ftyoder(at)yoderbuilt.com Guest
Posted: Tue Dec 18, 2012 5:56 pm Post subject: Cont IO-240B |
OC or anyone,
I am looking for a Brake Horsepower chart showing the max torque load (prop Load?) for the IO-240B. TCM sent me the manual but it doesn't have it included.
Thanks for your help, Tim
sstearns2(at)yahoo.com Guest
Posted: Tue Dec 18, 2012 9:08 pm Post subject: Cont IO-240B |
Hi Tim,
125 HP at 2800 rpm is 234 ft*lbs of torque. My IO-360 was run on a test cell and peak torque and HP both occured at redline rpm. I think you are pretty safe calling 234 ft*lbs max torque for a stock 240.
Scott
On Dec 18, 2012, at 5:56 PM, "F. Tim Yoder" <ftyoder(at)yoderbuilt.com (ftyoder(at)yoderbuilt.com)> wrote:
[quote] OC or anyone,
bakerocb
Posted: Wed Dec 19, 2012 5:02 am Post subject: Cont IO-240B |
12/19/2012
Hello Tim, I have a TCM publication titled “IO-240-B Model Specification”, Original Issue April 21, 1995, Revision May 15, 1996.
In Appendix A, Performance Data, of this publication there is a chart labeled “Full throttle/Propeller Load Curve, 3/30/95 Curve No. 95-005”.
This is actually three charts on one page with Engine Speed (rpm) across the bottom and BSFC, Corrected Brake Horsepower, and Absolute Dry Manifold Pressure, as the three separate vertical vertical data curves given.
No where on this chart, nor in any other portion of this publication, can I find the word “torque”.
I’d be willing to attempt to scan this chart and send it to you (and any others interested) if you think that it would be of use to you. I am curious as to why you want to know this “max torque load” number.
OC
Sent: Tuesday, December 18, 2012 8:56 PM
To: kis-list(at)matronics.com (kis-list(at)matronics.com) ; OC Baker (bakerocb(at)cox.net)
Subject: Cont IO-240B
OC or anyone,
bakerocb
Posted: Wed Dec 26, 2012 5:53 am Post subject: Cont IO-240B |
12/26/2012
Hello Fellow KIS Listers, The below copied email could not be posted by the Matronics KIS List because the type of attachment referred to (rtf) is not permitted.**
I have converted that rtf format to docx (compatible with prior versions of doc) and attached it to this posting email. Please let me know if you have any questions or problems with this posting. Thanks.
OC
**PS: Only the following enclosure types are supported: bmp cdr doc dsf dwg dxf gif
jpg jpeg pdf png txt xls
Sent: Wednesday, December 26, 2012 7:39 AM
To: F. Tim Yoder (ftyoder(at)yoderbuilt.com) ; KIS-LIST MATRONICS (kis-list(at)matronics.com)
Subject: Re: Cont IO-240B
12/26/2012
Hello Tim, Attached is what my computer generated in the way of a scan of the document in question. If this does not work for you please send me your snail mail address and I will make a copy of the document and mail it to you.
My KIS TR-1 prop is a PAC (Prince Aircraft Company) 68 inch diameter, 69 inch pitch, P- Tip prop. See here:
http://princeaircraft.com/TheProp.aspx
I am pretty satisfied with it, 380 hours plus to date. Please let me know if you have any further questions.
OC
'O C' Baker says "The best investment you can make is the effort to gather and understand information."
Sent: Tuesday, December 25, 2012 7:35 PM
To: Owen Baker (bakerocb(at)cox.net)
Hi OC,
I am looking for the Torque vs. rpm curve or table. From 2000 through 2800 rpm to help in selecting a new prop. If you could scan the chart you have I would appreciate it. It sounds like on I have from 1992 for the IO240-A that has "PRELIMINARY" written across it.
I think you mentioned it before but I have forgotten, what prop are you using?
Hope you had a Merry Christmas,
 Download |
| Filename: |
12-26-2012_07;24;52AM.docx |
1.71 MB |
| Downloaded: |
531 Time(s) |
bakerocb
Posted: Mon Dec 31, 2012 5:37 pm Post subject: Cont IO-240B |
12/31/2012
Hello Tim, Here are the results of today’s KIS TR-1 flight:
Altitude MSL: 2,000 feet
OAT: 10 degrees C
WOT RPM: 2,750 to 2,780 depending upon mixture adjustment
WOT KIAS: 145
WOT GPS GROUND SPEED KNOTS: 152
Fuel Flow: 10.5 to 10.9 GPH depending upon mixture adjustment.
The prop is a PAC 68 inch diameter, 69 inch pitch, P-Tip.
OC
Sent: Saturday, December 29, 2012 9:58 PM
OC,
Thank you for the information. Do you think your prop would make it to 2800 rpm at low level?
I appreciate the help.
