Bendix Mags, Ground Point
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
viperpilot
PostPosted: Mon Jan 21, 2013 7:02 pm    Post subject: Bendix Mags, Ground Point Reply with quote
I had my Bendix mags overhauled following a prop strike. The overhauled mags came back with "ring-and-post" connections to replace the "cigarette" connections I had previously. (photo attached)
The left magneto has a "retard" post to which I assume my "shower of sparks" output attaches. Both mags have a pretty evident post to which I plan to attach the core of the P-lead wire from my magneto switches (I have two magneto switches instead of a single key-operated starter switch.) I have wired the magneto switches as recommended by Bob Nuckels in his book, option "B".
The Question: Where does the SHIELD part of the wire get connected to the magneto to ground it?
The obvious point would be the gold-colored screw to the right and below the left mag (and the similar screw to the left and below the right mag). Does anyone have a similar setup with Bendix mags? Please advise.
Randy
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
 Filesize:  1.55 MB
 Viewed:  5221 Time(s)
smokyray(at)rocketmail.co
PostPosted: Tue Jan 22, 2013 10:08 am    Post subject: Bendix Mags, Ground Point Reply with quote
You are correct. The mag schematic is posted on the Bendix website FYI.
My advice is to install electronic ignition and never look back...
Smokey
Randy
http://forums.matronics.com/viewtopic.php?p=392863#392863
http://forums.matronics.com//files/img_2611_209.jpg
nrsage86(at)comcast.net
PostPosted: Tue Jan 22, 2013 11:07 am    Post subject: Bendix Mags, Ground Point Reply with quote
Thanks, Smokey!
Randy
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
