byoungplumbing(at)gmail.c Guest
Posted: Mon Nov 19, 2012 7:18 am Post subject: penetrating oil |
ok how long do you have to let it soak to get this kind of results?
boyd young
No Oil used ................... 516 pounds
WD-40 .................... ... 238 pounds
PB Blaster .................... 214 pounds
Liquid Wrench ...............127 pounds
Kano Kroil ................... 106 pounds
ATF*-Acetone mix............53 pounds
The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic
transmission fluid and acetone. Note this "home brew" released bolts
better than any commercial product in this one particular test.
herbgh(at)nctc.com Guest
Posted: Mon Nov 19, 2012 7:25 am Post subject: penetrating oil |
how about marvel mystery oil and acetone?? Herb
At 09:18 AM 11/19/2012, you wrote:
[quote]ok how long do you have to let it soak to get this kind of results?
boyd young
WD-40 ..................... ... 238 pounds
Kano Kroil .................... 106 pounds
ceengland7(at)gmail.com Guest
Posted: Mon Nov 19, 2012 11:15 am Post subject: penetrating oil |
In my case, I really don't remember how long I let them 'soak'. However, I doubt that I waited that long. After all, the Acetone will evaporate fairly quickly. I won't speculate on why it works, but it does work.
Charlie
On 11/19/2012 09:18 AM, b young wrote:
[quote] ok how long do you have to let it soak to get this kind of results?
boyd young
koxxy
Joined: 19 Oct 2011 Posts: 28 Location: Beaverton, OR
Posted: Mon Nov 19, 2012 1:08 pm Post subject: penetrating oil |
Thanks for the tip, Charlie. Most of us will have ATF fluid around (even used should work), but I wonder if fingernail polish remover could sub for acetone?
On Mon, Nov 19, 2012 at 11:16 AM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
[quote] Why? (Just to spend more money??)
On 11/19/2012 09:25 AM, Herb Gayheart wrote:
| Quote: | how about marvel mystery oil and acetone?? Herb
| Quote: | ok how long do you have to let it soak to get this kind of results?
boyd young
_blank">www.aeroelectric.com
tp://forums.matronics.com
Dana
Posted: Mon Nov 19, 2012 1:46 pm Post subject: penetrating oil |
At 04:08 PM 11/19/2012, Martin Koxxy wrote:
| Quote: | | Thanks for the tip, Charlie. Most of us will have ATF fluid around (even used should work), but I wonder if fingernail polish remover could sub for acetone? |
Sure, it'll be a _lovely_ flowery smelling bolt loosener!
Actually, though traditional nail polish remover used to be acetone, I don't think the stuff sold nowadays is always acetone any more.
-Dana
Why did the chicken cross the Mobius strip? To get to the other, er, um....
Posted: Mon Nov 19, 2012 2:48 pm Post subject: penetrating oil |
boyd young
| Just thought the experiment migh show some superior qualities of the Marvey oil....Herb
Richard Pike
Posted: Tue Nov 20, 2012 7:14 am Post subject: Re: penetrating oil |
Just speculating, methinks the acetone works as a very thin solvent that facilitates the lubricant working it's way into the rusted joint. So for the Kolb list: MEK? Wouldn't it work like acetone? All us Kolbers probably still have some, and now that the airplane is built, this might be a use for it.
Worth a try - but don't get it on the paint.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
