larkrv10(at)gmail.com Guest
Posted: Tue Jan 01, 2013 6:10 pm Post subject: Aeroled wiring |
Hi all
I've started wiring my -10 and am wondering if what I'm proposing is within normal wiring standards.
A shielded 20 ga, 3 conductor wire enters the wing tip near the rear wing spar, goes forward to the leading edge. I'd like to remove about 2" of outer insulation, 3' from the end, pull the shielding away from the 3 wires, solder another wire to the shield and ground to the metal wing rib. The 3' shielded wire then goes to the Aeroled light via a 4 pin connector, with the shielding tieing to the Aeroled base as per installation instructions.
The idea is to ground at the light base and at the outboard wing rib while still having enough wire to set the wing tip on the floor. I guess I could run another ground wire from the light base directly to the ouboard rib, but why not use the shielding as it passes the rib?
Does this configuration seem right?
Thx, Rick
#40956
Southampton, Ont
Posted: Tue Jan 01, 2013 6:50 pm Post subject: Aeroled wiring |
At 08:09 PM 1/1/2013, you wrote:
| Quote: | Hi all
what part number of AEROLED are you using? I'd
like to see the instructions.
Posted: Tue Jan 01, 2013 7:17 pm Post subject: Aeroled wiring |
Bob, a pair of Pulsar NS 90's and the Suntail.
Here's a link to the installation instructions.
http://www.aeroleds.com/LinkClick.aspx?fileticket=VLoy7bgULOw%3d&tabid=6250
I've seen your description on how to add a faston connector to shielding, so I'm basically proposing the same thing, just not at the end of the wire.
Make sense?
Thx, Rick
On Tue, Jan 1, 2013 at 9:49 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
| Quote: | Hi all
om" target="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
Posted: Wed Jan 02, 2013 6:30 am Post subject: Aeroled wiring |
At 09:15 PM 1/1/2013, you wrote:
Their installation drawings don't make sense.
ASSUMING that the installation has been proven
to BENEFIT from shielded wire. Who is the victim,
who is the antagonist and how does this shielding
break the propagation?
SOME led power supplies have proven problematic
for integration into airplanes. One notable product
are the LuxDrive supplies popular with some
DIY position lights installations. We crafted
a filter board for these power supplies to
fix a fundamental shortcoming for use on aircraft.
If the AEROLED product has a similar problem, shielding
the power leads won't fix it. Similarly, if the AEROLED
has some vulnerabilities to on-board transmitters, the
once again, shielded wire wont fix it.
Suggest you ditch the shielding (if the wires are already
in place, use it as a bundled trio and ignore the shields.
Install connectors as convenient to your anticipated
service requirements.
If a noise issue presents itself, let's attack the
problem with the judicious application of filter(s).
Bob . . . [quote][b]
ctbecker
Posted: Wed Jan 02, 2013 7:04 am Post subject: Aeroled wiring |
Thats exactly what I did on my installation and it seems
to work just fine.
Charlie Becker
On Tue, 1 Jan 2013 22:15:59 -0500
Rick Lark <larkrv10(at)gmail.com> wrote:
| Quote: | Bob, a pair of Pulsar NS 90's and the Suntail.
Make sense?
Thx, Rick
nuckolls.bob(at)aeroelectric.com> wrote:
>Nuckolls, III" <
> nuckolls.bob(at)aeroelectric.com**>
>> Hi all
>>proposing is
>>near the rear wing
>>remove about 2" of
>>away from the 3
>>the metal wing rib.
>>a 4 pin connector,
>> installation
>> instructions.
> Bob . . .
Posted: Wed Jan 02, 2013 5:43 pm Post subject: Aeroled wiring |
Bob, I believe the "victim"(s) are coax antenna and associated radios. The "antagonist", I'm not sure. I did speak to Dean at Aeroled, and I remember him talking about these lights not having a capacitor discharge, therfore the noise characteristics were different than "Whelan" type strobes. How the shielding breaks the propagation of noise, I have no idea.
It's going to be months before I will have the strobes and radios powered up, but I'll let you know how I make out. Wiring has been installed, but no connections made. I'm planning to go to Sun & Fun so hopefully the Aeroled people are there and I will have a talk with them again.
Thx, Rick
On Wed, Jan 2, 2013 at 9:30 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Bob . . . | Quote: |
Posted: Wed Jan 02, 2013 6:41 pm Post subject: Aeroled wiring |
At 07:43 PM 1/2/2013, you wrote:
| Quote: | Bob, I believe the "victim"(s) are coax antenna and associated radios. The "antagonist", I'm not sure. I did speak to Dean at Aeroled, and I remember him talking about these lights not having a capacitor discharge, therfore the noise characteristics were different than "Whelan" type strobes. How the shielding breaks the propagation of noise, I have no idea.
Yes, the noise is very different. While
h.v. strobe systems are replete with fast-rise
current/voltage waveforms at the flash rate
of the strobes, the LED supply noise is
an artifact of the switchmode, constant
current power supply typically used to
drive leds.
If the AEROLED product generates noises at
unacceptable levels, it's likely to be
CONDUCTED noise that will propagate right
down the power lines, shielded or not.
Have Dean give me a call any time. My mobile
phone is 316-209-7528. I'd like to explore
his perceptions of noise issues for his product.
I think we can be of service and perhaps save
future customers from jumping unnecessary
hoops.
I'm 99% sure that shielding these wires is
of no value. If there are noise problems to
be addressed, then filters located at the
source are called for.
mikefapex
Posted: Thu Jan 03, 2013 3:33 pm Post subject: Aeroled wiring |
I have the AeroLeds (two of the combined nav light/white strobe units) installed on my trike (Z19 RB). I wired up as per their instructions but they exhibit a small 'three click' noise in my headsets every time they flash. Not very loud but frustrating since all the other electrics work just fine.
I've not had time to do further debugging since early last year/2012 but I tried their suggestions of ferrite wraps. This did not help.
On Wed, Jan 2, 2013 at 7:39 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
drive leds.
phone is [url=tel:316-209-7528]316-209-7528[/url]. I'd like to explore
hoops.
===========-- Mike=======Mike FontenotApex Consulting & Services LLCLakewood, Colorado303 / 731-6645
mikef AT apexconsultingservices DOT com================================
berkut13(at)berkut13.com Guest
Posted: Thu Jan 03, 2013 4:56 pm Post subject: Aeroled wiring |
Did you use the latest wiring diagram off their website? The one that comes with the units is out of date.
-James
Berkut/Race 13
www.berkut13.com
Sent: Thursday, January 03, 2013 5:32 PM
Subject: Re: Aeroled wiring
drive leds.
hoops.
Posted: Thu Jan 03, 2013 6:16 pm Post subject: Aeroled wiring |
At 05:32 PM 1/3/2013, you wrote:
| Quote: | I have the AeroLeds (two of the combined nav light/white strobe units) installed on my trike (Z19 RB). I wired up as per their instructions but they exhibit a small 'three click' noise in my headsets every time they flash. Not very loud but frustrating since all the other electrics work just fine.
I've not had time to do further debugging since early last year/2012 but I tried their suggestions of ferrite wraps. This did not help. |
. . . and I wouldn't expect them to help.
What 'black boxes' are driving the headsets?
Do you have an intercom? Does a radio also
speak to the headsets?
Posted: Fri Jan 04, 2013 6:38 pm Post subject: Aeroled wiring |
Mike, Sorry to hear you've got a problem.
I'm assuming you used the shielded, 3 conductor 20 ga wire that Aeroled recommends? Did you run the wire separately or in wire bundles and/or with any coax antennae cable?
Any help is appreciated.
Regards, Rick
On Thu, Jan 3, 2013 at 6:32 PM, Mike Fontenot <mikefapex(at)gmail.com (mikefapex(at)gmail.com)> wrote:
[quote]I have the AeroLeds (two of the combined nav light/white strobe units) installed on my trike (Z19 RB). I wired up as per their instructions but they exhibit a small 'three click' noise in my headsets every time they flash. Not very loud but frustrating since all the other electrics work just fine.
drive leds.
hoops.
| [b]
mikef(at)apexconsultingse Guest
Posted: Mon Jan 07, 2013 8:31 am Post subject: Aeroled wiring |
| Quote: | >I'm assuming you used the shielded, 3 conductor 20 ga wire that Aeroled recommends?
No, at the time of my installation they simply specified regular 18ga wire. I did install it with a twist the entire length. Like I said, I've just been too busy and unable to address this. When I get the time I will go back and review their latest suggestions.
I would just suggest that people considering LEDs should not assume they will be noise free (because they are LEDs!). I like mine a lot, they are low amp usage, very bright, easy to configure as sync'd lights, but the actual noise-free install is somewhat more complicated than I appreciated. Two+ years ago we were all a bit less educated on this (I certainly was), but it seems these issues are better understood.
On Fri, Jan 4, 2013 at 7:37 PM, Rick Lark <larkrv10(at)gmail.com (larkrv10(at)gmail.com)> wrote:
Regards, Rick
drive leds.
hoops.
Posted: Mon Jan 07, 2013 11:01 am Post subject: Aeroled wiring |
LED lamps are, like their incandescent predecessors are quite noise free. Problem is that they are low voltage (2-4 volt) devices best driven as series parallel arrays by constant current power supplies. The power supplies are POWER OSCILLATORS with high probability of harmonic content that extends into the range of interest for radios. There may also be switching transients generated by wig-wag flashing that propagate mainly on the power supply lines.
Here's the problem. These devices are advertised with claims to having been awarded PMA for use aboard type certificated airplanes. This implies that they've been tested to the legacy electro-magnetic compatability issues common to thousands of other products presently sold into the TC aircraft industry.
When you're jumping the DO-160 EMC hoops, the product is treated as a stand-alone 'black box'. It must meet emissions standards without regard to installation issues. A requirement for shielded power/control wiring or a suggestion for avoiding wire bundles carrying other airframe wires is not allowed.
I've written to AEROLED asking to have some conversation with one or more of their techno-wienies with a goal for understanding more about (1) installation recommendations and (2) noise experiences articulated here on the List.
There's a BIG disconnect here. I'll continue to pursue a better understanding. ASSUMING we discover that AEROLED recommendations for installation are VALID, then the quality of their PMA is in doubt . . . which is really immaterial to our task. It may be that a simple set of filter components located at the power and control terminals of the device will eliminate the noises. In any case, shielded wire or selective routing of wires is a band-aid that admits to less than optimum design of the product.
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Tue Jan 08, 2013 6:35 am Post subject: Re: Aeroled wiring |
Being completely ignorant of the Aeroled system and wiring....
Noise in Electrical Circuits 101:
1) Saving a dollar in pcb design often generates problems that take thousands of dollars to solve in the field. (Hard-won wisdom.)
2) In my opinion, using a two layer PCB in a low-noise design is insane, unless it can be proven that it works as well as a 4-or-more layer board.
3) Sharp-edged signals have their place in extremely small, extremely low-power logic, but not in power supplies beyond what is needed to keep the thermal issues under control and the parts' size and cost manageable.
4) Minimize clock traces and clock trace power, and clock signal edges.
5) Control noise at the source. Always.
Noise in strobes: Whelen designed their venerable strobe units long ago. The strobe energy was stored in caps right at the beefy master-supply-strobe-sync unit. Today, especially for LEDs the strobe energy is best accumulated right at the discharge point (Supercaps?) to reduce noise issues and wiring size. Power to the strobes should be entirely DC with the sync signal generated by any number of simple means that won't generate an audio tick.
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Posted: Tue Jan 08, 2013 10:23 am Post subject: Aeroled wiring |
layer board.
. . . . or has been proven adequate by DO-170/Mil-STD-462
testing.
It's not yet clear as to the nature of the
offending emission. The filter needed for
integrating the Luxdrive products addressed
a poorly managed radio frequency issue. This
spectrum of potential interference IS covered
by DO-160, Paragraph 21.3
The 'tick' cited by several writers is probably
a conducted, fast rise current transient coming
out on the power lines. This is a very low energy
event at an audio rate and with imperceptible
radio frequency components.
DO-160 DOES have a test for SUSCEPTIBILITY to low energy
spikes (used to be called the chattering relay
test . . . in fact, early bench test fixtures did
indeed use a 'buzzing' relay as a noise generator).
But it doesn't speak to kind of noise EMISSION that might
generate the 'tick'. There are LOTS of devices that
generate transients that might 'tick' . . . landing
light turn on, pitot heat turn on, landing gear motor
inrush, etc. Folks tend to ignore these due to their
intermittent, one-time occurrence. But when it happens
continuously in sync with repetitive operations like
wig-wag or strobe, it's another matter.
This is a new condition that has not yet be addressed
by codification . . . the manufacturers of guilty
product would do well to jump on this and fix it
before the bureaucrats decide to step in and help.
rwtalbot
Joined: 13 Jan 2013 Posts: 1 Location: Sydney Australia
Posted: Sun Jan 13, 2013 7:04 pm Post subject: Re: Aeroled wiring |
Bob, forgive me for coming into this thread late. I also have been having issues with an Aeroleds setup in my RV-7A. I used to have the Whelen System 7 that Vans sold, but the powerpack failed and I decided to install these instead.
The noise I have is characterised by:
1.Noticeable dead spot from signals to the rear (at least prior to sorting out a ground as indicated below)
2.Noise on all comm frequencies caused by the NAV lights. It does not break squelch but can be heard when the squelch is disengaged and the navs turned on
3.Reduction in effective range of the Comms over my Whelen System 7. I used to be able to get the ATIS on my home field from 50nm and 7000’. I still can with the aeroleds turned off. If they are on I get nothing until I turn the lights off.
4.I can hear Nav and strobe noise in weak comm signals.
5.Navs + Strobe is even worse
6.The whole setup does not compair favourably to Whelen.
I use my aircraft for IFR/night etc and have over 500 hours in four years or so, so probably fairly aware of how the systems should work.
I spent a few hours in the hanger looking at my Aeroleds on the weekend and some more yesterday. I came to a few conclusions:
1.I have/had wired them as per the instructions.
2.I did find that the tail light was not properly grounded between the case and the black ground wire so I fixed that and it did reduce the noise but still not to where I am happy. (took for a test flight)
3.The wiring scheme suggested by Aeroleds actually looks like it would causes a ground loop between the airframe and the shield (when grounding both ends of the shield) . When connected on the Left wing it reduces the pop from the strobe on right and tail it appears to make no difference.
4.The tail nav is by far the noisiest and virtually impossible to quiet down. I assume because it has a lot more LEDs in it. I reduced noise by disconnecting the ground wire entirely (runs to my aft fuselage bulkhead). This seems to imply that local grounding is required. I may need to look at how I can achieve that with my rudder.
5.The Green (RHS) nav light is the next noisiest, followed by the red one (LHS). Both of these are very quiet in comparison.
6.Shortening the ground lead at the light end is not only impractical it makes little difference.
7.One of these lights causes minimal noise, the combined effect adds up. Worst case is all three plugged in and nav + strobe.
8.Noise can be heard using a portable Airband radio with the squelch disabled. In some cases the lights will break squelch but not often and not with the wiring as per the instructions
9.Noise is still present and can be clearly heard in weak signals (like listening to Sydney Centre on the ground).
10.My tail light gets extremely hot in operation. (burn your hands hot)
I had been of the opinion that the noise was most likely caused by a poorly filtered switch mode power supply injecting noise back into the power system. That coupled with the very fast rise time from the strobes when they are turned on leads to the issues. What surprised me was that with my handheld radio I could easily receive the signal when I placed the antenna near the lights, and also when the antenna was placed near my belly mounted Comm antennas.
Getting the wiring correct seems to virtually eliminate the emitted RFI. You must be very close to the wing light fixtures with the portable antenna. The tail light is worse but noticably better when grounded.
Being IFR I have a few other issues:
What about VOR, MKR, GPS etc?
How much of this noise could cause issues in electronics such as EFIS?
What are these things doing to the airframe ground and could it play havoc with my WX-500 storm scope? I have not noticed any strikes detected but it could perhaps reduce its range or accuracy - especially as the antenna is in the return path from the tail strobe.
What happens when the grounds become ineffective due to corrosion under the screws etc?
Richard
Posted: Mon Jan 14, 2013 8:14 am Post subject: Aeroled wiring |
At 09:04 PM 1/13/2013, you wrote:
--> AeroElectric-List message posted by: "rwtalbot" <richard(at)talbots.net.au>
Richard,
Thanks for the detailed and concise description of your
experience and observations. You've confirmed my skepticism
as to the validity of their DO-160/TSO qualification. Looking
at the installation manual for one of their nav/strobe
combo products we find this wiring diagram:
[img]cid:.0[/img]
This 'smells' . . . If I had proposed a product that REQUIRED
such accommodation by the system integrator/installer, I would
have been summoned to the boss' office for a come-to-jesus-meeting.
More importantly, I'm not sure just how I could take such a product
to the EMC lab for testing with shielded hookup wires. If one places
a conducted emissions probe over a shielded wire, it is EXPECTED
that measured energies will be attenuated with respect to that
which flows on the wires. I'd really like to read their EMC
report. If the system just barely passed conducted EMC emissions
with a shield, what would they have measured without the shield
or at the end of the shield where the wire break out to hook
up to the rest of the airplane?
I've written, observed and/or orchestrated hundreds of DO-160
EMC qualification programs . . . the experiences of List
members combined with AEROLED's published installation
requirements suggests that somebody dropped the ball for
getting this product to market.
Interesting observations. I wonder how they might
have been different in a Glasair or a Pulsar?
The noises you've wrestle with are VHF RF in nature
and probably represent a similar threat to VOR. Not so
much Marker Beacons which are VERY weak receivers
an STRONG signals. GPS . . . dunno . . . like I wrote,
I'd REALLY like to see their EMC lab test report.
Less likely but again, without a the blessing of a
golden test report by a qualified EMC lab, we're not
sure that other manifestations of emitted energy DO
NOT exist.
Good question. Don't know. If ONE aspect of the DO-160
qualification protocols are suspect, we have no basis
for assuming that other protocols are not similarly
compromised.
Gas tight original installation should preclude
drifts of performance with age.
I think these products need to be looked at again
for a second opinion as to the validity of their
TSO.
104.08 KB |
20603 Time(s) |
Mike Whisky
Posted: Sun Jun 29, 2014 2:08 am Post subject: Re: Aeroled wiring |
Continuous noise on COM 1 when nav lights are on.
I have the same issue. My Aeroleds transmit a signal which is picked up on my COM 1 GNS430W but not on the SL30. I wrote to Aeroleds and they replaced the units with a newer version. However I only sent them the wingtip nav/strobe lights and not the nav/strobe taillight. The problem is not audiable on ground with 1000 RPM but appears latest during take-off run.
In order to solve my issue I was wondering if your filters will solve it and where to order them.
_________________ RV-10 builder (flying)
#511 |
Posted: Sun Jun 29, 2014 4:34 am Post subject: Aeroled wiring |
At 05:08 AM 6/29/2014, you wrote:
The filter kit I used to offer was tailored to
a specific power supply that was popularly used
in some DIY LED lighting installations.
http://tinyurl.com/kqfw5pn
It would probably work with other products but
it would be a bit messy . . . and they're
out of production.
If AEROLED was able to fix the wing-tip lights,
why not the tail? They're in the business of
supplying holy-watered products for aircraft.
They, of all folks, should know what it takes
to bring your installation up to minimal design
goals.
Mike Whisky
Posted: Sun Jun 29, 2014 8:53 am Post subject: Re: Aeroled wiring |
Thanks Bob
To be fair I didn't send them the tail light as I was under the assumption that the noise is caused by the wingtip lights. One of Aeroleds suggestion was to install a piece of aluminum in the RV wingtips that covers the back of the installation and route ground wire from that piece to the nearest structure.
I agree that I would expect a product like this to function noise free without having to add this installation.
Michael
#511 |
