wingsdown(at)comcast.net Guest
Posted: Tue Jun 06, 2006 4:06 pm Post subject: Specs |
Thanks. Yes some folks don't realize that the engine actually breathes
quite a lot of air through breather vents. I drained them about ever
other oil change or 50 hours. The more blow- by you have the more that
is accumulated in the separators. Yep, that was the manual control, way
to much work load. Pretty touchy as I am sure you found out.
Rick
Posted: Tue Jun 06, 2006 9:08 pm Post subject: Specs |
Rick,
About when did your Soob break in? What were the
symptoms? Temps, blowby oil accumulated, power?
I heard that about 300 hrs is the magic number. Since
yours was a superior engine, I understand results may
vary.
Kurt S.
--- wingsdown <wingsdown(at)comcast.net> wrote:
| Quote: | Thanks. Yes some folks don't realize that the engine
actually breathes
them about ever
have the more that is accumulated in the separators.
Posted: Tue Jun 06, 2006 9:35 pm Post subject: Specs |
Rick,
Right now it is set so that the primary pump gives its
4-6 psi and the B/U pump comes on when pressure drops
to 3.5 psi for any reason in flight.
Before this setup, I ran one pump in flight, except
T/O and landing, and found the pressure could get down
below 2 psi under high power on one pump.
In neither case could I catch the fuel pressure being
the cause. Not ruled out, but EGT was good for the
entire flight, or not good, and fuel pressure varied
with power, not per flight.
I plan to revamp the fuel system, tank to engine, and
see if I can stumble across a cure. One size larger
tubing too. 1/4th inch ID for the smallest line right
now.
Kurt S.
| Quote: | Are you leaving the fuel pump on all the time? If
you are not seeing 5
psi all the time that could be a possible problem.
With the pump off you
will see higher EGTs. Has that been your experience
as well.
Rick
Posted: Wed Jun 07, 2006 4:49 pm Post subject: Specs |
Boy 1/4 sure seems small. Did you do a flow test. Under full power you
can flow as much as 16.5 GPH maybe more. With that 1/4 line I could see
how you might have pressure but lack adequate volume/ flow. Minimum
would be 3/8 to my thinking.
Rick
janderson412(at)hotmail.c Guest
Posted: Wed Jun 07, 2006 6:58 pm Post subject: Specs |
This is new news to me Rick, you saying that the stock soob turbo valves not
good? I have the stock (original) valve gear still fitted?? John
Subject: RE: Specs
Date: Wed, 7 Jun 2006 18:37:37 -0700
Well we can not count all the stock exhaust cross over failures until we
got the new SS set. I think I had just the right number of fingers
though. 350 hours seems about right, and it was an exhaust valve that
snapped just below the scallop number 3 cylinder. That was stock
components. SS with bronze guides is the only way to go for the boost
folks. If I were doing another set of heads I would coat at least coat
the exhaust runners and ports with Swain coating. The beat would be a
complete coating of the combustion chamber in the heads and all exposed
aluminum. I did the SS valve crowns as well.
OK misread the whole dang post.
Compression was good from the get go and only improved marginally over
time. I don't remember the numbers but I want to say 140 all around. No
real blow by on new engine. I wish I had kept better notes. I also had
the block, rings and pistons cryogenic treated so who knows. I was
really looking forward to a 3000hr TBO
Rick
Posted: Wed Jun 07, 2006 8:11 pm Post subject: Specs |
Just what I believe to be true. Stock valves are just that stock steel
valves. Our application subjects them to IMHO abnormal stresses. I have
by no means done any subjective test nor do I have reams of research to
document anything. Just based on my observations, personal, observed and
read. What's great about this media we exchange ideas, thoughts and
experiences in is the collective wisdom or at least red flags that are
raised. If I built another engine these things I would do.
Rick
Posted: Wed Jun 07, 2006 9:55 pm Post subject: Specs |
Good info anyway Rick,
You are way ahead of the rest of us on Soob Nuke
hardening.
Correcting my oil blowing breather, I capped the old
one off and ran a large ID, long, clear line from it
to my new breather, which I put on the right seat.
(That probably hasn't been done too often) Flew that
for a while and watched the engine breath.
Interesting! Not exactly what I expected. The engine
was tight and had only a slow migration of oil mist to
the collector. The white oily air wafted out the
filter and drifted around the cockpit showing very
little blowby. I suppose there was a lot more air
exchange left-right-left-right going on thru the old
breather and the pan.
Other lessons from the test were that I have few air
leaks in the cockpit, even though I didn't drop down
the curved up corners on my canopy. You are going to
get an oily mist blowing around under your cowl. And
don't mention "smoke in the cockpit" on Unicom where
someone who doesn't understand might hear it!
Casually mentioned "only light smoke in the cockpit"
to my ground support, as someone else ran out to
prepare the runway at another airport. Last
lesson, good range on my radio.....
My SS exhaust was not done well and I sent it back for
fixing. The left exhaust was welded over a hole in
the crossover about 1/2 the size of the pipe and I
thought it would flow badly. Also the tap for my
Fuel/Air ratio probe ran right into the turbo-out pipe
and was unusable. I asked them to open the exhaust
hole and rotate the probe tap 30 degrees. They
improved the hole, but rotated the tap 70 degrees on
the next try, right into the engine head.
I gave up and fixed it myself. The clincher was that
they threw a bag of nuts in with the second attempt.
I am from Wisconsin like the welder, but still didn't
like the humor in that. Not good customer relations,
especially since I was very kind to them. For the
$700 it eventually cost, I wanted a quality part.
Rick, did you smooth out the intake/exhaust ports for
better flow before coating?
I haven't had mine apart much, but did see that the
case was in raw form with jagged holes around the
pushrods from the casting. I suspect that the engine
could be spiffied up some, be a pound lighter and
breath a little easier.
Kurt S. S-5/NSI turbo
| Quote: | Well we can not count all the stock exhaust cross
number of fingers
exhaust valve that
That was stock
go for the boost
coat at least coat
The beat would be a
140 all around. No
notes. I also had
who knows. I was
Rick
Posted: Wed Jun 07, 2006 10:26 pm Post subject: Specs |
Rick,
| Quote: | Boy 1/4 sure seems small. Did you do a flow test.
volume/ flow. Minimum would be 3/8 to my thinking.
Rick
Yes, I checked it gravity and with each pump. Got the
exact results somewhere because I was trying to
calibrate the FF gauge too. Could only gravity flow
for the FF gauge to keep it on scale.
Had plenty of gravity for cruise (I think 7-8 GPH
static (no tank ram pressure) and off the meter with a
pump on. I forget the pump rates when I timed them.
I timed for 1 and 5 gallons each test and it seemed
plenty. Must have done 10 tests or more.
In fact, my engine kept running in cruise with both
pumps off and the valve blown out my gascolator, when
flying down here. It had a little boost from the tank
vents, so it showed about 8 to 8.5 GPH with an
estimated 3 GPH of that blowing out the gascolator in
flight.
I thought the engine had to be sucking some air with
the fuel in the gascolator like that, but it ran, and
luckily it was one of those times where it was running
normally richer. At full enrichment I could still
keep 1450 EGT, no pumps and dumping! But at 3200
rpm....
And it runs rich, 1300-1350 EGT's at full power. But
left full rich, it can hit 1550 at 4000 rpm.
I suspect I damaged the carb at the start with
overpressure, or unknownly buying fuel with alcohol
early on. It is the only thing I can think of.
Still, I am going to larger lines.
Kurt S.
Posted: Thu Jun 08, 2006 12:30 am Post subject: Specs |
Yes Rick, I agree re the great benefit from exchange of good ideas and more
so red flags. The valve that let go (on your engine?), was it an original or
replacement? I reused the original valves in my engine as they looked
perfect and it was a low mileage engine. John
Subject: RE: Specs
Date: Wed, 7 Jun 2006 21:11:23 -0700
Rick
Posted: Thu Jun 08, 2006 5:18 pm Post subject: Specs |
No I did not. If I had the non-turbo maybe, but without a flow bench it
would be a magic act. Flow through the heads with the turbo is not a
major problem at the RPMs we run. The coating is for thermal protection
of the aluminum.
Rick
Posted: Thu Jun 08, 2006 5:25 pm Post subject: Specs |
Original stock valve. Not sure if one can see hardening or fatigue
caused by temperature cycling. There is a fancy name for it, but I must
be getting old.
Rick
Posted: Thu Jun 08, 2006 6:13 pm Post subject: Specs |
Did the engine loose power/miss before it went? I had a valve head pop on a
1600 VW (Beetle) and every time I checked the valve clearance it was tight.
Silly me didn't twig!! Perhaps with hyd lifters it wouldn't show?? John
Subject: RE: Specs
Date: Thu, 8 Jun 2006 18:25:04 -0700
be getting old.
Rick
Did the engine loose power/miss before it went? I had a valve head pop on a 1600 VW (Beetle) and every time I checked the valve clearance it was tight. Silly me didn't twig!! Perhaps with hyd lifters it wouldn't show?? John
Subject: RE: Specs
--> Kitfox-List message posted by: "wingsdown" <wingsdown(at)comcast.net>
be getting old.
Rick
Posted: Thu Jun 08, 2006 6:32 pm Post subject: Specs |
I was fortunate in the fact that the head of the valve and seat shut the
turbo down. Had it not I think the engine might have been torn from the
mounts. No, just a LOUD rump sound and mysterious puff of smoke followed
by silence, a slide slip, flair, and roll out on the last taxi way. It
was kind of cool, expensive , but hey you cant buy rides like that.
:)And then the opportunity to build something else as an added bonus.
Rick
Posted: Thu Jun 08, 2006 8:34 pm Post subject: Specs |
Luuuuuky Rick!!!
To:
Subject: RE: Specs
Date: Thu, 8 Jun 2006 19:30:03 -0700
Rick
Posted: Thu Jun 08, 2006 9:21 pm Post subject: Specs |
I have rebuilt engines, but never modified them for
racing, etc, so I am no expert at it. Well, once I
did soup up a VW exhaust, ignition, and intake filter
to get another 3 hp or so out of it..... Still lost 5
knots when I went to high beam.
kurt S.
| Quote: | Rick, did you smooth out the intake/exhaust ports
for better flow before coating?
the turbo is not a
thermal protection
of the aluminum.
Rick
Posted: Thu Jun 08, 2006 10:05 pm Post subject: Specs |
Don't know if it helps, but it can't hurt to have a
clutch allow the prop to freewheel, if the engine
seizes. Don't need the entra prop momentum helping
rip things apart. Probably only a benefit at low rpm,
but we have one on the NSI package.
My only with the least modified, lowest powered
turbo Soob on the list.
Kurt S.
--- John Anderson <janderson412(at)hotmail.com> wrote:
Luuuuuky Rick!!!
