What terminal is this ?
Tundra10
PostPosted: Mon Feb 04, 2013 12:40 pm    Post subject: What terminal is this ? Reply with quote
So many connectors and no good way to sort through them all.
Does anyone know what terminal this is ?
http://www.qenesis.com/Temp/terminal.jpg
Thanks !
Jeff Page
Dream Aircraft Tundra #10
 Filesize:  31.71 KB
 Viewed:  7773 Time(s)
PostPosted: Mon Feb 04, 2013 1:27 pm    Post subject: What terminal is this ? Reply with quote
That terminal is used in a variety of products
including holders ATC plastic fuses where the wires
come in through the mounting surface to the back side
of the holder or, in this case, up under the fuse
holder from the front side of the mounting surface.
http://tinyurl.com/bl7b7ku
[img]cid:.0[/img]
 Filesize:  32.38 KB
 Viewed:  7772 Time(s)
Tundra10
PostPosted: Mon Feb 04, 2013 2:09 pm    Post subject: Re: What terminal is this ? Reply with quote
Thanks Bob !
These seem to be pretty uncommon, since Digi-key, Mouser etc. don't seem to carry them. Now that I have a part number, it is clear why I had trouble finding them before.
Once again, you have saved me a lot of time. Thanks !
Jeff Page
jlatimer1(at)cox.net
PostPosted: Mon Feb 04, 2013 2:52 pm    Post subject: What terminal is this ? Reply with quote
Jeff,
I used a rear feed fuse block that used these terminals. There is also a
removal tool for them that was useful. Here is link to a website that has
the terminals, blocks, and exctraction tool.
If the link doesn't work, the company is MIH Industries.
Hope this helps.
Jerry Latimer
http://home.earthlink.net/~dswartzendruber/id13.html
Tundra10
PostPosted: Mon Feb 04, 2013 3:22 pm    Post subject: Re: What terminal is this ? Reply with quote
Wow. That helped a lot. Turns out this terminal is used in many GM vehicles, so lots of auto parts places have it.
In case anyone else is looking for it, search for PackCon III. They are available for different size wires.
It seems the automotive ones are not plated, but rumor has it that the John Deere 57M7508 is.
Thanks !
Jeff Page
jimw_btg(at)earthlink.net
PostPosted: Mon Feb 04, 2013 9:04 pm    Post subject: What terminal is this ? Reply with quote
Another good source for this and other electrical connection products is
Waytek Inc. www.waytekwire.com
Take care.
Jim Wickert
Tel 920-467-0219
Cell 920-912-1014
Tundra10
PostPosted: Mon Feb 04, 2013 10:53 pm    Post subject: Re: What terminal is this ? Reply with quote
Thanks !
