frank goodnight
Posted: Sun Jan 20, 2013 7:14 am Post subject: fuel pump 701 |
[img]cid:1358694409322(at)dclient.mail.yahoo.com[/img] Hi ,
My question is-- Do most of you fly with the aux electric
fuel pump running all the time , or turn it off after takeoff?
So far I have left mine on all the time.
Frank Goodnight
701 912ULS about 2 hrs.
Fayetteville , AR
12.03 KB |
12228 Time(s) |
dougsnash
Posted: Sun Jan 20, 2013 7:25 am Post subject: fuel pump 701 |
What aux fuel pump? I did fuel flow test on my 701 and found an aux pump was unnecessary. Standard practice would be to only use the aux pump when high angle of attack flight is anticipated, ie:during takeoff and possibly during landing.
Doug M
CH-701 from scratch
NW Ontario, Canada
On 2013-01-20, at 9:13 AM, frank goodnight <frank.goodnight(at)att.net (frank.goodnight(at)att.net)> wrote:
[quote]<--static--liam_heartbubbles_bottomleft.jpg> Hi ,
Frank Goodnight
Fayetteville , AR
frank goodnight
Posted: Sun Jan 20, 2013 7:57 am Post subject: fuel pump 701 |
Hi Doug,
I mounted a faucet electric fuel pump just forward of the fuel control on the cabin
floor. My thoughts were that it might help if I got into a vapor lock situation when
hot and high with auto fuel. My other planes have used this sys , with a pluse type
engine pump that is operated off changes in induction pressure. I'm new to the 912
and the 701 so everything is a learning experience for me. Thanks for your thoughts
and intrest.
Frank
To: "zenith701801-list(at)matronics.com" <zenith701801-list(at)matronics.com>
Sent: Sun, January 20, 2013 9:25:22 AM
Subject: Re: fuel pump 701
Doug M
CH-701 from scratch
NW Ontario, Canada
| Quote: | <--static--liam_heartbubbles_bottomleft.jpg> Hi ,
Frank Goodnight
Fayetteville , AR
klondike(at)megalink.net Guest
Posted: Sun Jan 20, 2013 8:14 am Post subject: fuel pump 701 |
not good
dougsnash
Posted: Sun Jan 20, 2013 8:56 am Post subject: fuel pump 701 |
Fritz, do you mean the absence of an auxiliary fuel pump on my plane is not good?
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Here in Canada a fuel flow test is mandatory before first flight. I'm traveling for work right now so I don't have the documentation with me but if I recall, at a climb angle of 17 degrees, I had two times the full power fuel requirement of my engine available at the carbs using strictly gravity flow. Much above 17 degrees and the fuel tanks get too close to the same level as the engine fuel pump to provide adequate gravity flow. Fortunately, 17 degrees is more than adequate for a safe climb. Given these numbers, I am satisfied flying without an auxiliary fuel pump.
Ultimately, however, we all must decide just how much redundancy we need in our planes. Each to their own, I suppose.
Doug M
To: zenith701801-list(at)matronics.com
Sent: Sunday, January 20, 2013 10:14:13 AM
Subject: Re: Zenith701801-List: fuel pump 701
--> Zenith701801-List message posted by: "fritz" <klondike(at)megalink.net (klondike(at)megalink.net)>
not good
Posted: Sun Jan 20, 2013 9:32 am Post subject: fuel pump 701 |
Yes Doug, I was referring to the "redundancy". Take-offs" being the most
critical part of flight-- in my opinion only. I also agree with Frank that
it lessens the chance of a vapor lock. Your numbers prove you to be
correct.
I was thinking 601, low wing, when I made my post.
Happy flying--- Fritz
Dan Wilde
Posted: Sun Jan 20, 2013 9:33 am Post subject: fuel pump 701 |
I also have no aux fuel pump. Have not had for over 5 years and 250 hours. The plane was built to Zenith standards which at the time at least did not show a need for it. Fuel flow has never been an issue even when hanging it on the prop at full throttle (granted that is only done for a short period since it makes me nervous.
Dan Wilde
Posted: Sun Jan 20, 2013 9:42 am Post subject: fuel pump 701 |
My 701 was a long time ago when the plans called for the fuel tank behind
the instrument panel = less gravity fuel press therefore I had engine
driven pump with an electric, aux pump.
Happy Flying--- Fritz
dougsnash
Posted: Sun Jan 20, 2013 9:53 am Post subject: fuel pump 701 |
Ah, yes, the 601 would definitely require a boost pump.
Honestly, I purchased a Facet boost pump for my plane but decided it was more complication for the fuel system than I was comfortable with. Once I had the flow numbers figured out, I figured the boost pump was unnecessary.
Doug M
CH-701
NW Ontario, Canada
On 2013-01-20, at 11:32 AM, "fritz" <klondike(at)megalink.net> wrote:
Yes Doug, I was referring to the "redundancy". Take-offs" being the most critical part of flight-- in my opinion only. I also agree with Frank that it lessens the chance of a vapor lock. Your numbers prove you to be correct.
NYTerminat(at)aol.com Guest
Posted: Sun Jan 20, 2013 12:08 pm Post subject: fuel pump 701 |
Frank, In answer to your question, I only used my electric fuel pump for take offs and landings as a backup in critical times.
Bob Spudis
N701Zx/ 912S/ sold
In a message dated 1/20/2013 10:14:54 A.M. Eastern Standard Time, frank.goodnight(at)att.net writes:
Hi ,
Frank Goodnight
Fayetteville , AR
12.03 KB |
12214 Time(s) |
rpf(at)wi.rr.com Guest
Posted: Mon Jan 21, 2013 9:45 am Post subject: fuel pump 701 |
I have a 601xl with a Jab 3300 and only use the fuel pump before starting(turn it on for a few seconds, turn it off and start the plane). I have 740 hours on my plane.
Randy
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of Dan Wilde
Sent: Sunday, January 20, 2013 11:33 AM
Dan Wilde [/b]http://forums.matronics.com - List Contribution Web generous nbsp; -Matt Dralle, List href="http://www.matronics.com/contribution">http://www.matronics.com/c=[/b] [b]
Posted: Mon Jan 21, 2013 9:56 am Post subject: fuel pump 701 |
some folks have more hours than this on their aircraft before bad habits
catch up to them---- good luck.
Posted: Mon Jan 21, 2013 11:00 am Post subject: fuel pump 701 |
That's what's nice about living in America, so far, we can still do what we
want. You do want you want and I'll do what I want. I also believe the
owner of Jabiru USA does it this way. Don't consider it a "bad habit" at
all.
grumman1(at)hotmail.com Guest
Posted: Mon Jan 21, 2013 11:40 am Post subject: fuel pump 701 |
I fly a grumman aa1, Use elect. pump only for take off, landing and switching tanks, and when landing I shut it down before touchdown just in case of problem on roll out, this is a normal procudure for me,
Mike J.
[quote] From: rpf@wi.rr.com
To: zenith701801-list@matronics.com
Subject: RE: Zenith701801-List: fuel pump 701
Date: Mon, 21 Jan 2013 13:00:31 -0600
--> Zenith701801-List message posted by: "Randy" <rpf@wi.rr.com>
all.
Posted: Mon Jan 21, 2013 12:17 pm Post subject: fuel pump 701 |
I salute you, this is similar to the way I was taught.
