3/32 match drilling HS Spar & Spar caps
Mike Whisky
PostPosted: Tue Jun 06, 2006 5:18 am    Post subject: 3/32 match drilling HS Spar & Spar caps Reply with quote
Hello, I just finished the rudder and thanks to all contributers to this
list because my trailing edge came out real nice.
I added a picture series of the rudder construction on my site
www.wellenzohn.net
Here are two questions:
1) How can I remove ProSeal spots from the skin (an easy way pls)
2) The HS construction requires 3/32 match drilling (HS Spar & Spar caps)
these drills didn't come with the Tool Kit I bought and I can't find them
on the tools webstores. Since I reside in Switzerland I wonder if match
drilling with a #40 would also do it. Any suggestions?
Michael Wellenzohn
#40511 (HS)
Zürich,Switzerland
michael(at)wellenzohn.net
www.wellenzohn.net
RV-10 builder (flying)
#511
Rick S.
PostPosted: Tue Jun 06, 2006 5:42 am    Post subject: 3/32 match drilling HS Spar & Spar caps Reply with quote
I have found that you have to let proseal just wear off....when it's still uncured you can use MEK but it is harsh on the skin.
You should be fine using the #40 drill bit or it may be easier to find a 2.35 mm bit in Europe. Either should work fine. The difference in size between a #40 and a 3/32 would be measurable if you were doing precise drilling on a lathe, mill or drill press but using a hand drill in soft aluminum, the error (wobble) factor is greater than the size difference.
Rick S.
40185
Fuse/Finish
Rick S.
RV-10
40185
rvbuilder(at)sausen.net
PostPosted: Tue Jun 06, 2006 5:51 am    Post subject: 3/32 match drilling HS Spar & Spar caps Reply with quote
 Proseal can be cleaned off with MEK relatively easily.  I don't remember the need for a 3/32 drill bit but that would be an "A" size bit.  Probably easier to find it as that than 3/32.
Michael Sausen
RV-10 #352 Working on Fuselage
LloydDR(at)wernerco.com
PostPosted: Tue Jun 06, 2006 7:15 am    Post subject: 3/32 match drilling HS Spar & Spar caps Reply with quote
I have found that Coleman Lantern fuel will clean the proseal spots off,
and it evaps very quickly, with no residue. But use it in a well
ventilated area, it will cause a bad headache! Also it is not as harsh
on your hands or lungs as MEK, and cleans as well. This is what I used
on the tanks of the 7, and it is readily available at discount stores
and outdoor stores.
Dan
RV10E (N289DT)
Fuselage
jdalton77(at)comcast.net
PostPosted: Thu Jun 08, 2006 11:49 am    Post subject: 3/32 match drilling HS Spar & Spar caps Reply with quote
I used a #40 and it was fine.
Jeff
Mike Whisky
PostPosted: Fri Jun 09, 2006 5:30 am    Post subject: Re: 3/32 match drilling HS Spar & Spar caps Reply with quote
Thanks guys for your input! I'll continue drilling with a #40 once my compressor works again, need to fix it (what a waste of time). Will go flying through the swiss alps this weekend (beautiful weather here) pictures will be added soon after on http://www.wellenzohn.net
Rgs
Michael
to not archive
#511
LIKE2LOOP(at)aol.com
PostPosted: Fri Jun 09, 2006 12:10 pm    Post subject: 3/32 match drilling HS Spar & Spar caps Reply with quote
In a message dated 6/9/2006 9:38:32 AM Eastern Standard Time, michael(at)wellenzohn.net writes:
    I found the air drill a pain to use. First there is the cord that seems to hook up on something and then there is that noisy compressor that keeps kicking in. I just purchased a Black and Decker, "firestorm" 14v cordless drill kit. It comes with 2 batteries, and a charger that will charge them both at once if needed.  It also has a drill chuck that pops off and makes it an easy bit driver (important in FLA, since i just installed 93 hurricane panels with a bit driver).  Since i switched to this life is easier... i was using a corded  drill, still easier then the compressor.
Steve
Stephen Blank             RV-10 Builder #40499  -   Cessna 170B flyer
766 SE River Lane
Port St. Lucie, FL 34983           Building the elevators.
772-475-5556 cell - evenings and weekends
jesse(at)itecusa.org
PostPosted: Fri Jun 09, 2006 1:33 pm    Post subject: 3/32 match drilling HS Spar & Spar caps Reply with quote
Are you serious?  You are toting around a heavy cordless drill, worrying about keeping batteries charged, and turning slowly while building an airplane that has about 50,000 holes to drill?  I really hope I am missing something here.  Yeah, the air hose can be a pain, but it is a lot easier than toting around a backpack compressor.  You would have to pry my air drill out of my…well, you know how that goes.
Anyway, I hope you really aren’t building an airplane with a cordless drill.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LIKE2LOOP(at)aol.com
Sent: Friday, June 09, 2006 4:09 PM
Subject: Re: Re: 3/32 match drilling HS Spar & Spar caps
Steve
766 SE River Lane
VHMUM(at)bigpond.com
PostPosted: Fri Jun 09, 2006 2:22 pm    Post subject: 3/32 match drilling HS Spar & Spar caps Reply with quote
most cordless drills will not give the speed needed for drilling alloy! Refer to Vans notes on this.
Chris
PostPosted: Fri Jun 09, 2006 7:02 pm    Post subject: 3/32 match drilling HS Spar & Spar caps Reply with quote
In a message dated 6/9/06 5:38:43 P.M. Eastern Daylight Time, jesse(at)itecusa.org writes:
jhasbrouck(at)woh.rr.com
PostPosted: Sat Jun 10, 2006 5:47 am    Post subject: 3/32 match drilling HS Spar & Spar caps Reply with quote
Geez, I wish I'd have known that my B & D 14V "Firestorm" wouldn't work well.  Just finishing the fuselage with it now.  Personally I think high speed air drills are your enemy not your friend.  Much easier to drill out the occasional bad rivet with a slow turning cordless drill!  My $.02
John
n8vim(at)arrl.net
PostPosted: Sat Jun 10, 2006 10:05 am    Post subject: 3/32 match drilling HS Spar & Spar caps Reply with quote
Yikes.. Flame war over drills?
As a famous engineer once said... "Use the right tool for the right job!"
Air drills work well for drilling aluminium, cordless/hand drills work
well for drilling out rivets, cordless screw drivers work well for
deburring..
As always, your mileage may vary.
-Jim 40384
John
