.
I have the SR3000/2W on my 914 powered Europa, and I'm very satisfied
with the performance to say the least. The only drawback of a 2-blade
prop is that it is a bit more prone to vibrations, but with the prop
properly balanced and the carburators properly tuned there are no
significant vibrations. I see it as an advantage that I immediately feel
it when the carbs are unbalanced, inviting me to investigate, rather
than to hide the imbalance to me until more serious problems develop.
Avoid the scimitar blades. They offer no advantage over the normal
blades, it is just for the looks (if it is your taste after all), but
they are asymmetrical on the variable pitch system and create strain
both mechanically as electronically.
Frans
Paul M 383
Posted: Thu Feb 07, 2013 7:53 am Post subject: Re: Woodcomp Prop diameter |
Thanks to both (no pun intended, Christoph!),
Christoph: I have just found our LAA limits (based on EASA CS-VLA) and it might be tricky getting 1650 approved, but now the topic has opened up to 2 vs. 3 blades and W vs. normal.
Frans: do you have any data you may have recorded during testing/touring?
Specifically, airspeed & RPM (presumably 5,500?) mapped to climb rates; and max speed at different weights.
A bit of a long shot, but have you measured any data while normally-aspirated (turbo off)? If you need an excuse to go flying, maybe you might fancy trying some normally-aspirated climbs and cruises?
Thanks in advance,
Paul
XS Mono 912S
Posted: Thu Feb 07, 2013 8:18 am Post subject: Woodcomp Prop diameter |
On 02/07/2013 04:53 PM, Europaul383 wrote:
Quote: | Frans: do you have any data you may have recorded during
testing/touring?
Yes, but my ship is quite non-standard and it is impossible to attribute
the performance to the individual mods as they where there from the
beginning. I have very large wing root fairings, highly modified low
drag cooling, intercooler on the engine, a modified high top
arrangement, gap seals, modified exhaust, etc. and the /2W prop is just
one of the features. My Europa seems to be on the "fast" side when
compared to other Europa's.
Quote: | A bit of a long shot, but have you measured any data while
I don't see how it would be possible to turn the turbo off (turning it
off is something entirely different to flipping the TCU switch) but of
course I can fly in Manifold Pressure regions that are available to
naturally aspirated engines too. In fact I usually fly with about 27 to
28" of MAP which gives me speeds around 130 IAS (at)MTOW if I recall
correctly. (Haven't been flying for a while due to weather and lack of
reachable interesting destinations).
Frans
Posted: Thu Feb 07, 2013 10:35 am Post subject: Woodcomp Prop diameter |
Paul, I have data comparing performance of SR 3000W 1625
with SR 2000 1625 on a 914 and clear advantage for latter.
Am skiing at present but when home will send you the full
analysis. The LAA will I believe not accept 1650, and I
suspect that Woodcomp would advise the 3 blader (but ask
them) for a 912 S as they did for my 914, otherwise at any
height you risk running out of propeller to take the
power.
Regards, David Joyce, G- XSDJ
On Thu, 7 Feb 2013 07:53:03 -0800
testing/touring?
normally-aspirated climbs and cruises? [Wink]
Thanks in advance,
Paul
XS Mono 912S
http://forums.matronics.com/viewtopic.php?p=393776#393776
Un/Subscription,
Forums!
Admin.
graeme bird
Posted: Thu Feb 07, 2013 10:54 am Post subject: Re: Woodcomp Prop diameter |
I changed last year. I guess you saw my post regarding replacement blades on the W version having to be a set. If I started again I would go for the normal ones. It has to be 1625 and 3 blades to be approved by the LAA.
having put it on, put the warp drive back, then back to woodcomp, I cant say that there was any substantial cruise performance increase except take off and more control on landing. It looks very nice though.
Kevin was very helpful.
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
Posted: Thu Feb 07, 2013 11:46 am Post subject: Woodcomp Prop diameter |
On 02/07/2013 07:34 PM, David Joyce wrote:
Quote: | I suspect that Woodcomp would advise the 3 blader (but
ask them) for a 912 S as they did for my 914, otherwise at any height
you risk running out of propeller to take the power.
With my 914 intercooler and 3000/2W I fly regularly at +FL100 but never
ran out of propeller to take the power or even close to that.
Frans
Posted: Thu Feb 07, 2013 12:47 pm Post subject: Woodcomp Prop diameter |
Frans, We are of course subject to LAA scrutiny & they
require us to demonstrate climb rate of >300fpm in max
coarse from a go around, which no doubt means that our
coarse stop will be not so coarse as yours. I can
overspeed the engine at 100% throttle at 10,000ft - not
that at is of great consequence as I usually cruise at
much lower throttle settings. Otherwise your inter cooler
is working wonders! Regards, David Joyce
On Thu, 07 Feb 2013 20:45:50 +0100
>at any height
+FL100 but never
that.
Frans
Un/Subscription,
Forums!
Admin.
MalcolmH
Posted: Fri Feb 08, 2013 4:08 am Post subject: Re: Woodcomp Prop diameter |
davidjoyce(at)doctors.org wrote: | Paul, I have data comparing performance of SR 3000W 1625
power.
"Europaul383" <europaul383> wrote:
I'm sure David will correct me but I think he meant 'former' in his response above
Paul, I am in a similar position to yourself and indeed asked the same question on the forum and David was most helpful in the advice he gave. However then Frans suggested the 2W option. I didn't find Woodcomp particularly helpful I'm afraid. I had a little correspondence with Kevin and the factory but the bottom line seemed to be you pays your money and takes your choice.
My view is that its an awful lot of money to spend only to realize you've made a mistake and now Graeme has concluded that he would have fitted the 'normal' ones (by this I think he means 3000/3 no W suffix).
So I was erring towards the 3000/3W but not sure again after Graeme's comment.
One thing though the Smart Avionics Controller would be my option.
Paul M 383
Posted: Fri Feb 08, 2013 7:44 am Post subject: Re: Woodcomp Prop diameter |
As you say Malcolm, I have made up my mind I'm not sure!
I know the LAA mandate a max of 1625 mm (based on clearance calcs in CS-VLA, which is not a requirement for LAA aircraft, but that's another argument!)... they don't insist on 3 blades - Andy Draper said they have lots of 3000/2W listed for Sport Cruisers, but I guess they have the ground clearance to allow for longer blades...
I suspect 3 blades may be necessary to keep a decent blade area for 1625 diameter (with a 1650 you have more area, so can get away with 2 blades I guess).
So now it's *just* a choice of wide vs. normal:-
Data showing W is better for 914 - but does this apply equally to 912S?
or a subjective comment "If I started again I would go for the normal ones" (like you, I think that's what he means).
Decisions, decisions!
rowlandcarson(at)gmail.co Guest
Posted: Fri Feb 08, 2013 11:10 am Post subject: Woodcomp Prop diameter |
On 7 Feb 2013, at 13:32, Europaul383 wrote:
Quote: | I'm thinking of ordering a Woodcomp SR3000/3 for my 912S-powered XS Mono.
Paul - for what it's worth, I have got the SR3000/3W in 1625mm diameter for my Rotax 912S, but the two have not yet been married together, and the airframe is a long way from completion yet, so I can't report on the success of the combination. The high twist of the W blade seems much better suited to the speed range of the Europa, and should not be causing negative thrust, as some lower-twist blades can, in certain speed ranges (David Joyce has done the sums on that).
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
graeme bird
Posted: Fri Feb 08, 2013 11:29 am Post subject: Re: Woodcomp Prop diameter |
yes and the rationale was,
a) David J had written somewhere that the twist on his 914 hadnt given him as much as expected (and I am on a 912S)
b) they are standard blades and cheaper, and a single blade can be replaced if you ding one (rather than £2000 for three).
After my ding I would have gone from W to normal IF I hadn't done all the flight testing and been through the approval process with the W.
According to Andy Draper, 1625 is max on a mono due to ground clearance and then two short blades wont be enough.
If anyone wants two fine 3000W blades I have them - good as new.
kit4 (Wagstaff) TBD
Paul M 383
Posted: Fri Feb 08, 2013 12:07 pm Post subject: Re: Woodcomp Prop diameter |
Thanks Rowland and Graeme,
Great answers and both valid in their own right (dammit!) The choices seem to be:
W for the extra twist needed (although not necessarily as much as expected).
Normal for lower cost & lower replacement cost.
I'll get whatever you decide, MalcolmH!
Thanks to everybody for all the very useful input.
Paul M
XS Mono 912S
Posted: Sun Feb 10, 2013 4:11 am Post subject: Woodcomp Prop diameter |
Paul, Back from skiing and as promised herewith the text
of the article I wrote comparing a 12 degree twist prop
with a 26 degree twist prop (ie the SR3000W (The
originalwas published in the Europa Flyer a few years
back). The key points are:
Climb rate, Fuel consumption both improved
Top speed incvreased 4 knots at low and medium altitude -
this is the equivalent of the engine giving an extra 7 HP!
Cooling dramatically improved./
None of this should come as a surprise - if
you look at any high/highish performance propeller driven
plane from Spitfires through Red Bull racers to modern
turboprops, they all have propellers with around 26
degrees of twist, and given the relative diameter of their
props their speed range demands the same sort of prop
design as a Europa for optimal performance. At any normal
cruise speed the central portion of a Europa 12 degree
twist prop will be in Beta mode, effectively braking that
central column of air and diverting it from the cooling
intakes.
It seems a pity to me to pick a prop on the
basis of how much it might cost to replace if you break a
blade
I will contact Jiri at Woodcomp and get an
answer as to whether they feel that a 2 bladed 3000W can
cope with the power of a 912S
Regards, David Joyce, G-XSDJ
On Thu, 7 Feb 2013 05:32:34 -0800
ideas?
Paul M
XS Mono 912S
Un/Subscription,
Forums!
Admin.
Description: |
 Download |
Filename: |
Does_Propeller_Twist_Matter.doc |
Filesize: |
40 KB |
Downloaded: |
1297 Time(s) |
Paul M 383
Posted: Mon Feb 11, 2013 10:14 am Post subject: Re: Woodcomp Prop diameter |
Thanks David,
I read your interesting article when it came out, but thought the improvement was between your previous SR2000 and the new SR3000 (not the SR3000 vs. SR3000/W).
Speaking to Jiri (at) Woodcomp, they simply supply "what the builder prefers", but can say historically that most Europas have 1625mm and "some" have the W blades.
What I didn't know is that the W are not just wider, but have more twist - I thought the 3000 had the same twist as the 3000/W, so it was just a choice of narrow vs. wide. Now I know different...
The factory line on blade replacement is not that the W blades have to be supplied in 3s (and the normal/narrow blades are not guaranteed to be available singly) - just that they have to be equally balanced as a set - and since the narrow blades are produced in greater numbers, there is a greater chance of finding blades that match.
In addition, most blades they produce are 1700mm, so it is less likely to find a balance match for a shorter 1625mm blade ... even more so (statistically) for the rarer short, wide blades.
They do not want to make maintenance and replacement an expensive exercise, but they do have to find ones that balance.
I am waiting for a price on the W blades, but I suspect that is the way I shall be going.
Thanks again to everybody for very useful information.
Paul M
XS Mono 912S
