Mike Whisky
Posted: Fri Dec 07, 2012 1:28 pm Post subject: Grass runway operation |
Hi,
For those who are flying in and out of grass runways could you please share ground roll for T/O and landing distance at gross weight.
Vans states on there website 500ft/650ft but I guess that's on paved runways.
Has anyone experience how terra grid (50% coverage) of grass runway influences T/O distance.
Michael
_________________ RV-10 builder (flying)
#511 |
cooprv7(at)yahoo.com Guest
Posted: Fri Dec 07, 2012 2:15 pm Post subject: Grass runway operation |
While I don't know the answer to your question, I suspect it is not significantly different given the impressive T/O performance (landing should be the same or better since we don't brake too hard). The biggest consideration operating on grass is the close tolerance between wheel pant and wheel, you might want to do a search of the archives if nobody has any direct comments.
Marcus
40286
On Dec 7, 2012, at 4:28 PM, "Mike Whisky" <rv-10(at)wellenzohn.net> wrote:
Hi,
Michael
RV-10 builder (interior & finishing)
#511
http://forums.matronics.com/viewtopic.php?p=390034#390034
robin(at)PaintTheWeb.com Guest
Posted: Fri Dec 07, 2012 2:53 pm Post subject: Grass runway operation |
Landing on grass is not always same or better. Grass can hold moisture and power braking NOT suggested. Vans posted landing distance includes liberal use of brakes.
Robin
Marcus
40286
Hi,
Michael
#511
n223rv(at)wolflakeairport Guest
Posted: Fri Dec 07, 2012 3:14 pm Post subject: Grass runway operation |
I fly off of grass almost exclusively. While I have never measured actual take off distance at max gross, I can tell you it is significantly reduced when you take off with half flaps.
-Mike Kraus
RV-10 flying
Hi,
Michael
#511
Ron B.
Posted: Fri Dec 07, 2012 3:30 pm Post subject: Re: Grass runway operation |
My strip is 2200' and I'm off in less than half at gross. If it's soft and wet I will use half.
Ron
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Fri Dec 07, 2012 4:58 pm Post subject: Grass runway operation |
Ron, what is your elevation?
On Dec 7, 2012, at 16:30, "Ron B." <ronbelliveau(at)eastlink.ca> wrote:
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
rv10flyer
Posted: Fri Dec 07, 2012 10:52 pm Post subject: Re: Grass runway operation |
The only time I get off on pavement in 500' is solo, full fuel and below 50F at 663' MSL. At gross with the family and 3* flap setting during the hot humid summer we are off around 2,000'. Winter maybe 1,000'. On wet, soggy grass at Triple Tree, SC this summer departing uphill rwy 3, at gross with 18* flaps we were off in 2,000. I usually land at 4* glideslope, 70 kias at gross, touchdown 100-200' past the numbers, don't touch the brakes, roll out 2,000' before turning off at midfield. I raise the nose and let it fly off when it is ready, usually about 65 kts at gross. I hardly use brakes on any landing, even if I have to taxi 500' farther back to the ramp.
_________________ Wayne G. |
Ron B.
Posted: Sat Dec 08, 2012 4:31 pm Post subject: Re: Grass runway operation |
Sean, I'm at 100'.
Mike Whisky
Posted: Tue Dec 11, 2012 12:16 pm Post subject: Re: Grass runway operation |
Great, thank you all.
Now getting to the art of sanding for the paintshop ;.)
Mike
#511 |
