Cowl Replacement Update
robin(at)PaintTheWeb.com
PostPosted: Thu Jan 10, 2013 12:13 pm    Post subject: Cowl Replacement Update Reply with quote
We are close to flying the replacement cowl. I wanted to share a few photos of the new cowl, baffles, oil cooler location including bracket. intake etc…
Robin
Can't you see the air molicules woooshing by the cowl?
I like having only 2 inlet holes.
Engine looks pretty clean for 325+ hours.
Double Induction, double filter system. No Alt Air so yet.
Nifty oil cooler bracket
 Filesize:  43.66 KB
 Viewed:  13921 Time(s)
 Filesize:  56.54 KB
 Filesize:  59.58 KB
 Filesize:  66.28 KB
 Filesize:  66.44 KB
 Filesize:  81.99 KB
Strasnuts
PostPosted: Thu Jan 10, 2013 12:26 pm    Post subject: Cowl Replacement Update Reply with quote
Very cool! Excited to hear how she works in flight.
On Jan 10, 2013, at 13:13, Robin Marks <robin(at)PaintTheWeb.com (robin(at)PaintTheWeb.com)> wrote:
[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
Robin
<image013.jpg>
<image014.jpg>
<image015.jpg>
<image016.jpg>
<image017.jpg>
<image018.jpg>
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
recapen(at)earthlink.net
PostPosted: Thu Jan 10, 2013 1:07 pm    Post subject: Cowl Replacement Update Reply with quote
Is this a new SJ RV10 cowl? I don't see it on their website....
Would like to see a front view of the dual fiberglass intake runners.
Guessing you're not using a plenum.....
rv10flyer(at)live.com
PostPosted: Thu Jan 10, 2013 1:12 pm    Post subject: Cowl Replacement Update Reply with quote
you pull that cowling off a legacy? even with that supercharged engine I don’t think the cowling is going to give you the speed of a Lancair.. sorry to disappoint [img]cid:48F5555A16A74EED8A7CC5E700EABE4F(at)pascalPC[/img]
Very nice fit and engine
Sent: Thursday, January 10, 2013 12:13 PM
Subject: Cowl Replacement Update
Robin
[img]cid:592A650C217B4145B55974BB28406AB8(at)pascalPC[/img]
[img]cid:2585F0E1D0334DCEAD427FA82EC8F9BB(at)pascalPC[/img]
[img]cid:FA573B9F8A674D7B8DE900642EDB2D86(at)pascalPC[/img]
[img]cid:413398A0A0DD4D4A9A726C8BF4CCC68A(at)pascalPC[/img]
[img]cid:A938198C956D4B059E4ADC863BF4E862(at)pascalPC[/img]
[img]cid:798FC876455C428087A8AF96C97AF97D(at)pascalPC[/img]
 Filesize:  1.1 KB
 Viewed:  13916 Time(s)
 Filesize:  43.66 KB
 Filesize:  56.54 KB
 Filesize:  59.58 KB
 Filesize:  66.28 KB
 Filesize:  66.44 KB
 Filesize:  81.99 KB
PostPosted: Thu Jan 10, 2013 2:01 pm    Post subject: Cowl Replacement Update Reply with quote
Ralph,
This cowl replaces the SJ cowl and plenum. Adios!
This is the new Showplanes and intake system for the FM300. No Plenum for me ever again.
If one were to visit the Showplane website you can see the induction system from the front view. Basically the bottom quarter of each inlet is dedicated to the FI induction system.
Robin
PostPosted: Thu Jan 10, 2013 2:06 pm    Post subject: Cowl Replacement Update Reply with quote
Thanks!
wgreenley
PostPosted: Thu Jan 10, 2013 2:25 pm    Post subject: Cowl Replacement Update Reply with quote
9-12 months from needing to order a cowl. This is a new area for me, what is
the reason for using the showplanes cowl over vans regular cowl?
Bill Greenley
RV-10 builder
Bob Turner
PostPosted: Thu Jan 10, 2013 3:02 pm    Post subject: Re: Cowl Replacement Update Reply with quote
Do you plan to stuff some insulation between the induction air and the #1 exhaust?
Bob Turner
RV-10 QB
PostPosted: Thu Jan 10, 2013 3:14 pm    Post subject: Cowl Replacement Update Reply with quote
I originally placed the SJ cowl on the -10 based on the 2 place RV fleet history with the SJ unit. I was probably the 3rd -10 SJ cowl flying. Unfortunately the SJ -10 cowl well documented problems meant that I needed to replace the cowl on my flying -10. The smart move would have been to go with the proven factory cowl. It does everything you need it to do and there are 350 other -10 pilots you can have something in common with when installing the Vans cowl. When my 8A came on line it was time to replace the -10 cowl. I opted for the new cowl even though I will most likely be the first flying production Showplanes -10 cowl because the builder has a long history of RV aftermarket product development and I had been in discussions with Bryan for about 2 years tracking his progress. He is extremely methodical in his development approach vs. just blowing up a smaller cowl and plenum hoping it works. My prior cowl & plenum were sold as a set intended to be used together but even a basic measurement like the inlet holes weren't aligned. That should have been a warning to me but I already had started the assembly. Bryan on the other hand had done so much R&D and his goal was to develop a "no compromises" cowl. A cowl that can fly with the standard Vans oil cooler on the wedge with no added louvers and cobbled together solutions required. When it came time I decided to support a builder & designer that gave great care in his development. I can say the quality of fiberglass far exceeds anything ever shipped from Vans.
Long story / short. The smartest solution would have been the Standard Vans cowl and it will remain so for most builders. But this cowl is great looking and works with the FM200 & FM300 so I am giving it a try. That is why I fly in the Experimental category for gosh sakes. Of course the first 325 hours I flew in the Disgruntled category but hopefully this new cowl will resolve those issues. The rest of the plane is a dream to own & fly.
Robin
RV-4 Sold
RV-6A Sold
RV-10 Flying
RV-8A Flying
PostPosted: Thu Jan 10, 2013 3:15 pm    Post subject: Cowl Replacement Update Reply with quote
Yes. It's tight up there.
R
jchang10
PostPosted: Thu Jan 10, 2013 6:36 pm    Post subject: Cowl Replacement Update Reply with quote
Robin... Wow, pretty cool. I think i spoke with Bryan at Independence
last year. He and the owner were showing the RV-10 prototype just back
from the painter. Unfortunately, they didn't make it in time for
Oshkosh. However, their -10 was probably the most modified -10 i have
ever seen or heard of yet. I had never heard of Showplanes before, so i
was quite surprised to see so many great mods i had never heard of. I
could have easily spent another 10 years building if i had known. Wink
Oh well, back to my plain jane airplane. Very Happy
Jae
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
#40533 RV-10
carl.froehlich(at)verizon
PostPosted: Thu Jan 10, 2013 7:40 pm    Post subject: Cowl Replacement Update Reply with quote
Just to offer another opinion on the James Cowl and plenum...
I'm running a stock IO-540 from Van's with the Hartzell BA prop, a single
oil cooler (but not mounted like Van's suggests) and bottom cowl louvers
about the same area size as specified for the stock Van's cowl. I do not
have oil temp problems and control CHTs below 400 degrees. Comparing my
cruise and top speeds to Van's performance specifications I am enjoying
measurable gains (data run taken before recent rigging tweaks yielded 187kts
TAS, 6500', 2500 RPM, 23.3"MP - about 73% power). Tracking this discussion
on the list for a few years now it seems I have a much later cowl than Robin
as I did not have plenum alignment problems and started off with the larger
inlet rings.
The James Cowl is not magic. It offers reduced drag over the Van's cowl by
a smaller inlet area but (theoretically) more efficient use of the cooling
air that is taken in. The trade off is on a hot day I have to put the nose
down a little more on an extended climb (say 135 knots instead of the 120 I
use in my RV-8A). The set up does add significant work over the stock Van's
cowl. I decided to go down this path for the same reason it seems Robin
did; the positive James Cowl track record in 2 place RVs. When I ordered
mine Will James was straight with me on customer reports of heating problems
- and what action he took to address them. This was enough to mitigate my
concerns. The last time I checked however Will no longer offers the RV-10
cowl.
As Robin states the least risk, lowest work option is to stick with the
stock Van's cowl. My decision tree was biased toward fuel efficient cross
country performance. With just 60 hours and only one long cross country, I
am pleased with the results. I've had the plane down for the holidays to
back fit the ADSB receiver and to work the gripe list but this weekend it
comes back out of the hangar. It's a shame the day job keeps getting in the
way of flying.
Carl
 Filesize:  465.26 KB
 Viewed:  13892 Time(s)
PostPosted: Fri Jan 11, 2013 10:37 am    Post subject: Cowl Replacement Update Reply with quote
Carl,
I would not necessarily dispute your observations. I just can’t consistently keep my cylinders under 400 F and I fly in CA often out of the San Fernando Valley. Just no way to fly the plane and not feel you are reducing the engine life at those temps. Plus I could not fly LOP with the SJ cowl which would have given my CHT's a rest for the bulk of each leg. The thought of landing at temp and a quick turnaround with a heat soaked engine makes me groan for my Barrett special. I figured I could pay now or pay later. In general while 187 TAS at 2,500 RPM sounds good my long term preference is targeting 10 GPH, Low CHT's and an engine that makes it to 2,000 TBO.
Robin
 Filesize:  76.69 KB
 Viewed:  13863 Time(s)
 Filesize:  48.62 KB
Bob Turner
PostPosted: Fri Jan 11, 2013 11:04 am    Post subject: Re: Cowl Replacement Update Reply with quote
How did the cowl affect the ability to fly LOP? Is this the odd air pressure on the injector bleed holes issue?
Bob Turner
RV-10 QB
PostPosted: Fri Jan 11, 2013 11:23 am    Post subject: Cowl Replacement Update Reply with quote
Bob, It's been years since I addressed the issue so I don't want to tell you something that is partially correct but not totally accurate. I have a feeling that some of my temp issues and LOP issues had to do with such a minor difference in top & bottom deck pressure which limited the amount of cooling air passing through the cylinder fins.
I did however swap out my standard injectors to a Turbo Rail type of set up (AFP Products) which helped but never got me balanced all the way to LOP flight w/o a rough running engine. At that point I knew I was a year out from scrapping the cowl all together so no further development was undertaken. Just too many patches & band aids for me. Hopefully v.2.0 will work out better.
Robin
PostPosted: Tue Jan 15, 2013 7:21 pm    Post subject: Cowl Replacement Update Reply with quote
Someone asked to see the front view of the Showplanes cowl to review the FI inlet area.
Here you go!
Robin
 Filesize:  58.97 KB
 Viewed:  13812 Time(s)
 Filesize:  52.49 KB
PostPosted: Wed Jan 16, 2013 4:44 am    Post subject: Cowl Replacement Update Reply with quote
Thanks - I was one of the ones that requested a front-view...
Mauledriver(at)nc.rr.com
PostPosted: Wed Jan 16, 2013 6:37 am    Post subject: Cowl Replacement Update Reply with quote
I didn't ask but thanks. Now I get it. A very different approach with the ram air resulting in a very good looking nose.
Here you go!
Robin
