Always a slight coolant leak after flight
graeme bird
PostPosted: Wed Nov 28, 2012 9:31 am    Post subject: Always a slight coolant leak after flight Reply with quote
While I am sorting odd bits and bobs; since build I have had a slight coolant leak when the engine cools. I guess the water stops being pumped, the heads are hot and the pressure builds in the pipe from top bottle to port side of radiator and that joint weeps. Why doesnt it flow to the expansion bottle though? I have a silicon down pipe and good clamp but it still does it. Maybe I need a constant torque type clamp. Tempted to put the original black pipe back on.
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
yck.laurens(at)gmail.com
PostPosted: Wed Nov 28, 2012 11:00 am    Post subject: Always a slight coolant leak after flight Reply with quote
I had the same problèm for years, and solved the pb with constant
torque type clamps
yannick LAURENS
F PSCZ
mono 912UL
225 h
Graeme Bird
G-UMPY
Mono 912S/Woodcomp 3000/3W
Newby: 45 hours
g(at)gdbmk.co.uk
http://forums.matronics.com/viewtopic.php?p=389264#389264
raimo.toivio(at)rwm.fi
PostPosted: Thu Nov 29, 2012 9:45 am    Post subject: Always a slight coolant leak after flight Reply with quote
This is with precision same syndrom as I have in my OH-XRT. It has been totally dry and w/o leaks since 2007 until last winter after 5 years I changed all the rubber hoses and pipes and decided to install also those blue silicon hoses. During the last season I have seen after every flight a teaspoon or couple of coolant dropping out (port side). That makes me nervous. All the joints have been tightened several times.
Attached a picture which tells what is happening when the hose (blue silicon) is a bit too near a muffler /silencer. But that´s a different story.
Cheers, Raimo
OH-XRT 340,00 hours & 557 landings and re-rigged for 2012-2013 winter
2012/11/28 graeme bird <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)>
--> Europa-List message posted by: "graeme bird" <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)>
Graeme Bird
G-UMPY
Newby: 45 hours
g(at)gdbmk.co.uk
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
target="_blank">http://www.matronics.com/Navigator?Europa-List
Terveisin,
Raimo Toivio
RWM-SYSTEMS
"älykästä informaatiotekniikkaa vuodesta 1980"
37500 Lempäälä
FINLAND
p. 03 - 3753 777
f. 03 - 3753 100
www.rwm.fi
info(at)rwm.fi (info(at)rwm.fi)
 Filesize:  90.82 KB
 Viewed:  3904 Time(s)
stephan.cassel(at)gmail.c
PostPosted: Fri Nov 30, 2012 12:35 am    Post subject: Always a slight coolant leak after flight Reply with quote
Hi
I am also using the silicon hoses from Stefan Ingemarsson. Very good hoses I may add.
My start to drip at the radiator.
It looks like the inner diameter is a bit, not much, too big. I bought Teflon tape and put some layers (1-1,5 mm or so)  on the both inlet and outlet of the radiator.
The inlet and outlet must be totally dry when applying the Teflon tape. At least for me this stopped the drip completely.
Another thing I have observed is that this type of silicon is vulnerable to heat, especially close to the exhaust system and should be isolated.
Best regards
Stephan
LN-STE
Ivor Phillips
PostPosted: Fri Nov 30, 2012 8:01 am    Post subject: Always a slight coolant leak after flight Reply with quote
I agree with Yannick, I have used silicone hoses since day one with the spring
clamps and never had any kind of leak in five years,
 Also all the hoses are fitted with a reflective
thermal sleeve, exspecially the hose from the pressure cap container to the Radiator
IMHO is a must!
Ivor
G-IVER 914
On 30 November 2012 08:34, stephan cassel <stephan.cassel(at)gmail.com (stephan.cassel(at)gmail.com)> wrote:
Hi
Best regards
Stephan
LN-STE
