keithmckinley
Posted: Sat Nov 10, 2012 7:11 am Post subject: Pneumatic line flare |
Just double checking...37 degrees? also, anyone have any thoughts on this;
connection at emergency air bottle is good, Front cockpit E air valve is perfect with SS needle, I rebuilt the check valve (Doug's kit) on front right firewall.
The emergency bottle will still not hold air.
Keith
hkgibby(at)yahoo.com Guest
Posted: Sat Nov 10, 2012 7:55 am Post subject: Pneumatic line flare |
I had a hole develop in bottle itself from rust and had to replace. You will not be able to hold air for more than 30 secs or so and you'll be able to hear it back at drain access door. Other culprits could be the shutoff valves/gauges in individual cockpits.
Hoot
On Nov 10, 2012, at 8:11 AM, "keithmckinley" <keith.mckinley(at)townisp.com> wrote:
Keith
Keith McKinley
700HS
KFIT
http://forums.matronics.com/viewtopic.php?p=387506#387506
keithmckinley
Posted: Sat Nov 10, 2012 5:06 pm Post subject: Re: Pneumatic line flare |
Cockpit valves look like new, lines are tight.
I believe the gauges measure line pressure and not bottle pressure like the main air system. I'm going to recheck the schematic.
Keith
Posted: Sat Nov 10, 2012 5:39 pm Post subject: Pneumatic line flare |
On the CJ, the main system gauge measures line pressure until you open
the main air valve. Then it measures the pressure in the main air
bottle. The emergency gauge measures the emergency bottle pressure
because it reads the pressure all the time without the emergency air
valve opened.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 11/10/2012 7:06 PM, keithmckinley wrote:
Keith
Keith McKinley
700HS
KFIT
http://forums.matronics.com/viewtopic.php?p=387522#387522
kingcj6(at)aol.com Guest
Posted: Sat Nov 10, 2012 5:57 pm Post subject: Pneumatic line flare |
Years ago, our emergency system also drained down. A ultrasonic tester found the leak to be in the inlet area of the gauge; a new one quickly fixed it.
Dave
keithmckinley
Posted: Fri Nov 16, 2012 10:51 am Post subject: Re: Pneumatic line flare |
Thanks Everyone!
Keith
Harv
Posted: Thu Nov 29, 2012 1:35 am Post subject: Re: Pneumatic line flare |
Keith
I'm having exactly the same issue at the moment, emergency air pressure leaks to zero over about a day. It must be small leak and isnt audiable (to my ear).
I've not had chance to look closely yet but I have new stanless needles in the emerg valves and the bottle was pressure tested (as per the schedule) and the check valve on the fire wall is new.
I can only thing a line nut needs tightening or a gauge is leaking?
Rgs
Harv
tigerbabaluba
Posted: Thu Nov 29, 2012 1:59 am Post subject: Re: Pneumatic line flare |
Try water and soap. Start your search at the emergency bottle nut.
I´ve got same problem, solved very easily.
_________________ Tigerbabaluba from Portugal |
