RV-10 nose gear failure
rv10flyer(at)live.com
PostPosted: Wed Jan 02, 2013 9:29 am    Post subject: RV-10 nose gear failure Reply with quote
http://www.faa.gov/data_research/accident_incident/preliminary_data/media/M_0102_N.txt
rleffler
PostPosted: Wed Jan 02, 2013 10:03 am    Post subject: Re: RV-10 nose gear failure Reply with quote
Looks like Bob Kaufman's RV-10. I don't think Bob participates on the list.
Rick S., are your aware what happened?
bob
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
Tim Olson
PostPosted: Wed Jan 02, 2013 11:07 am    Post subject: RV-10 nose gear failure Reply with quote
I hadn't heard that he was flying....did he just recently
get first flight or has he been flying for a while?
I know he originally was looking at doing a Rotary?, but I
don't know if he ended up doing it or going with the
usual. Sad to hear though, about the nose gear thing,
but very good that there were no fatals on the list of
statistics.
bob
Bob Leffler
N410BL - Paint - 90% done, 90% to go stage
RV-10 #40684
http://forums.matronics.com/viewtopic.php?p=391469#391469
bcondrey
PostPosted: Wed Jan 02, 2013 11:32 am    Post subject: RV-10 nose gear failure Reply with quote
Bob K and I exchanged email a few weeks ago and he said at that point he was getting close.  He changed horses and went with a Lycoming to get it in the air.  I haven't heard from him since...
On Wed, Jan 2, 2013 at 1:06 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
[quote]--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
statistics.
[quote]--> RV10-List message posted by: "rleffler" <rv(at)thelefflers.com (rv(at)thelefflers.com)>
bob
Bob Leffler
RV-10 #40684
============================================SOME FREE Gifts!)
tp://www.aeroelectric.com/" target="_blank">www.aeroelectric.com
    * HomebuiltHELP www.homebuilthelp.com
--> hank you for your generous support!
_======================atronics List Features Navigator to browse
nics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
======================  --> http://forums.matronics.com
PostPosted: Wed Jan 02, 2013 1:03 pm    Post subject: RV-10 nose gear failure Reply with quote
Came across some pictures of the plane. Looks like the front gear ripped off
and there is oil all over the belly, not sure which one came first however.
Not to spread a theory, but my understanding is that the plane did not flare
completely when it contacted the runway, possible pushrod related. Only the
NTSB report and Bob can confirm that.
 Filesize:  1.07 MB
 Viewed:  12064 Time(s)
 Filesize:  1.22 MB
EdKranz
PostPosted: Wed Jan 02, 2013 2:07 pm    Post subject: RV-10 nose gear failure Reply with quote
Purely speculation, but I gotta figure that the oil on the belly was there before the nose gear collapse. There is a good amount of oil, and it's wind blown all the way back to the tail.
On Wed, Jan 2, 2013 at 3:01 PM, Pascal <rv10flyer(at)live.com (rv10flyer(at)live.com)> wrote:
[quote] Came across some pictures of the plane. Looks like the front gear ripped off and there is oil all over the belly, not sure which one came first however.
Not to spread a theory, but my understanding is that the plane did not flare completely when it contacted the runway, possible pushrod related. Only the NTSB report and Bob can confirm that.
Ed Kranz
RV10
Finishing
www.edandcolleen.com
Bajajim
PostPosted: Wed Jan 02, 2013 6:00 pm    Post subject: RV-10 nose gear failure Reply with quote
The Elevator Rod came loose from the control stick Page 39-10.
He lost control (the bolt fell out) about 75 ft off the ground at short
final
(After flying from Reno to Las Vegas....)
Both pilot and passenger walked away...
I was there...
It happened 12-31-12 at North Las Vegas Airport.
cooprv7(at)yahoo.com
PostPosted: Wed Jan 02, 2013 6:18 pm    Post subject: RV-10 nose gear failure Reply with quote
Thanks for the update, eliminates all sorts of random speculations. I think I know what I'll be checking the next time I go to the airport!
Glad to hear everyone was okay, while the timing of the failure sure could have been better…it could have been infinitely worse.
Marcus
final
I was there...
Rick S.
PostPosted: Wed Jan 02, 2013 7:56 pm    Post subject: Re: RV-10 nose gear failure Reply with quote
Jim,
Do you mean the pushrod end that has the self locking nut and safety wire To secure the rod end. Not sure how you saw that flying around the pattern. I suggest you let Bob speak for himself and let the investigation take its course without speculation.
Rick Sked
Rick S.
RV-10
40185
PostPosted: Wed Jan 02, 2013 8:53 pm    Post subject: RV-10 nose gear failure Reply with quote
Bob did tell me the oil on the belly was from the engine break in blow-by.
Not engine related. . Many of us know that there are some steps we
completely missed in the final inspection, it is quick possible something
came loose and if so I hope it will reinforce to the rest of us to make sure
we don't skim through anything. This goes for pre-flight.
I agree, at this point Bob will need to update the group, on the facts,
anything else is a theory. The good news is the plane did it's job and he
and his passenger walked away.
I am fascinated by NTSB reports, there is always something someone can gain
from, sadly, someone elses accident, and hopefully not repeat it oneself. I
received a invite to a webinar Jan 15, Gene Benson does a good job of
reviewing cases and talking about how one can avoid doing the same thing.
http://genebenson.com/call_the_ball/ctb_webinar.html
hope it helps someone as much as his previous presentations have helped me.
Pascal
PostPosted: Thu Jan 03, 2013 6:16 am    Post subject: RV-10 nose gear failure Reply with quote
NTSB reports are indeed a great source of information, especially trends for any type of airplane or condition. However, the initial report is often very vague and must be taken with a grain of salt. I am very well acquainted with one report of an RV-6 where the "nose gear folded back". Apparently the airplane hit so hard the tailwheel moved all the way to the front of the airplane! Wink Yes, I know for a fact it was a taildragger RV-6. It seems that in a lot of cases the NTSB does not file a final report, but when they do it typically is far more detailed and accurate.
Marcus
On Jan 2, 2013, at 11:52 PM, "Pascal" <rv10flyer(at)live.com> wrote:
Bob did tell me the oil on the belly was from the engine break in blow-by. Not engine related. . Many of us know that there are some steps we completely missed in the final inspection, it is quick possible something came loose and if so I hope it will reinforce to the rest of us to make sure we don't skim through anything. This goes for pre-flight.
I agree, at this point Bob will need to update the group, on the facts, anything else is a theory. The good news is the plane did it's job and he and his passenger walked away.
I am fascinated by NTSB reports, there is always something someone can gain from, sadly, someone elses accident, and hopefully not repeat it oneself. I received a invite to a webinar Jan 15, Gene Benson does a good job of reviewing cases and talking about how one can avoid doing the same thing. http://genebenson.com/call_the_ball/ctb_webinar.html
Pascal
Bob Turner
PostPosted: Thu Jan 03, 2013 3:42 pm    Post subject: Re: RV-10 nose gear failure Reply with quote
Preliminary reports: I noticed both reports said "passengers zero, crew two".
Maybe anyone in the front must be a crew member!
Bob Turner
RV-10 QB
