Low speed takeoffs and stall Airpseed. LRI
ggower_99(at)yahoo.com
PostPosted: Mon Jun 05, 2006 4:14 pm    Post subject: Low speed takeoffs and stall Airpseed. LRI Reply with quote
Hello Paul,
I have mine installed in the 701,   Is a diferent type of airplane that the 601, because the 701 has two diferent angle of attack in the wing.
One without the slots working (normal approach) and another diferent angle of attack in the flare (when the slots beguin to work).
We use our LRI calibrated at normal approach angle of attack for two reasons:
First We fly at diferent altitudes here and diferent sizes of landing strips, so a slow aproach without loosing glide angle/speed  is important.
And second the STOL  flair/approach in the 701 is so slow and close to the ground that sincerely,  there is no time to glance at the LRI.  We just keep the eyes on the strip trough the side of the windshield that instant before touch down...
I am now building a 601  XL  that will also have an LRI installed,   but I am very far from the kit looking as an airplane...
Here is one good article that explains how the LRI works in a "normal" type of wing.  (If there is something close to "normal wing" in modern homebuilt airplanes Smile
In this article is an instalation in a RV6.
Very similar way,  was how it was explained to me by a local bush pilot that has one installed in his airplane and talked me to install one.
http://home.hiwaay.net/~sbuc/journal/liftreserve-pg2.htm
Hope this helps.  Because I am sure that the XL can make impressive short field landings in grass strips if flow correctly...  Time will say (in my case).
Saludos
Gary Gower.
Paul Mulwitz <p.mulwitz(at)worldnet.att.net> wrote:
[quote]--> Zenith-List message posted by: Paul Mulwitz
My Lift Reserve indicator comes up sooner, and I do pay attention to
that, but anyone know of an airspeed indicator that is more
sensitive at the slower speeds?
I have installed a Lift Reserve Indicator in my XL, but I am a long
way from flying. I want to ask you about your experience with this
device. With it working at low speeds, why do you want a low speed
airspeed indicator? Is the LRI sufficient to tell you when to
rotate? Perhaps this is just a matter of having a backup indication.
Paul
XL wings.
do not
PostPosted: Mon Jun 05, 2006 6:03 pm    Post subject: Low speed takeoffs and stall Airpseed. LRI Reply with quote
Hi Gary,
Thank you for the article link on flying the LRI.  I enjoyed reading it and got my ideas about it reinforced.  It sounds to me like a much better instrument to use for critical airspeed control than the airspeed indicator.  Of course you can still use the nose "Picture" on the horizon to control your speed as well, but the LRI sounds like a nice precise way to get nearly maximum performance from your plane on both takeoff and landing.
I understand your comment about not wanting to take your eyes off the runway on landing approach to check the LRI.  There may be several ways to deal with this problem.  Let me suggest a few:
1.  You can set up your approach at the desired LRI indication.  Then look at the pitch on the nose of your plane and hold the same pitch while using the same power/airspeed and flap setting.  This should hold the same LRI indication.
2.  I have seen many AOA indicators - particularly the kind with colored lights - mounted above the instrument panel so the indication is easy to see while looking out the windshield.  You could mount your LRI indicator either on top of the panel or at the top-most position in the center of your viewing image.  This would make it very easy to find the indicator at the critical moments.
3.  If you have already mounted your indicator at a remote location in your instrument panel, you might be able to make an optical path to make it visible from above the panel.  This might be similar to the mirrors used in a "Periscope".  Place one rectangular or oval mirror below the gauge and mount another one above the panel in line with the other mirror.  Then you should be able to see the instrument face while looking out the windshield.
In any case, I am happy I decided to install one of these instruments in my XL.  I think I will put it on the topmost row of instruments - perhaps right next to the EFIS.
Thanks again,
Paul
XL wings (nearly done)
At 05:13 PM 6/5/2006, you wrote:
Hello Paul,
Saludos
Gary Gower.
rdewees(at)mindspring.com
PostPosted: Mon Jun 05, 2006 6:28 pm    Post subject: Low speed takeoffs and stall Airpseed. LRI Reply with quote
Hi Paul and Gary,
I can't speak to the 701 installation of a LRI but have had a LRI in my
601HDS for almost a year and a half. I posted pictures of the probe and
indicator on Scott Laughlin's website and would not fly without it. My
field is short and rough and I found that my landings were unnecessarily
long and fast. Using the LRI I have shortened the takeoff and landing
distance and cut down considerably on wear and tear on the plane and my
nerves. I highly reccomend one.
As far as being too busy to look at one while close to the ground I
found that it's THE most important instrument to look at close to the
ground. I mounted mine above the instrument panel so it's in my line of
sight as I look out the canopy. A few ex-military pilots recognize it
but almost all GA pilots are clueless as to it's function untill they
see it in action. Total cost was less than $80 or so. Only downside is
that the Dwyer differential pressure gauge used on mine as in indicator
is an odd size-- I guess 3 or 3 1/2 inches so it's hard to put in line
with other instruments. I have seen expensive and complex digital
models that illiminate sequential red or green LEDs but I like the
analog needle that gives immediate feedback on wing's lift. I installed
it to let me know when the wing was about to stall so I could land
slower but found that it's just as handy to lift off short in ground
effect and watch the lift available rise to a safe level before rotating
and climbing out Works just as well to give warning of an impending
departure stall or if you do a high speed turn or chandelle it lets you
know what the state of lift remaining is.
If you ever fly with one you won't be without one. Just don't stick it
in a corner where you can't see it easily.
Ron
Gary Gower wrote:
Hello Paul,
wing.
say (in my case).
Saludos
Gary Gower.
jean-paul.roy4(at)tlb.sym
PostPosted: Tue Jun 06, 2006 2:17 am    Post subject: Low speed takeoffs and stall Airpseed. LRI Reply with quote
Hello all. Just one question. Where can this LRI instrument be bought?
Jean-Paul Roy
just received the wing kit
PostPosted: Tue Jun 06, 2006 3:14 am    Post subject: Low speed takeoffs and stall Airpseed. LRI Reply with quote
I built mine from plans available on the net. However, you can also
buy them as complete systems. One source I found from a google search:
http://www.liftreserve.com/Faqinst.htm
Paul
XL wings
zodierocket(at)hsfx.ca
PostPosted: Tue Jun 06, 2006 3:44 am    Post subject: Low speed takeoffs and stall Airpseed. LRI Reply with quote
You can build the LRI from Plans I have on www.ch601.org in the Builder
Resources section. This is an instrument I would never be without.
Mark Townsend Alma, Ontario
Zodiac 601XL C-GOXL, CH701 just started
www.ch601.org / www.ch701.com / www.Osprey2.com
PostPosted: Tue Jun 06, 2006 4:36 am    Post subject: Low speed takeoffs and stall Airpseed. LRI Reply with quote
Thank you kindly Paul
Jean-Paul Roy
Gig Giacona
PostPosted: Tue Jun 06, 2006 5:40 am    Post subject: Re: Low speed takeoffs and stall Airpseed. LRI Reply with quote
I'm a little curious. You've got a Dynon unit right? Is there a reason other than redundancy that you aren't just using the AOA that is part of the unit?
p.mulwitz(at)worldnet.att wrote:
Hi Gary,
Thank you for the article link on flying the LRI.? I enjoyed reading it and got my ideas about it reinforced.? It sounds to me like a much better instrument to use for critical airspeed control than the airspeed indicator.? Of course you can still use the nose "Picture" on the horizon to control your speed as well, but the LRI sounds like a nice precise way to get nearly maximum performance from your plane on both takeoff and landing.
I understand your comment about not wanting to take your eyes off the runway on landing approach to check the LRI.? There may be several ways to deal with this problem.? Let me suggest a few:
1.? You can set up your approach at the desired LRI indication.? Then look at the pitch on the nose of your plane and hold the same pitch while using the same power/airspeed and flap setting.? This should hold the same LRI indication.
2.? I have seen many AOA indicators - particularly the kind with colored lights - mounted above the instrument panel so the indication is easy to see while looking out the windshield.? You could mount your LRI indicator either on top of the panel or at the top-most position in the center of your viewing image.? This would make it very easy to find the indicator at the critical moments.
3.? If you have already mounted your indicator at a remote location in your instrument panel, you might be able to make an optical path to make it visible from above the panel.? This might be similar to the mirrors used in a "Periscope".? Place one rectangular or oval mirror below the gauge and mount another one above the panel in line with the other mirror.? Then you should be able to see the instrument face while looking out the windshield.
In any case, I am happy I decided to install one of these instruments in my XL.? I think I will put it on the topmost row of instruments - perhaps right next to the EFIS.
Thanks again,
Paul
Hello Paul,
We use our LRI calibrated at normal approach angle of attack for two reasons:?
First We fly at diferent altitudes here and diferent sizes of landing strips, so a slow aproach without loosing glide angle/speed? is important.
And second the STOL? flair/approach in the 701 is so slow and close to the ground that sincerely,? there is no time to glance at the LRI.? We just keep the eyes on the strip trough the side of the windshield that instant before touch down...
I am now building a 601? XL? that will also have an LRI installed,?? but I am very far from the kit looking as an airplane...
Here is one good article that explains how the LRI works in a "normal" type of wing.? (If there is something close to "normal wing" in modern homebuilt airplanes Smile?
Hope this helps.? Because I am sure that the XL can make impressive short field landings in grass strips if flow correctly...? Time will say (in my case).
Saludos
Gary Gower.
W.R. "Gig" Giacona
601XL Under Construction
JAPhillipsGA(at)aol.com
PostPosted: Tue Jun 06, 2006 6:38 am    Post subject: Low speed takeoffs and stall Airpseed. LRI Reply with quote
Ron, good to hear from you. I just pulled my DG, vac and all that plumbing from the plane so I have an empty hole in the dash (EHITD) I could fill with an LRI. What kind do you have and how difficult is it to install ? I remember you talking about it when we were flying, but my attention was on your 3300 so I missed some of it. I really don't want to have to take a wing off to install something. Best regards, Bill
PostPosted: Tue Jun 06, 2006 7:47 am    Post subject: Low speed takeoffs and stall Airpseed. LRI Reply with quote
Hi Bill,
I read your post about the device you made to get under the panel.  That's a great accomplishment.  I couldn't find a shoe horn that large so I just squirm in.  I've spent way too much fun on my back with my feet over my head and it wasnt' even an indecent situation!
  I don't remember the source of the plans for my LRI except that I got them from Scott Laughlin.  I will send him an email and ask him to post the link.  He was turning out the probe ends and mentioned that he was set up to do others so I bought one from him for $40.  I think I could make one now tho.  It's made from alumimum bar stock 1/2 X 1 1/2 inches and about 10 inches long.  THere are two holes drilled lengthwise almost all the way thru the bar but edgewise holes from the front are drilled to meet the long holes.  Much like a second pito-static system.  The probe was mounted to a wing rib that forms the inside corner of a baggage locker.  I routed the small plastic tubeing inside the lightening holes of the ribs and up the inside of the fuselage.  There isn't any electicity involved unless you want to put a POST light on the gauge.  I'll look for pix too.
 Ron
 Filesize:  146.45 KB
 Viewed:  519 Time(s)
 Filesize:  213.4 KB
 Viewed:  499 Time(s)
 Filesize:  114.26 KB
 Viewed:  503 Time(s)
 Filesize:  92.15 KB
 Viewed:  525 Time(s)
PostPosted: Tue Jun 06, 2006 7:50 am    Post subject: Low speed takeoffs and stall Airpseed. LRI Reply with quote
Hi Gig,
I don't have a Dynon unit yet. I may choose one, but I am also
seriously considering a Blue Mountain unit.
I built my LRI as a time filler while I was waiting 3 months for my
wing kit. I am glad to learn it is a great instrument. It also has
the quality that it doesn't require power and is unlikely to
fail. That means it could be considered a backup for an EFIS except
for the fact it doesn't really help with anything except takeoff and landing.
As a practical matter, I am planning on only VFR flight. That means
I don't really need any instruments at all. I would like to get an
instrument rating and fly my XL that way, but I can't do that until
the FAA decides the third class medical is no longer needed. I know
they are considering that move, but they want to see how well using a
driver's license as medical qualification works under the Sport Pilot rule.
I think the AOA/LRI indicator should be separate from the EFIS
anyway. It should be very easy to spot at the critical moments
during takeoff and landing approach when it is most useful. I am
afraid the one built into the Dynon unit will be too hard to spot to
be really useful at that point.
If it sounds like I am a little confused on this whole subject then I
have done a really good job of writing about it.
Paul
XL wings
PostPosted: Tue Jun 06, 2006 10:13 am    Post subject: Low speed takeoffs and stall Airpseed. LRI Reply with quote
a baggage locker.
I decided to mount the LRI probe and pitot/static probes on oval
metal plates similar to the one used to access the fuel
strainer. That allows me to remove them while moving the wing around
in my shop so they don't get broken off.
Paul
XL wings
JohnDRead(at)aol.com
PostPosted: Thu Jun 15, 2006 2:24 pm    Post subject: Low speed takeoffs and stall Airpseed. LRI Reply with quote
safe unsubscribe
