riveting question
caveman(at)pemtel.net
PostPosted: Sat Jan 26, 2013 5:53 pm    Post subject: riveting question Reply with quote
Hi -
I am building a 701. I finally got to the point of riveting the
left wing skeleton together, and I am encountering a problem. Many
of the rivets are close to one or more flanges, such that it is
impossible to set the rivet tool at right angles to the work. I
tried going ahead and setting the rivets with the tool at an angle,
but I'm not very happy with the results.
Can anyone suggest a technique for setting these rivets? I would
really appreciate any insights.
If you feel that this does not warrant posting on the list, please
email me directly at caveman(at)pemtel.net.
Thanks ----
---- Mike Newsome
carlossa52(at)gmail.com
PostPosted: Sat Jan 26, 2013 7:53 pm    Post subject: riveting question Reply with quote
Mike, take a look at this discussion, on top of the page.
I made something like it and use several times in tight spots. Life saver.
http://www.vansairforce.com/community/showthread.php?p=267189
Good luck
Carlos
CH601-HD, plans
On 26 January 2013 20:49, Mike Newsome <caveman(at)pemtel.net (caveman(at)pemtel.net)> wrote:
[quote]--> Zenith701801-List message posted by: "Mike Newsome" <caveman(at)pemtel.net (caveman(at)pemtel.net)>
Hi -
email me directly at caveman(at)pemtel.net (caveman(at)pemtel.net).
Thanks ----
   ---- Mike Newsome
Terry Phillips
PostPosted: Mon Jan 28, 2013 10:36 am    Post subject: riveting question Reply with quote
Carlos
That is a really slick little tool. I could have used that a couple of times. Thank you for posting that.
Terry
[quote] [img]cid:part1.04000500.03030708(at)gmail.com[/img]
Carlos Sa (carlossa52(at)gmail.com)
Saturday, January 26, 2013 8:52 PM
Good luck
Carlos
CH601-HD, plans
Terry Phillips
ttp444~at~gmail.com
Corvallis MT
ZU-601XLB/Jab 3300 s .. l .. o .. o .. o .. w build kit - Tail & flaps are done;
Upgrading wings & ailerons per the AMD Safety Directive
http://www.mykitlog.com/N47TP/
 Filesize:  770 Bytes
 Viewed:  4288 Time(s)
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
