Red Cube FWF install
woxofswa
PostPosted: Fri Nov 09, 2012 10:27 am    Post subject: Red Cube FWF install Reply with quote
Anyone be so kind as to post some pix on their firewall forward red cube installation?
Thanks in advance.
Myron Nelson
Mesa, AZ
Flew May 10 2014
partner14
PostPosted: Fri Nov 09, 2012 11:49 am    Post subject: Red Cube FWF install Reply with quote
Hey Myron. Don McDonald here.... I have several... pic 6812c is actually mine... white is rubber (totally mounted to the rubber)... Just an fyi.. I was having trouble with the fuel flow going to zero about 2% of the time... wouldn't necessarily stay at zero, but long enough to screw up the fuel burn calcs.... since moving it forward, it's absolutely dead nuts on!
Sent: Friday, November 9, 2012 12:27 PM
Subject: Red Cube FWF install
--> RV10-List message posted by: "woxofswa" <woxof(at)aol.com (woxof(at)aol.com)>
Thanks in advance.
Myron Nelson
Mesa, AZ
Emp completed, QB wings completed, legacy build fuse in mostly done, finishing kit in progress.
http://forums.matronics.com/viewtopic.php?p=387382#387382
http:/ http://www.bui//www.homebuilthelp.com/" target="_blank">http://www.homebuilthelp.com/</ &nbsthe many ator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-L==
 Filesize:  63.73 KB
 Viewed:  14267 Time(s)
 Filesize:  96.58 KB
 Filesize:  294.77 KB
Don A. McDonald
40636
aerosport1
PostPosted: Fri Nov 09, 2012 12:08 pm    Post subject: Red Cube FWF install Reply with quote
Myron here is how I mounted mine. 355 hrs and no problems
Geoff Combs
www.aerosportmodeling.com
 Filesize:  554.91 KB
 Viewed:  14265 Time(s)
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
aerosport1
PostPosted: Fri Nov 09, 2012 12:18 pm    Post subject: Red Cube FWF install Reply with quote
Just an FYI for the location of the fuel transducer. Soon there should be some very good data on mounting this
fuel transducer in the tunnel as in the Vans instructions. From this data this could be a real problem and I would think twice
about mounting it in the tunnel. Bob Newman at TCW will be providing a report on this. The report will be
quite scary at to say the least. Bob said you can contact him directly to discuss or wait for his report.
Geoff Combs
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald
Sent: Friday, November 09, 2012 2:49 PM
Subject: Re: Red Cube FWF install
Thanks in advance.
Myron Nelson
Mesa, AZ
http:/ http://www.bui//www.homebuilthelp.com/" target="_blank">http://www.homebuilthelp.com/</ target="_blank" ator?RV10-List? many &nbsthe >http://www.matronics.com/Navigator?RV10-L==
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
Strasnuts
PostPosted: Fri Nov 09, 2012 4:01 pm    Post subject: Red Cube FWF install Reply with quote
Myron,
Here is a pic of mine. 280 hours with no problems. I fireslleved mine per
directions but I didn't follow the statement: Do not attach the transducer
directly to the engine......
Here is some notes from the installation manual.
Fuel Flow Transducer Notes
. NEVER blow through the transducer. Keep the yellow caps on until it is
installed.
. The fuel flow transducer(s) should be installed in a straight section of
your fuel line. (6 straight inches on each side is desirable).
. The fuel line should not drop down after exiting the transducer.
. The wires MUST NOT come out of the bottom of transducer. Wires pointing up
is the best .
. When assembling fittings into the 1/4" NPT inlet and outlet ports do not
exceed a torque value of 25 ft.-lbs.
. Do not use Teflon tape in an aircraft fuel system. Use "Fuel Lube/Ez Turn
Lubricant"
. The transducer should be mounted down stream of a fuel filter.
. Do not attach the transducer directly to the engine to avoid excessive
vibration.
. Do not mount the transducer near the exhaust systems or other hot engine
components.
. If the transducer is in the engine compartment, it should be covered in
fire sleeve to protect it from excessive heat.
. The transducer wires may be trimmed any desired length
Possible Transducer Placement Locations:
1. Between the auxiliary electric boost pump and the engines mechanical fuel
pump.
2. Between fuel injection servo and the distribution block.
3. Between the Engine driven pump and the Carburetor
Note: If your engine is equipped with a fuel return line from the carburetor
back to the fuel tank you will need to install two flow transducers.
One in the feed line from the fuel pump to the carburetor and one in the
return line from the carburetor back to the fuel tank. This applies to
certain Continental engines and Rotax 912(ULS) and 914 engines.
 Filesize:  128.1 KB
 Viewed:  14253 Time(s)
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
larkrv10(at)gmail.com
PostPosted: Sun Nov 11, 2012 6:12 pm    Post subject: Red Cube FWF install Reply with quote
Sean, how did you, or where did you get the fire sleeve to cover the transducer?
Thx, Rick
#40956
Southampton, Ont
On Fri, Nov 9, 2012 at 6:59 PM, Seano <sean(at)braunandco.com (sean(at)braunandco.com)> wrote:
[quote]Myron,
Here is a pic of mine. 280 hours with no problems.  I fireslleved mine per directions but I didn't follow the statement:  Do not attach the transducer directly to the engine......
. NEVER blow through the transducer. Keep the yellow caps on until it is installed.
. The fuel flow transducer(s) should be installed in a straight section of your fuel line. (6 straight inches on each side is desirable).
. The wires MUST NOT come out of the bottom of transducer. Wires pointing up is the best .
. When assembling fittings into the 1/4" NPT inlet and outlet ports do not exceed a torque value of 25 ft.-lbs.
. Do not use Teflon tape in an aircraft fuel system. Use "Fuel Lube/Ez Turn Lubricant"
. Do not attach the transducer directly to the engine to avoid excessive vibration.
. Do not mount the transducer near the exhaust systems or other hot engine components.
. If the transducer is in the engine compartment, it should be covered in fire sleeve to protect it from excessive heat.
1. Between the auxiliary electric boost pump and the engines mechanical fuel pump.
Note: If your engine is equipped with a fuel return line from the carburetor back to the fuel tank you will need to install two flow transducers.
One in the feed line from the fuel pump to the carburetor and one in the return line from the carburetor back to the fuel tank. This applies to
Strasnuts
PostPosted: Sun Nov 11, 2012 8:04 pm    Post subject: Red Cube FWF install Reply with quote
Rick,
I bought mine from Aircraft Spruce. The first link is what I clicked on and then onto the proper size, which I can't currently remember. I would just measure a rough circumference.
The second link is a new one for me. I would have ordered this if it was available when I installed mine.
http://www.aircraftspruce.com/catalog/appages/stratofs.php?clickkey=4118
http://www.aircraftspruce.com/catalog/appages/gbfireslvft.php?clickkey=4118
I cut the bolt holes through the firesleeve and pushed it on then stuck the bolts through both. I then connected the fuel lines.
As you can see I mounted mine to the engine which the instructions say NOT to do for vibration.
780 Hours
SuperSTOL 60 hours
jrlark
PostPosted: Mon Nov 12, 2012 5:29 am    Post subject: Red Cube FWF install Reply with quote
Excellent Sean, thx. I didn't know ACS sold fire sleeve. I learn things everyday on this list.......
Regards, Rick
