Posted: Mon Jan 21, 2013 6:30 am Post subject: Rear Seat Heat Issue |
We had a slightly different problem with a draft coming from the rear
and cooling my front seat passenger's right side. I have Flightline's
panels on the rear baggage covers which has foam and a pretty tight
fit. I had asked a back seat passenger to feel around but got no joy.
Finally on a cold flight, my SO crawled back and felt around and it
seemed to come from the baggage door. I had tried to put some sealing
around the door previously but pulled it out. I did some careful
sealing there and the problem seems to be resolved.
Bill
On 1/15/2012 3:30 PM, jchang10 wrote:
Hmm, a few people mentioned once they added a backing to the baggage cover to seal those gaps, they have not had any complaints about rear seat heat.
I'll start looking for something to use for backing, and hope it solves my problem too.
Thanks again!
Jae
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
http://forums.matronics.com/viewtopic.php?p=363882#363882
rv10flyer
Posted: Tue Jan 22, 2013 9:56 am Post subject: Re: Rear Seat Heat Issue |
I have everything sealed up pretty good(spars, aileron pushrods, corrugations and doors). At 20*F once we are warmed up(3-5 min after takeoff), we keep the front open 1/4" and the rear open 1/2". The kids keep wool blankets over the heat outlets, so most of the heat comes right up around them.
_________________ Wayne G. |
jchang10
Posted: Tue Jan 22, 2013 10:30 am Post subject: Rear Seat Heat Issue |
Thanks Bill and Wayne. I started that thread a year ago. I discovered that most of that cold air was coming in thru the corrugations of the baggage bulkheads. I ended up cutting up triangular shaped foam plugs which i glued into the corrugations which seems to be doing an adequate job.
Now on my second winter, i noticed my biggest air leak is now air coming in thru the cabin door pin holes. I am using the Al door pin blocks with a fairly tight fit to the door pins, so i'm surprised to be getting as much air in as i am. I haven't come up with a solution yet.
Another observation i noticed in my second winter, is that since most of the big air leaks are taken care of, there is less air movement in the cabin. This actually makes the cabin colder than with some air circulation. I used to crack open the rear cabin heat and let that hot air circulate everywhere which worked nicely. Now, with all the cold air vents closed, if you open up the front and rear heat, you generally got very hot feet and lower legs, but the rest of the body is cold. This is what my passengers have told me.
A worse problem for me is that the front cabin heat seems to just go straight up into the instrument area, causing unnecessary heating of the panel. I often find myself trying to redirect cold air from the pilot's vent back behind the panel as much as i can. Getting some air moving in there helps to circulate the heat to other parts of the cabin where it is more useful.
Anyway, these are some other observations related to cabin heating i have recently noticed.
Jae
| Quote: | --
#40533 RV-10
do not archive |
On 1/22/2013 9:56 AM, rv10flyer wrote:
[quote] | Quote: | --> RV10-List message posted by: "rv10flyer" <wayne.gillispie(at)gmail.com> (wayne.gillispie(at)gmail.com)
Wayne G.
12/01/2011
TT= 95
| [b]
_________________ #40533 RV-10
Phase 1 Done 11/26/2011 |
