bob.verwey(at)gmail.com Guest
Posted: Tue Dec 04, 2012 12:28 am Post subject: current limiting an alternator |
Listers,
Is it economically and relatively simple to limit charging current from an alternator in a 12v system? The automotive alternators have relatively high initial output and looking at my small electrical loads, I don't see the need for a massive battery...or have I got it all wrong?? <grin>
Bob Verwey
IO470 Bonanza A35 ZU-DLW
V6 Chevy Safari ZU-AJF
Posted: Tue Dec 04, 2012 6:34 am Post subject: current limiting an alternator |
At 02:26 AM 12/4/2012, you wrote:
Listers,
all wrong?? <grin>
While an alternator has the CAPABILITY of delivering
energy at relatively high rates, it can do so only
if the LOAD is willing to accept it based on
VOLTAGE DIFFERENTIALS and total loop resistance.
When you hook an energy consumer across the bus,
the current it requires is relatively constant and
only slightly dependent on bus voltage. But an
energy storage device (battery) may present a
load to the bus that is initially several volts
lower than the bus voltage set point.
Now, you have the POTENTIAL for some serious
currents to flow but even that's limited by the
internal resistance of the battery. Intuitively
one sees a potential hazard to, let us say, a 2 a.h.
SLVA battery being totally discharged and then connected
across a bus capable of delivering 40+ amps
at normal bus voltages. Indeed, the itty-bitty
battery's acceptance will 'spike' on initial
connection but probably no where near 40 amps
and it will fall rapidly. The risk to the battery
is not so much from 'hammering energy into a
chemical conversion'; the greatest potential
for damage is from heating of the internals
as a result of I(squared) x R watts being
dissipated within the small mass. This is
made worse by the fact that the dissipation
is not necessarily spread evenly throughout
the battery's chemistry.
The battery will not necessarily drown
upon experiencing its first 'drink from the
firehose' but a series of such events will
chip away at battery performance and severely
shorten its potential service life.
It would help to know more about your design
goals. What size battery are you wanting to
use? Is this battery going to be your only
source of energy during failure of the boss-
hog alternator? Have you established endurance
goals for alternator-out operations? Aside
from engine cranking, ENDURANCE goals are the
big driver of battery size. Can you give
us more numbers as to size of battery you
want to use and how this battery fits into
your consideration for a comfortable Plan-B
termination of flight after an alternator
failure?
Posted: Tue Dec 04, 2012 8:37 am Post subject: current limiting an alternator |
Hi Bob, As usual, you have put much more thought into your answer than I did into my question!
My craft is powered by a Chevy V6 with a single aftermarket ignition coil, specifically designed for "high vibration environments". My endurance goals for alternator-out operations would be 30 minutes, as I will be strictly day VFR, and with a cruise speed of 100 knots I will have some options.
Electrical loads are the usual ignition system, 2 comms, GPS, landing light, but really the very basics required. No fuel pump, high wing with carb. I had the H35 battery in mind, same as in the Bonanza.
I am not considering an endurance bus.
Bob Verwey
On 4 December 2012 16:33, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Listers,
failure?
om" target="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
Posted: Tue Dec 04, 2012 9:57 am Post subject: current limiting an alternator |
At 10:35 AM 12/4/2012, you wrote:
Hi Bob,
I am not considering an endurance bus. Okay. According to this posting
http://tinyurl.com/cryc6w3
The battery on an H35 is a 12 volt, rated at 29 a.h. for a one-hour rate. At 30 pounds this is not a wimpy device. On the certified airplane, it's paired with at least a 60A alternator. There might have been an larger alternator offered as an option.
Many of our brothers are flying 17 a.h. batteries with alternators of 40 amps or more.
Can you articulate a foundation for your concerns? Even if you don't have an E-bus, consider a battery bus that supplies power for the ignition system. You should be able to fly this airplane with the battery master and alternator switches OFF.
Bob . . . [quote][b]
Posted: Wed Dec 05, 2012 12:38 am Post subject: current limiting an alternator |
Bob, thanks for the insights; my concern was clearly born of ignorance. I will implement the battery bus as suggested.
Best...
Bob Verwey
On 4 December 2012 19:55, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote] At 10:35 AM 12/4/2012, you wrote:
Hi Bob,
Bob . . . | Quote: |
