bbradburry(at)bellsouth.n Guest
Posted: Tue Dec 04, 2012 8:45 pm Post subject: Initial amp spike on PTT |
My hangar mate and I checked the current in the wire pulled to ground by the
PTT and found an initial spike of almost 2 amps. This seems excessive to
me. After the initial spike it dropped down to a low number that I don't
currently remember, but close to what I would think is acceptable in the
millamp range.
The radio is a Garmin GNS 430W.
Any comments on this?
Bill B
Posted: Tue Dec 04, 2012 10:00 pm Post subject: Initial amp spike on PTT |
At 10:43 PM 12/4/2012, you wrote:
<bbradburry(at)bellsouth.net>
millamp range.
What is the duration of the spike? The PTT
line coming out of the radio may have some
form of RFI ingress protection that includes
capacitance to ground. Any capacitor rapidly
discharged through the PTT circuit will produce
some large 'inrush' currents but they're typically
very short duration hence low energy.
Posted: Wed Dec 05, 2012 4:51 am Post subject: Initial amp spike on PTT |
Short duration, but long enough to read it on the VOM. Maybe a second??
I have some trim indicators that are connected to this same ground (it is on
my stick) and they dim out when I hit the PTT. I am going to separate the
PTT from them today.
Bill B
Posted: Wed Dec 05, 2012 9:25 am Post subject: Initial amp spike on PTT |
At 06:50 AM 12/5/2012, you wrote:
Wow . . . I'm not sure we have enough data
to craft good hypothesis.
| Quote: | I have some trim indicators that are connected to this same ground (it is on
Hmmmm . . . it would be interesting to
dig into this further. I cannot imagine
why the radio would impose such a stress
on the PTT line . . . take that back . . .
try this one for an "off the wall" notion.
If the PTT current presented by the radio
was limited to that which was necessary
(perhaps a few mA) then PTT switches and
relay contacts NOT characterized for very
low currents tend to gain contact resistance
due to corrosion. Switches designed to switch
significant loads (1A or more) tend to get
'cleaned' with the tiny arc that forms during
each opening of the contacts. A 'power' rated
switch can become flaky with age when loaded
at very low values.
Many upper-crust relays and switches come with
gold plated contacts. As long as the contacts
are never loaded beyond the "low level specs"
the layer of gold preserves contact integrity.
The same device can be used in 'power' control
but the arcing will burn the gold away and
the contact morphs into a 'power only' device.
Some years ago, my employer's receiving inspection
decided that it would be a good deal to 100%
test all incoming, crystal can relays at their
rated loads. Thousands of devices were put into
a fixture and 'tested' at 2A.
Problem is that many of these relays were destined
for jobs as managers of low level signals. The gold
plating was burned away during receiving inspection.
The crippled relays began to fail in large numbers
sometimes years after the airplane was delivered.
It's just possible that some thoughtful designer
at Garmin built a feature into the PTT line that
reduces the need for PTT switches with gold
contacts.
Any chance you could get a 'scope trace of this
current pulse?
Posted: Wed Dec 05, 2012 3:54 pm Post subject: Initial amp spike on PTT |
Bob,
No I have no access to a scope.
As we were checking this problem with keying the mike out today, we found
that the RAC trim indicators were going to one end of the indicators and
dimming out when we keyed the mike. We have checked out the power and
ground wires for these indicators and they seem ok.
I called the Ray Allen Co about this and he suggests that I sounds like an
RF problem, but we fabricated a coax that ran from the radio to the antenna
by going completely outside the plane to insure that we were not getting RF
interference and it did not change the indicators performance.
I keep thinking that someone previously on the list had a problem with the
indicators a year or so ago and possibly found a fix???
B2
