rudder trim RV-10
Goto page 1, 2  Next
jrdial(at)hal-pc.org
PostPosted: Sun Nov 11, 2012 9:08 am    Post subject: rudder trim RV-10 Reply with quote
  I have a new RV-10 trim kit from Aerosports Products in the box unopened I will sell for $195.oo, I will pay freight in USA. I built and fly an RV6 and won this in a drawing at an RV Fly-In.
  Contact: jrdial(at)hal-pc.org (jrdial(at)hal-pc.org)
rleffler
PostPosted: Sun Nov 11, 2012 1:10 pm    Post subject: rudder trim RV-10 Reply with quote
Geoff’s rudder trim can be adapted to other model RV’s. Call Geoff for details.
bob
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of J. R. (Dick) Dial
Sent: Sunday, November 11, 2012 12:08 PM
Subject: rudder trim RV-10
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
trigo(at)mail.telepac.pt
PostPosted: Mon Nov 12, 2012 11:04 am    Post subject: rudder trim RV-10 Reply with quote
JR
I am probably interested but I am away from home and I will have to confirm at my shop.
I will contact you direct on Tuesday
Carlos
Enviado do meu iPhone
No dia 11/11/2012, às 17:08, "J. R. (Dick) Dial" <jrdial(at)hal-pc.org (jrdial(at)hal-pc.org)> escreveu:
ctric.com
www.buildersbooks.com
uilthelp.com
matronics.com/contribution
://www.matronics.com/Navigator?RV10-List
cs.com
PostPosted: Mon Nov 12, 2012 2:46 pm    Post subject: rudder trim RV-10 Reply with quote
It has been sold.
Dick
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo
Sent: Sunday, November 11, 2012 11:53 AM
Subject: Re: rudder trim RV-10
JR
Carlos
===================================ctric.com>www.buildersbooks.comuilthelp.commatronics.com/contribution===================================://www.matronics.com/Navigator?RV10-List===================================
ctric.com
ctric.com
ctric.com
ctric.com
ctric.com
ctric.com
5
ctric.com
6
ctric.com
7
ctric.com
8
ctric.com
9
bob88
PostPosted: Fri Dec 06, 2013 7:21 pm    Post subject: Re: rudder trim RV-10 Reply with quote
Anyone have experience with the electric rudder trim kit that is available for the RV10? Is rudder trim important in the 10?
Jim Berry
PostPosted: Fri Dec 06, 2013 7:29 pm    Post subject: Re: rudder trim RV-10 Reply with quote
I have rudder trim in my -10, and like it. That said, I consider it a nice to have feature, not something essential.
rene(at)felker.com
PostPosted: Fri Dec 06, 2013 8:34 pm    Post subject: rudder trim RV-10 Reply with quote
Same here.................
Rene'
N423CF
801-721-6080
rv10flyer(at)live.com
PostPosted: Fri Dec 06, 2013 8:45 pm    Post subject: rudder trim RV-10 Reply with quote
I have a tab on the rudder, ball is pretty much centered in cruise most of
the time. You will need something more than nothing.
Pascal
flying-nut(at)cfl.rr.com
PostPosted: Sat Dec 07, 2013 4:52 am    Post subject: rudder trim RV-10 Reply with quote
I've seen rudder trim tabs hacked out of the rudder, riveted bendable
tabs, big wedges, small wedges ...... but nobody could tell me 'how much
tab do you need?'. So I decided to use small RC servos to implement my
aileron and rudder trim which will drive a hinge segment, controllable
from the stick. I'll probably leave the installation of the hinges
'till after phase 1.
Linn
most of the time. You will need something more than nothing.
Pascal
Mauledriver(at)nc.rr.com
PostPosted: Sat Dec 07, 2013 7:14 am    Post subject: rudder trim RV-10 Reply with quote
No experience here but after 350 hours of flying without rudder trim,
I've decided not to install the trim system because it's not worth the
effort.
I've found that on one hand, I like flying with my feet on the pedals.
It may be a holdover from the Maule. It takes very little pressure to
adjust for climb, cruise and descent. Flying with the AP engaged, the
pedals help keep me engaged.
On the other hand, there is enough friction in the system (and so little
pressure is required) that I can set the right pedal where I need it
and it will stay there in most conditions. I know that people have
simply added some friction or even a temporary stop to the cable to help
accomplish the same thing. That didn't sound right to me before I flew
but makes sense now. Adding a bit of friction to increase the breakout
force would have little or no effect on the operating friction and would
be sufficient for 'setting the trim' in this particular plane.
I do recommend aileron trim and something to slow down the pitch trim
and/or limit its effects (I use Safety Trim).
http://forums.matronics.com/viewtopic.php?p=415035#415035
Jim Berry
PostPosted: Sat Dec 07, 2013 10:20 am    Post subject: Re: rudder trim RV-10 Reply with quote
[quote="flying-nut(at)cfl.rr.com"]nobody could tell me 'how much
Linn
I use a 12" hinge segment as you describe, and it is more than enough. Very small deflections will maintain trim. I think 6" would do the job; maybe even less.
PostPosted: Sat Dec 07, 2013 5:03 pm    Post subject: rudder trim RV-10 Reply with quote
Thanks Jim. I was going to start out with 12" and trim as necessary. I
can adjust the speed of the servo easily so I hope to end up with
smallest added drag and good trim function.
Linn
Linn
http://forums.matronics.com/viewtopic.php?p=415069#415069
Checked by AVG - www.avg.com
johngoodman
PostPosted: Sun Dec 08, 2013 7:56 am    Post subject: Re: rudder trim RV-10 Reply with quote
I used a spring-based rudder trim system. I got it in 2008 from M.L.Skunkworks for $75. I think he is out of business, but there is a company called Aerosport that sells the same thing for $250 Shocked
Regardless, it works great and I rarely have to change it. I don't think the RV-10 needs much rudder trim, unless you have crooked pants....
carl.froehlich(at)verizon
PostPosted: Sun Dec 08, 2013 8:23 am    Post subject: rudder trim RV-10 Reply with quote
Yep - I looked at this and decided that while it is simple and effective, it
is way overpriced. The M.L. Skunkworks version is still listed for $115 -
much more reasonable. http://www.mlblueskunk.com/Rudder_Trim_System.html
After all the rigging tweaks during Phase One I have not found a need for
rudder trim in cruise.
Carl
PostPosted: Sun Dec 08, 2013 8:30 am    Post subject: rudder trim RV-10 Reply with quote
I mentioned the tab, that fellow Don McDonald helped me create and it was
not a big deal. You grab a piece of aluminum, 4" X 2" and you bend it
slightly. Fly and see what happens at cruise. adjust as needed and repeat
flight until ball is centered. If I add up the cost of gas I guess it was
about $75, except I was flying anyway so it was practically free. My ball is
centered than not and I rarely need to adjust it in cruise, John is right
on, once you get the rudder tab tuned in there is very little trim
adjustments needed.
I know Tim Olson went the route of the trim tab to electronic trim, I would
encourage all you debating this to check out his extensive review and steps
to do oneself.
Pascal
aerosport1
PostPosted: Sun Dec 08, 2013 8:31 am    Post subject: rudder trim RV-10 Reply with quote
Aerosport Products rudder trim is a much more refined unit then the
skunkworks.
You get what you pay for with our rudder trim. It might not be for everyone.
If you saw
What goes into making this a quality unit and you may or may not understand.
Geoff
Geoff Combs
Aerosport Products
8090 howe industrial pkwy
canal winchester, ohio 43110
614.834.8659p
www.aerosportproducts.com
 Filesize:  165.76 KB
 Viewed:  16159 Time(s)
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
sean(at)braunandco.com
PostPosted: Sun Dec 08, 2013 11:14 am    Post subject: rudder trim RV-10 Reply with quote
I love my rudder trim form Aerosport. It works perfect and doesn't add
weight to the rudder assembly. As a great by-product it holds the rudder
from being slammed around in winds. Of course you need to put in a gust
lock in strong gusts.
Tim Olson
PostPosted: Mon Dec 09, 2013 8:13 am    Post subject: rudder trim RV-10 Reply with quote
It's always funny to watch this thread pop up, it's almost like someone has
it on their calendar to re-start the debate every 4 or 6 months.
Basically, my thoughts on Rudder trim are these:
First and foremost, rudder trim is not something that is a one-size-fits-all
thing. It is not a NEEDED thing, and it isn't a big safety thing.
There isn't
any reason people HAVE to have rudder trim. I flew something like
285 hours before I had any rudder trim, flying with a wooden block painted
to match and attached and in general it was nearly sufficient.
Nearly.
Everyone flies a different mission, and I fly very little short-hop local
flights. I probably spend over 90% of my flying on longer legs.
Some of them loaded to gross wt. Some light. Some in between.
Airspeeds vary between 150kts and 170kts. It all depends.
In that environment, those first 285 hours had the annoyance of
always requiring a foot on a pedal putting just the right pressure
on to keep in trim. What happens if you are not in trim? Well, it's
worse than just having a constant crab angle....the view out the
window is tilted. To have a nice level horizon, you need to be in trim.
I find it annoying to not be level....because it just isn't right, and
shouldn't be that way. For a short hop you wouldn't even notice
it. But, if you are an X/C flier, it is a pain.
A rudder block, or fixed tab (bendable), would suffice if you almost always
fly the same speeds and weights. It is simple, easy, and as Pascal
did, the bendable tab is about as simple and easy and quick to do as you
can get. For a static tab I think I prefer the wedge block, for
aesthetics,
but once you have it set right, it will fix probably much of your trim
issues. Some of my trips pre-trim were ok. Many of them were not.
It all depended on if I flew LOP, ROP, heavy, or light. It's not wrong to
go that way. For many people, you'll be satisfied.
Then there's the spring-bias trim. Now that there are good choices
out there, I think this is a plenty reasonable alternative for many.
As Sean mentioned, it does give some spring to the rudder to prevent
minor movement in light breeze. It does not at all mean you don't
need a gust lock. It's fairly simple to install, and should do the job
pretty well. Personally, I would recommend that if you go with spring
bias trim, you also do a fixed wedge to correct most of it. That way
the spring bias is nearly 100% neutralized most of the time, and
you only use it slightly. There's nothing at all wrong with the
spring bias trim, and I think many people will love it. It's the minimum
that I personally would be happy with....and it can be added post-build,
so that's nice too.
Then there's the adjustable tab trim. This is what I have.
It's something that I *personally* would absolutely do again,
and my preference hasn't changed...I'd do it the same way. In fact, I'll be
rebuilding my rudder someday and I plan to incorporate it almost identically
into the new build. I had debated adding a cutout tab, but I don't know
if it's
worth the work and the increased thinking about how to structurally
reinforce
things. The hinge tab on the trailing edge is simple, works well, and
is fairly
minimal impact. I don't remember exactly (I think it's in my write-up)
how long
it took, but I'm sure it wasn't more than one weekend, with the bulk of it
being one evening. So time invested was minimal. To me, aerodynamic
trim like this is about as good as you can get for trimming. You're actually
trimming your flying surface of the rudder to be in trim, just like you do
with the elevator. It means that there is no tension on either rudder
cable in flight, which isn't necessarily a benefit...it just means that the
rudder has no need for any actuation to keep it perfect. I actually
think a little spring return on the pedals may be a good thing, but again,
there are ways that it will also be less convenient. Van's has a very
simple system, and any change to it adds some degree of
negative side, even if there is a benefit added. The world isn't
100% black or 100% white....anything you do will involve a little
grey. The biggest downside to the electric trim is that you will be BETTER
off doing it pre-paint. I did mine post-paint and while it turned out good,
it would have been better pre-paint. The biggest upside is
the absolute perfect adjustment to trim with no effect on the pedals
or feel whatsoever. Do I use it, yes....I just did a round trip to Florida
and I used it on that trip both ways. I had a sloped horizon at one point
that was ticking me off, so I trimmed it out. It worked well. But, it's not
necessarily "better" than any other method. All of them can work.
I do think that for most x/c fliers, at least those who are really in tune
to their airplane, will enjoy at least some form of adjustable trim.
I also think that for those who don't have adjustable trim, their opinions
may actually change as they fly more and more long x/c legs. The fact
is, trim is not a static thing unless all flight characteristics are
also static....it's just the individual's toleration for imperfection as it
gets more out of trim.
It's just funny to see the thread come back again and again.
You can ask if rudder trim is needed, and either answer, Yes or No,
is correct. And which system is best? Well, that is all up to
the builder too. You're going to find satisfied people with ANY method.
So I'd encourage the builder to actually sit and think about it on their
own. Spend some time pondering it. Then just pick one and go.
Aileron trim....that I think is needed. Yes, there are those who don't
agree,
but the -10 tanks are so long, and it doesn't take too much imbalance to
develop that rolling tendency. You can minimize it with good fuel
management, but if this one were put to a vote, my guess is you'd
have maybe 5-10% of the people who fly lots of X/C time who
would vote no.
Rudder trim, if electric, would be ok either at full speed or reduced.
If you have safety trim, which is probably ideal from a simplicity
standpoint in wiring, I'd just do speed reduction so you can be
very precise. Otherwise, full-speed will work.
Aileron trim you'll want to run full speed for sure.
Elevator trim I believe is a safety issue if you don't do speed reduction
on it, but ONLY at airspeeds over 100 or 110kts. You definitely
want full speed when in the pattern. But you absolutely don't want
full speed while flying. It is just too dangerous if you get a stuck
switch, shorted ground, bumped switch, or anything that could cause
more than 1 second of accidental trim. Even 1 second of accidental
trim is almost guaranteed to cause you to bust your IFR assigned
altitude, so even from that aspect it's just not worth leaving it full
speed. Yes, I also flew many hours with only full-speed trim, but
that wasn't incident free. It did work, and I learned to live with it
for a while, but there are safety issues and I think Safety Trim basically
fixed all those issues for me. This isn't meant to be a plug for
Safety Trim, because it gets annoying when people constantly
plug products on the forums, but, they did a great job on it.
If you have Vertical Power and do it there, fine. If you did a
roll-your own, fine. Even if you don't deal with runaway trim,
you really need to do something to have a dual-stage speed
on the trim. Do it however you want...but just do it.
was not a big deal. You grab a piece of aluminum, 4" X 2" and you bend
it slightly. Fly and see what happens at cruise. adjust as needed and
repeat flight until ball is centered. If I add up the cost of gas I
guess it was about $75, except I was flying anyway so it was
practically free. My ball is centered than not and I rarely need to
adjust it in cruise, John is right on, once you get the rudder tab
tuned in there is very little trim adjustments needed.
would encourage all you debating this to check out his extensive
review and steps to do oneself.
Pascal
PostPosted: Mon Dec 09, 2013 9:59 am    Post subject: rudder trim RV-10 Reply with quote
Absolutely, without a doubt, an excellent post. I really learned a lot
and also got some valuable info.
I agree that building a stock airframe isn't 'bad' except to say that
departure from the plans adds immense additional build time. At least it
does for me.
I chose to use model airplane servos because of the light weight (one of
my 'hot buttons') and low cost. Ease of installation using the hinge
method is also a plus. However I had to install a pulse width
controller for the servos ..... and instead of a simple 555 chip I chose
to do it with an evaluation processor so I could control it's speed and
position 'better'. Because I can!
I have already wired the elevator trim and flap controls through relays
and thanks to Tim's take on the elevator trim speed I'll go ahead and
add both of them to the processor program to 'pulse' the relays and
thereby control the speed of those two functions as well. Making the
speed variable with the length of time the button is pressed becomes a
simple programming task. The change does, however, add to my build
time, but I take Tim's concern with elevator trim speed as a safety
factor seriously.
As for Tim's 'funny part' ..... I don't think there's real effort to
start a food fight every so often. I like to search a subject to see
what has been written before but may post the same question again since
there's more 'experience' gained by those fortunate to get their project
finished and gaining additional knowledge on whether the mods they made
were successful or a waste of time.
OK, lunch is over so it's back to building!!!
Linn
someone has
one-size-fits-all
There isn't
painted
Nearly.
always
aesthetics,
wrong to
so that's nice too.
I'll be
identically
know if it's
reinforce
is fairly
write-up) how long
of it
actually
you do
that the
again,
BETTER
good,
Florida
point
it's not
tune
opinions
as it
agree,
would vote no.
basically
> bend it slightly. Fly and see what happens at cruise. adjust as
> needed and repeat flight until ball is centered. If I add up the cost
> of gas I guess it was about $75, except I was flying anyway so it was
> Pascal
napolin(at)me.com
PostPosted: Mon Dec 09, 2013 11:59 am    Post subject: rudder trim RV-10 Reply with quote
I only have about 65 hours on the 10 but I just flew from MD to FL. I found that it doesnt take much force on the pedals to center the ball and there is enough friction in the system to keep it there a good part of the time. Right now I dont see any need for rudder trim.
On the other hand I dont have the wheel pants or landing gear fairings installed yet and if they arent aligned perfectly rudder trim might become more important
Nikolaos Napoli
Goto page 1, 2  Next
Page 1 of 2
