schmoboy
Posted: Sat Dec 15, 2012 8:32 am Post subject: Cowl Hinge Pins |
Anyone know a source for the stainless hinge pins besides Vans? I don't
understand why they don't provide enough for the side hinges between the
top and bottom cowl. Page 47-8 says they are available from the
accessories catalog. I'd think they are more than just accessories. I
understand that they weld on a retainer for these "accessories", but one
would think that it would be supplied in the kit.
-Sean #40303
Posted: Sat Dec 15, 2012 1:40 pm Post subject: Cowl Hinge Pins |
Sean,
I purchased hinge pin material from ACS - this may be the right number but
you need to check: MS20253-P2-7200 HINGE PIN SS 03-49000. I see no
advantage to stainless steel over the standard steel pins.
I got (2) 6' lengths as I install the cowl side pins from inside the
cockpit. The pins run through a piece of 1/4" aluminum tubing on the cabin
side of the firewall that acts as a conduit. I took a 3/16" round head
rivet and drilled a 1/16" hole through the center, then countersunk the
shank end, cut off the head, and JB welded the rivet into one end of the
1/4" tubing (countersunk part to the inside so the pin is directed into the
1/16" hole). A 3/16" hole is drilled into the firewall such that the rivet
shank pokes through 1/4" or so, in a spot such that the pin is directed into
the first eyelet on the cowl.
This is really a lot simpler than it sounds. The end result is with a few
AN fittings you have lockable side pins that don't poke through the front of
the cowl.
Carl
schmoboy
Posted: Sat Dec 15, 2012 3:10 pm Post subject: Cowl Hinge Pins |
Thanks Carl.
I assumed it was "required" to replace them with the part mentioned in
the plans, but I am now seeing that is not the case.
I shamelessly stole the pin retainer from Mike
(http://www.azcloudflyer.com/finish/IMG_0298.jpg). And it seems the
pins that come with the hinges will be fine.
-Sean #40303
On 12/15/12 3:39 PM, Carl Froehlich wrote:
Sean,
the cowl.
Carl
Greg McFarlane
Joined: 12 Apr 2012 Posts: 58 Location: Albany Western Australia
Posted: Sun Dec 16, 2012 3:01 am Post subject: Re: Cowl Hinge Pins |
Re conduit for cabin side entry of side cowl hinges, rather than use 1/4 inch ally pipe, if you go to your local auto brake place you'll be able to purchase steel brake pipe that the side pins are a neat fit in. Then it's only a matter of drilling a hole in the firewall and fwd fuse bulkhead F-1002-R that is a neat fit for the steel pipe and lines up with the side cowl hinges, bond with bondo or epoxy. I've kept mine straight just below the vents but you can bend the pipe to any location and the pin will happily follow. Epoxy a rivit into the last forward piano hinge, top or bottom to stop the pin from making friends with your fan. Cheers from Western Australia.
Posted: Mon Dec 17, 2012 12:26 pm Post subject: Cowl Hinge Pins |
You will be very happy that you bought the pins from Van's if you do. The welded on tab makes it much easier to remove the pins and keeps them very securely. Just using an eyelet to hold the tip of the pin is not nearly as nice, IMHO.
YMMV
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On Dec 15, 2012, at 11:32 AM, Sean Stephens <sean(at)stephensville.com> wrote:
Anyone know a source for the stainless hinge pins besides Vans? I don't understand why they don't provide enough for the side hinges between the top and bottom cowl. Page 47-8 says they are available from the accessories catalog. I'd think they are more than just accessories. I understand that they weld on a retainer for these "accessories", but one would think that it would be supplied in the kit.
-Sean #40303
Tim Olson
Posted: Mon Dec 17, 2012 7:16 pm Post subject: Cowl Hinge Pins |
Amen to that Jesse! I had just the hing section for a long long
time, and while it did work, eventually the eyelet widens and the
pin can start to move and then the wear happens faster yet.
I did the JB weld thing for a while to hold it on, and that worked
ok for a while but soon one of them broke free and then I had to
re-glue it. Finally I got ticked off enough that I did it better.
I bought new pins, and a section of stainless hinge, and silver
soldered them together. Yes, Van's does sell a pre-made pin, but
by this point I was irritated and knew I could do a better job
if I took the time. Wish I would have had Van's pins right from
the start. Actually, if I could do it all over again, I'd
make mine look like Sean's where the pins get hidden by an
oval shaped RV-10 logo. That to me trims it out perfectly.
Tim Olson - RV-10 N104CD
On 12/17/2012 2:26 PM, Jesse Saint wrote:
<jesse(at)saintaviation.com>
YMMV
Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C:
352-427-0285 F: 815-377-3694
> kit.
> -Sean #40303
aerosport1
Posted: Tue Dec 18, 2012 1:35 pm Post subject: Cowl Hinge Pins |
Here are the covers Tim was referring to. These are produced by Aerosport
Products.
Geoff Combs
Aerosport
8090 howe industrial pkwy
canal winchester, ohio 43110
614.834.5227p
614.834.5230f
www.aerosportmodeling.com
| Description: |
| Filesize: |
28.75 KB |
| Viewed: |
5306 Time(s) |
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
jdriggs49(at)msn.com Guest
Posted: Tue Dec 18, 2012 10:10 pm Post subject: Cowl Hinge Pins |
Can those be recessed? My buddy left his proud but seems like I've seen pics of them flush???
[quote] From: g.combs@aerosportmodeling.com
To: rv10-list@matronics.com
Subject: RE: RV10-List: Cowl Hinge Pins
Date: Tue, 18 Dec 2012 16:34:01 -0500
Products.
Geoff Combs
Aerosport
614.834.5227p
614.834.5230f
rleffler
Posted: Wed Dec 19, 2012 2:55 am Post subject: Cowl Hinge Pins |
By design they are supposed to be recessed and flushed. Here is a link to the instructions.
http://aerosportproducts.com/Docs/cowlpin.pdf
Sent from my iPad
On Dec 19, 2012, at 1:09 AM, Danny Riggs <jdriggs49(at)msn.com (jdriggs49(at)msn.com)> wrote:
[quote] Can those be recessed? My buddy left his proud but seems like I've seen pics of them flush???
[quote] From: g.combs(at)aerosportmodeling.com (g.combs(at)aerosportmodeling.com)
Subject: RE: Cowl Hinge Pins
Products.
Geoff Combs
Aerosport
614.834.5227p
614.834.5230f
_________________ Bob Leffler
N410BL - Phase I
Posted: Wed Dec 19, 2012 6:29 am Post subject: Cowl Hinge Pins |
Thanks!
Subject: Re: RV10-List: Cowl Hinge Pins
Date: Wed, 19 Dec 2012 05:54:34 -0500
Sent from my iPad
Products.
Geoff Combs
Aerosport
614.834.5227p
614.834.5230f
