frank goodnight
Posted: Sun Jan 20, 2013 7:32 am Post subject: electric fuel pump |
[img]cid:1358694869461(at)dclient.mail.yahoo.com[/img] Hi,
I fly a firestar with a HKS engine, it uses the same pluse
pump as a 503 for the engine mounted pump with the elect
pump mounted between the tank and and the engine pump.
Do most of you that have that type system, leave the
electric pump on all the time , or turn it off after takeoff?
I have always left the electric pump on all the time--about
200 flight hrs--. Lately I have been hearing that it may be
better to turn it off after takeoff. Like to hear thoughts
from anyone who uses this type sys.
Frank Goodnight
12.03 KB |
6286 Time(s) |
pj.ladd(at)btinternet.com Guest
Posted: Sun Jan 20, 2013 8:43 am Post subject: electric fuel pump |
Frank,
Lets not start with the silly pictures eh? Just leave it to the under twelve year olds.
Pat (Curmudgeon in UK)
frank goodnight
Posted: Sun Jan 20, 2013 8:53 am Post subject: electric fuel pump |
Pat,--- Don't what you are talking about. I have sent NO pictures to you or anyone else.
Please be sure of what you are talking about before flaming someone.
Thanks Frank
Sent: Sun, January 20, 2013 10:44:04 AM
Subject: Re: Kolb-List: electric fuel pump
Frank,
zeprep251(at)aol.com Guest
Posted: Sun Jan 20, 2013 9:02 am Post subject: electric fuel pump |
Frank,
The pulse supply from the intake manifold on the HKS is weak.We have had lean condition at high cruise power settings with the pulse pump only.Their high dollar replacement pump is still less than ideal.Run the pump all the time.If it was mine,I'd have a second electric pump in line as well.I doubt they could get good signal even from the crankcase.It needs a cam driven pump like Rotax or Jabiru.A stout engine other than that.
G.Aman .
12.03 KB |
6277 Time(s) |
frank goodnight
Posted: Sun Jan 20, 2013 9:06 am Post subject: electric fuel pump |
Thanks Gary, I believe the same.
Frank
Sent: Sun, January 20, 2013 11:02:45 AM
Subject: Re: electric fuel pump
Frank,
G.Aman .
12.03 KB |
6277 Time(s) |
Thom Riddle
Posted: Sun Jan 20, 2013 9:31 am Post subject: Re: electric fuel pump |
Frank,
If you will log onto the Matronics website and see your post, you will see the silly cartoon that Pat was talking about. It is a .jpg file somewhere in your post. Look for it and perhaps you can get rid of it.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Sun Jan 20, 2013 11:18 am Post subject: electric fuel pump |
Thom Riddle
Buffalo, NY (9G0)
Kolbers:
Do you all know Frank G? He is a big, tough guy. Spent a lot of time
living in the wilds of Alaska, not downtown Anchorage.
Frank has had that little cartoon character on his emails for as long as I
have known him, which has been a while now. I have a feeling if he wanted
to get rid of it, he would have done so long ago.
There is a story behind the "character", but my memory fails me. Someone
else, long ago on the Kolb List, tried to encourage Frank to get rid of his
character. Seems they did not succeed.
A few years ago Frank almost made it to the Monument Valley Flyin in his
Firestar. He made it from Brownsville, Texas (IIRC) to Window Rock,
Arizona, approximately 1,000 sm over some unfriendly terrain and extremely
high altitudes. Frank was about 100 sm from Monument Valley when he decided
it best he cancel out the rest of the flight and continue by road. I said
earlier, Frank is a very big man who discovered the little Firestar powered
with the HKS did not have enough grunt to get him over the mountains safely,
and Frank might need more training and experience flying in the high
altitudes and extreme winds of the Rockies.
All this chatter of Frank's cartoon character probably should not have come
to the Kolb List, but sent bc to Frank if it was all that important.
_________________ John Hauck
Titus, Alabama |
Thom Riddle
Posted: Sun Jan 20, 2013 11:59 am Post subject: Re: electric fuel pump |
If Frank likes his cartoon character, then he should be proud of it, not deny its existence. I was just backing Pat's statement that it existed in Frank's post, an unassailable truth.
Buffalo, NY (9G0)
- Anonymous |
Dana
Posted: Sun Jan 20, 2013 1:52 pm Post subject: electric fuel pump |
At 11:52 AM 1/20/2013, frank goodnight wrote:
| Quote: | Pat,--- Don't what you are talking about. I have sent NO pictures to you or anyone else.
Thanks Frank
do not archive |
Frank, it's a picture of a cartoon character blowing heart shaped bubbles, and it's in every post you send to the list. Has been for a long time.
-Dana
People will accept your ideas much more readily if you tell them that Benjamin Franklin said it first.
lcottrell
Posted: Sun Jan 20, 2013 2:55 pm Post subject: electric fuel pump |
John and I have been trying to find "Stationary" like that but so far have not been successful. I will keep trying.Larry
On Sun, Jan 20, 2013 at 2:45 PM, Dana Hague <d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)> wrote:
Thanks Frank
do not archive |
-Dana
tp://forums.matronics.com
