New rocker bushing material - possible issue
andysilvester
PostPosted: Wed Nov 03, 2010 10:49 am    Post subject: New rocker bushing material - possible issue Reply with quote
Received from Jabiru recently, this is news that they changed the bearing material for the rockers. However, some are reporting issues when this new material is used on the 'old' rocker lubrication system. Here's it is, for general information and awareness (if in doubt, call your Jabiru dealer):
Dear Jabiru Dealers and Maintenance Organisations,
We have recently introduced a new type of valve rocker bush material, as shown in the attached photos. This material has been used in South Africa for some time with no problems but we have found several cases in Australia where the yellow bush material degraded very quickly in service – within the first hours of operation. All the issues so far have been in hydraulic lifter type engines using the old rocker lubrication system – i.e. hydraulic lifter engines with an external oil feed pipe from the crankcase to the cylinder head and solid lifter types.
Engines where the oil feed for the rockers is carried by hollow pushrods are not affected.
There are no production engines of this configuration so at the moment this alert does not affect new production engines.
If you have fitted any of these type bushes to any engine with an external oil feed pipe please have the engine inspected and let us know if there are any issues. The inspection can be carried out by removing the rocker covers and checking the rockers for slop or for any yellow residue. We are also interested to hear if everything is fine, so please tell us how many engines you have checked and what the inspections found.
While the investigation is happening these bushes must not be fitted to any engine with an external oil feed pipe. If you need any of the old type bushes in a hurry in the meantime please let us know.
Thank you,
Doug Smith
Engineer, Jabiru Aircraft
The pics attached show the new material (I admit to looking at my calendar to see if it was April 1st). I know I'm 'old-school', but what's wrong with sintered bronze (oilite) for this job? Swiss cheese, anyone?
C'mon Lynn, I bet you have a comment.....!
Cheers, Andy
 Filesize:  75 KB
 Viewed:  18733 Time(s)
 Filesize:  88.21 KB
pete(at)usjabiru.com
PostPosted: Wed Nov 03, 2010 11:34 am    Post subject: New rocker bushing material - possible issue Reply with quote
Let's be clear here - - these rocker bushes have only been retrofitted to some existing engines and no one buying a new engine will not be getting rockers fitted with the new material.
Pete
rickofudall
PostPosted: Wed Nov 03, 2010 1:07 pm    Post subject: New rocker bushing material - possible issue Reply with quote
.."no one buying a new engine will not be getting rockers fitted with the
new material."
Huh?
Rick Girard
Pete
plus2s
PostPosted: Wed Nov 03, 2010 3:11 pm    Post subject: New rocker bushing material - possible issue Reply with quote
That's American for "all new engines have the new material"
--- On Thu, 4/11/10, Richard Girard <aslsa.rng(at)gmail.com> wrote:
[quote] From: Richard Girard <aslsa.rng(at)gmail.com>
Subject: Re: New rocker bushing material - possible issue
To: jabiruengine-list(at)matronics.com
Date: Thursday, 4, November, 2010, 10:04 AM
..."no one
the new material."
Huh?
Rick Girard
wrote:
Krotje" <pete(at)usjabiru.com>
material.
Pete
Lynn Matteson
PostPosted: Thu Nov 04, 2010 4:45 am    Post subject: New rocker bushing material - possible issue Reply with quote
As Newman said to the cops when they showed up at his door...."What
took you so long?" (Seinfeld episode)
I typed the above before I looked at the pictures. After seeing the
pictures, I can only say....What the (bleep)???
I guess this proves that the Australian mice/rats are bigger than the
African mice/rats. Smile
Yeah, Andy, my (home-serviced) replacement bushings have been working
just fine for over 800 hours now, in my antiquated external oil feed
and solid-lifter engine. There are times when engineers should just
use what has worked for years and years (plain old metal bushing
material) and NOT try space-age materials that perhaps haven't been
proven in the application.
Lynn Matteson
Jabiru 2200, #2062
Sensenich 62"x46" Wood (summer)
Rotec TBI-40 injection
Status: flying...1065 hrs (since 3-27-2006)
On Nov 3, 2010, at 2:49 PM, andysilvester wrote:
<andy(at)cimaer.com.br>
know.
Thank you,
Doug Smith
cheese, anyone?
Cheers, Andy
http://forums.matronics.com/viewtopic.php?p=318059#318059
http://forums.matronics.com//files/jab_new_rocker_bushing_2_134.jpg
http://forums.matronics.com//files/jab_new_rocker_bushing_1_637.jpg
Lynn
Kitfox IV-Jabiru 2200
N369LM
PostPosted: Thu Nov 04, 2010 5:36 am    Post subject: New rocker bushing material - possible issue Reply with quote
Let me rephrase – no one buying a new engine will be getting rockers fitted with the new material
Pete
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Richard Girard
Sent: Wednesday, November 03, 2010 4:05 PM
..."no one buying a new engine will not be getting rockers fitted with the new material."
Huh?
Rick Girard
On Wed, Nov 3, 2010 at 2:28 PM, Pete Krotje <pete(at)usjabiru.com (pete(at)usjabiru.com)> wrote:
--> JabiruEngine-List message posted by: "Pete Krotje" <pete(at)usjabiru.com (pete(at)usjabiru.com)>
Pete
andysilvester
PostPosted: Thu Nov 04, 2010 8:19 am    Post subject: Re: New rocker bushing material - possible issue Reply with quote
That’s not what the notice says, Pete, unless Doug at Jabiru has changed his mind and told you but no-one else.
The notice draws attention to using the new bushing material with externally-fed rocker lubrication; this seems to be the combination where failures have occurred. He says ‘There are no production engines of this configuration so at the moment this alert does not affect new production engines’, but since new production engines are fitted with hollow pushrods, they can (and presumably do) use the new bushing material. Nowhere does he say that they have withdrawn the new yellow material from production engines using hollow pushrods.
Andy
Lynn Matteson
PostPosted: Thu Nov 04, 2010 11:37 am    Post subject: New rocker bushing material - possible issue Reply with quote
Hey Andy/Pete/others-
Do you suppose the folks over at the Yahoo Jabiru group would be
interested in this topic?
Lynn Matteson
Jabiru 2200, #2062
Lynn
N369LM
andysilvester
PostPosted: Thu Nov 04, 2010 12:33 pm    Post subject: Re: New rocker bushing material - possible issue Reply with quote
Yes, Lynn, I think the Yahoo Groupers would be interested but to be honest, the system of linking pictures to text there is cr(at)p. You have to post the pictures in a separate files or pictures section and for me, the whole ease-of-communication and impact for illustrated text is lost.
Also, Pete's made the point adequately that this SHOULD not be an issue that will affect loads of owners, at least as far as we know from Jabiru now. I posted it for technical interest purposes, and to get the pics next to the text is what it's all about. Let's hear it yet again for the Matronics 'web' format.......
Cheers, Andy
Lynn Matteson
PostPosted: Fri Nov 05, 2010 2:41 am    Post subject: New rocker bushing material - possible issue Reply with quote
I'll second the Matronics vote...a much better vehicle for ease of
access, etc....I wish we were all over here, rather than there, or
better yet, both if that need be.
Lynn Matteson
Jabiru 2200, #2062
Cheers, Andy
http://forums.matronics.com/viewtopic.php?p=318159#318159
Lynn
N369LM
dacourtn
PostPosted: Wed Dec 26, 2012 12:38 pm    Post subject: Re: New rocker bushing material - possible issue Reply with quote
Jabiru's disclaimer that this has only occurred on external oiler engines is not true. I have a Jabiru 3300, Serial Number 33A1687. As part of a warranty repair to the heads which included replacing the slow-bleed lifters with quick-bleed lifters, Pete recommended that I also convert to the internal oiler upgrade, which I did. All head work was performed by Jabiru USA. After about six hours of run time I pulled the rocker covers to re-torque the heads and found a lot of bright yellow debris in the heads and oil filter. I called Pete and he told me it was just the ends of the rocker bushings, that that was "NORMAL" and "Wasn't a problem".
Although a little hard to see, this shows the multiple pieces in the oil filter.
 Filesize:  1.36 MB
 Viewed:  16471 Time(s)
These are two of the larger pieces behind the rocker cover.
 Filesize:  1.2 MB
BARRY CHECK 6
PostPosted: Wed Dec 26, 2012 4:10 pm    Post subject: New rocker bushing material - possible issue Reply with quote
NOT A PROBLEM!
Are the particles floating around inside your engine?  <--- Problem.
Can the particles access points such as oil galleys?  <--- Problem
Can the particles wedge themselves between cylinder and rings?  <--- Problem
HELL YEA!   It is a problem.
Get that answer in writing and also have the warranty state it will cover any problems.
On Wed, Dec 26, 2012 at 3:38 PM, dacourtn <dacourtn(at)yahoo.com (dacourtn(at)yahoo.com)> wrote:
[quote]--> JabiruEngine-List message posted by: "dacourtn" <dacourtn(at)yahoo.com (dacourtn(at)yahoo.com)>
http://forums.matronics.com/viewtopic.php?p=390988#390988
http://forums.matronics.com//files/2_from_oil_filter_987.jpg
http://forums.matronics.com//files/1_from_rocker_cover_549.jpg
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
zcrj90(at)yahoo.co.uk
PostPosted: Thu Dec 27, 2012 1:27 am    Post subject: New rocker bushing material - possible issue Reply with quote
Slightly horrified about this one. I recall the Fox having a bushing problem but that was years ago.
Pete is quoted here and elsewhere about 'normal' regarding having debris in the engine. Doesn't sound right maybe he can explain either; he's been misquoted, or why it's OK and where this 'spare' material is coming from and why it's OK.
Is there no end to jabiru's incompetence when it comes to this lovely engine?
Can they not learn a little from previous debacles?
The downward spiral continues, lets hope we don't have any aircraft that are part of the trend.
Best for 13 guys! Clive
Sent: Thursday, 27 December 2012, 0:10
Subject: Re: JabiruEngine-List: Re: New rocker bushing material - possible issue
NOT A PROBLEM!
le, List Admin.
ollow target=_blank>http://www.aeroelectric.com/
/" rel=nofollow target=_blank>http://www.buildersbooks.com/
ofollow target=_blank>http://www.homebuilthelp.com/
llow target=_blank>http://www.matronics.com/contribution
ist" rel=nofollow target=_blank>http://www.matronics.com/Navigator?JabiruEngine-List
et=_blank>http://forums.matronics.com/
zeprep251(at)aol.com
PostPosted: Thu Dec 27, 2012 5:33 am    Post subject: New rocker bushing material - possible issue Reply with quote
These particles can only get to the oil pump screen,no further.Not to be horrified.
PostPosted: Thu Dec 27, 2012 6:15 am    Post subject: New rocker bushing material - possible issue Reply with quote
Not so much the particles but the holes that they left behind....
Sent: Thursday, 27 December 2012, 13:32
Lynn Matteson
PostPosted: Fri Dec 28, 2012 6:05 am    Post subject: New rocker bushing material - possible issue Reply with quote
Because this topic is being posted on Matronics, I can add a photo to
this text (if anybody's interested) to show what the "Fox" had for a
rocker bushing problem back in 2007. I replaced the teflon-coated
original bushing material with store-bought bronze bushings, and
haven't had a lick of problems in that area for the last 5 years and
1100+ hours.
In this picture, the teflon coating has been worn away, and the brass/
bronze material underneath is starting to flake away, leaving the
flakes of brassy-colored material to be found in the rocker cavities.
Lynn Matteson
Jabiru 2200, #2062
Prince prop 64 x 30, P-tip
Rotec TBI-40 injection (sleeved to 36mm)
Status: flying with 1406 hrs... (since 3-27-2006)
lovely engine?
 Filesize:  299.5 KB
 Viewed:  16412 Time(s)
Lynn
N369LM
dacourtn
PostPosted: Fri Mar 15, 2013 1:15 pm    Post subject: Re: New rocker bushing material - possible issue Reply with quote
Here is a picture of some of my rocker bushings (all 12 look the same) after only 10 hours of operation. These were installed as part of the internal oiler modification by Jabiru US.
Rocker Bushings With 10 Hours.
 Filesize:  1.21 MB
 Viewed:  16007 Time(s)
