jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Tue Nov 27, 2012 8:38 am Post subject: Dirty Laundry |
I just wanted to share an issue that we discovered during our annual inspection. This is just a bit embarrassing since we seemed to have potentially solved some issues that we have been having since shortly after we first started flying our airplane (450 hours). But unless we are willing to share our ‘embarrassing’ errors we will not save others from making the same mistake.
As some may know we have struggled to run anything near LOP without the engine ‘stumbling’, we made many modifications to help this situation and made significant improvements, but were never comfortable with the way the engine ran LOP. We blamed this on the James Cowl and Plenum installation; I am not saying our discovery takes the cowl and plenum off the table as contributing factors to LOP issues.
Lately, our CHT temps started rising, and we were unable to climb at altitude without getting the CHT’s above 400. We also noticed a fuel smell on takeoff, I have searched high and low for the source of the fuel smell. Our engine has always idled a little rough; we were told and convinced that this was caused by the fuel vaporizing in the injector lines since we had a tight cowl and plenum.
Then we gained a symptom that lead to discovering our problem. Lately our idle RPM rose to around 1050 – this was the symptom that got me looking for intake leaks. There it was, four of our intake gaskets were obviously leaking. We could see the gaskets were out of place, so I pulled all of the intake tubes and found some amazing gasket placements. The picture below shows one of the gaskets, this is as it came off the engine.
So after replacing the gaskets and performing the ‘rest’ of the annual a test flight was in order. Wow, someone hung a brand new engine! Keep in mind we have only done one test flight, so the data is very limited – but there was noticeable improvement. CHT’s down, no fuel smell, pull the mixture and the engine just sort of looses power without any stumble at all, idle speed down to 650. Also of note, during full power static run-up our fuel flow went from 20.2 GPH to 23.5 GPH.
I have a hard time believing that the engine was assembled with the gaskets out of place, I also have a hard time believing that the gaskets have not been leaking for some time, perhaps even very early on, and obviously getting worse.
There it is – our dirty laundry, hopefully this information is useful to others.
Thanks, Jason
100.13 KB |
4644 Time(s) |
107.14 KB |
4644 Time(s) |
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
Posted: Tue Nov 27, 2012 8:52 am Post subject: Dirty Laundry |
Jason,
Are you fuel injected or carburated?
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On Nov 27, 2012, at 11:38 AM, jkreidler <jason.kreidler(at)regalbeloit.com> wrote:
Thanks, Jason
Jason Kreidler
http://forums.matronics.com/viewtopic.php?p=389123#389123
http://forums.matronics.com//files/photo_2_707.jpg
http://forums.matronics.com//files/photo_1_150.jpg
sean(at)stephensville.com Guest
Posted: Tue Nov 27, 2012 9:03 am Post subject: Dirty Laundry |
I just mounted the engine a few days ago. When reading up on some other
points, I've read of so many issues with the intake gaskets that I will
be pulling my intakes and checking them. I'll be applying a small bit of
Hylomar Universal Blue on them during re-assembly after seeing so many
issues with crumbling intake gaskets.
-Sean #40303 (assembling engine baffling)
On 11/27/12 10:38 AM, jkreidler wrote:
Thanks, Jason
Jason Kreidler
taildragon(at)msn.com Guest
Posted: Tue Nov 27, 2012 9:33 am Post subject: Dirty Laundry |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Jason, maybe I missed it but was your engine new or rebuilt?
jkreidler
Posted: Tue Nov 27, 2012 9:55 am Post subject: Re: Dirty Laundry |
New - Lycoming - Thunderbolt
IO-540-D4A5
260 HP (Std Compression)
Airflow Performance Injection
Dual Mags
Thanks Jason
rv10flyer(at)live.com Guest
Posted: Tue Nov 27, 2012 10:10 am Post subject: Dirty Laundry |
I think you owe it to Lycoming/Thunderbolt to tell them there is a problem
and your thoughts. They need to know this for their own feedback not as a
criticism. Sure, my rebuilt had issues and Americas engine came through each
and everytime for me sent me whatever I need to resolve "setting" breaking
in issues. They were grateful for my feedback is the point and I think
Thunderbolt will too.
Nice job getting this resolved!
Kelly McMullen
Posted: Tue Nov 27, 2012 6:53 pm Post subject: Dirty Laundry |
Keeping your note in mind, I looked at each intake port gasket externally on my new to me engine that arrived this afternoon. All looked good.
On Tue, Nov 27, 2012 at 10:55 AM, jkreidler <jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)> wrote:
[quote]--> RV10-List message posted by: "jkreidler" <jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)>
IO-540-D4A5
Dual Mags
Thanks Jason
Jason Kreidler
http://forums.matronics.com/viewtopic.php?p=389204#389204
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
