Cable runs
woxofswa
PostPosted: Sat Jan 12, 2013 2:01 pm    Post subject: Cable runs Reply with quote
Quick question for the brain trust. I am finishing FWF and was wondering about issues involving securing the EGT (Dynon metal braid) lines in the same cushioned clamps as the spark plug cables for a clean and tidy installation.
Are they respectively shielded enough that there is no issue or is it better to secure them separately?
Thanks in advance.
Myron Nelson
Mesa, AZ
Flew May 10 2014
flysrv10(at)gmail.com
PostPosted: Sat Jan 12, 2013 2:11 pm    Post subject: Cable runs Reply with quote
Mine are tied together without any issues.
Rob Kermanj
Thanks in advance.
Myron Nelson
Mesa, AZ
Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress.
http://forums.matronics.com/viewtopic.php?p=392131#392131
rv10flyer(at)live.com
PostPosted: Sat Jan 12, 2013 2:34 pm    Post subject: Cable runs Reply with quote
Using the Skyview setup, this is exactly what I did without any issues at
all. Get a CHT spike every once in a while but that is a connection issue
and not a routing issue. You will have no issues putting them all together.
dave.saylor.aircrafters(a
PostPosted: Sat Jan 12, 2013 4:07 pm    Post subject: Cable runs Reply with quote
Myron,
It sure would seem like the very high voltage to the spark plugs vs.
the very low voltage from the thermocouples would be a bad mix--like
it would bleed over and give the EGT some kind of bizarre reading.
But, I've seen it done on lots of installations and it never seems to
be a problem. Has anyone seen any oddball EGT readings as a result?
It does make sense from a neatness/weight/convenience/hardware count
perspective to run them all together.
Dave Saylor
831-750-0284 CL
Thanks in advance.
Myron Nelson
Mesa, AZ
rnewman(at)tcwtech.com
PostPosted: Sat Jan 12, 2013 6:09 pm    Post subject: Cable runs Reply with quote
Although running AFS equipment mine are neatly tied together and all readings are rock solid. Also true of the other planes my dad and I built. It's a non issue.
Bob Newman
On Jan 12, 2013, at 7:04 PM, Dave Saylor <dave.saylor.aircrafters(at)gmail.com> wrote:
Myron,
Dave Saylor
831-750-0284 CL
> Thanks in advance.
> Myron Nelson
> Mesa, AZ
bill.peyton
PostPosted: Sun Jan 13, 2013 7:19 am    Post subject: Re: Cable runs Reply with quote
I ran mine in a separate clamp attached to the same valve cover screw as the ignition leads. I did not want to take the chance if an erroneous reading with the egt. In reality, the egt lines are such low impedance that the chance of it happening is slim. It was too easy to just use additional adel clamps...
 Filesize:  738.41 KB
 Viewed:  8003 Time(s)
WA0SYV
Aviation Partners, LLC
schmoboy
PostPosted: Sun Jan 13, 2013 12:13 pm    Post subject: Cable runs Reply with quote
I'm curious what you guys did for the lip of the valve cover by the
screws. Did you add washers to lift up the contact area of the clamp to
clear the lip of the valve cover?
-Sean #40303 (finishing cowl)
WA0SYV
http://forums.matronics.com/viewtopic.php?p=392178#392178
http://forums.matronics.com//files/image_620.jpg
flying-nut(at)cfl.rr.com
PostPosted: Sun Jan 13, 2013 12:41 pm    Post subject: Cable runs Reply with quote
to clear the lip of the valve cover?
Yes. Standard practice!
Linn
> Bill
> WA0SYV
Checked by AVG - www.avg.com
PostPosted: Sun Jan 13, 2013 12:44 pm    Post subject: Cable runs Reply with quote
Yep, added washers.
On Jan 13, 2013, at 3:12 PM, Sean Stephens wrote:
I'm curious what you guys did for the lip of the valve cover by the screws. Did you add washers to lift up the contact area of the clamp to clear the lip of the valve cover?
> Bill
> WA0SYV
bill.peyton
PostPosted: Sun Jan 13, 2013 1:13 pm    Post subject: Re: Cable runs Reply with quote
The new LYCOMING engines come with a bag of washers and screws that are longer than the factory installed valve cover screws. The washers go under the clamps
WA0SYV
Kelly McMullen
PostPosted: Sun Jan 13, 2013 1:35 pm    Post subject: Cable runs Reply with quote
That is what I do Sean, to ensure the valve cover is secure and to give the adel clamp a flat surface to rest on.
On Sun, Jan 13, 2013 at 1:12 PM, Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)> wrote:
[quote]--> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)>
--> RV10-List message posted by: "bill.peyton" <peyton.b(at)sbcglobal.net (peyton.b(at)sbcglobal.net)>
WA0SYV
le, List Admin.
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
PostPosted: Sun Jan 13, 2013 2:09 pm    Post subject: Cable runs Reply with quote
Yes, two did it.
On Jan 13, 2013, at 3:12 PM, Sean Stephens <sean(at)stephensville.com> wrote:
> Bill
> WA0SYV
schmoboy
PostPosted: Sun Jan 13, 2013 2:35 pm    Post subject: Cable runs Reply with quote
Thanks everyone. That's what I figured, but wanted to confirm.
-Sean
<mailto:sean(at)stephensville.com>> wrote:
<sean(at)stephensville.com <mailto:sean(at)stephensville.com>>
<peyton.b(at)sbcglobal.net <mailto:peyton.b(at)sbcglobal.net>>
adel clamps...
WA0SYV
le, List Admin.
