jappie
Posted: Mon Oct 29, 2012 1:40 pm Post subject: vhf transponder interference |
Hello everyone
I'm a new member here and looking for some help on a problem I've noticed approx. 2 years ago.
1- When I transmit on my Garmin GNC 250XL, some gauges on my panel go haywire. ie: Mitchell fuel level indicator.
2- When I trasnmit, ATC tells me my altitude changes on his radar ( transponder Garmin GTX-320) encoder AK-350.
3- When I put my X-Ponder from Off to any position ( SBY, ON, ALT ) a "White" noise can be heard in my headset ( only while receiving).
4-Receiving deteriorate as the flight goes.
airplane all fiberglass, C-GGYY to see pictures
Thank you
Jean-Pierre
Posted: Tue Oct 30, 2012 5:19 am Post subject: vhf transponder interference |
At 04:40 PM 10/29/2012, you wrote:
Hello everyone
Your cockpit is "hot" with RF energy generated
by the transmitter. The most prevalent cause of
this condition is a poorly installed coax connector
at either end of the comm antenna feeder but
especially the transceiver end.
Check this connector to make sure the shield
ground integrity is good.
jappie
Posted: Wed Oct 31, 2012 1:52 pm Post subject: Re: vhf transponder interference |
thank you Bob
I've also found on "Google" that I should have a Notch filter installed, as per Garmin, which I don't have....
I bought the plane 9 years ago as is....
I will check the coax cable during winter maintenance.
JP
Posted: Thu Nov 01, 2012 5:57 am Post subject: vhf transponder interference |
At 04:52 PM 10/31/2012, you wrote:
thank you Bob
JP
Can you point me to the website that recommends/offers
this 'notch filter'?
jappie
Posted: Thu Nov 01, 2012 12:18 pm Post subject: Re: vhf transponder interference |
This is a .pdf file: installation manual for Garmin 250 XL
page 9 & 10 Notch filter required, but I understand that it if for GPS interference, not my problem, but still say I need it anyway.
JP
http://trackeraff.com/IAS/manuals/Garmin/GNC%20250/156_InstallationManual.pdf
Posted: Thu Nov 01, 2012 1:26 pm Post subject: vhf transponder interference |
At 03:18 PM 11/1/2012, you wrote:
JP
Okay. The GPS signal radiated by satellites is VERY
small. At the same time, your VHF transmitter is designed
to transmit most strongly in the 118 to 135 range, a range
that brackets 131.285. The 12th harmonic of this frequency
falls on the GPS center frequency of 1.57542 Ghz.
A check you can make first is to see how transmissions
on frequence adjacent to the 'rosewood stake' affects
GPS performance. Watch GPS signal strengths while keying
the transmitter on say on all the notches between 131.2
and 131.35. See if the signal strengths degrade to causing
the GPS to loose track.
If so, try the VHF comm frequencies down to day 131 and up
to 132 . . . how close CAN you be to the rosewood stake and
not affect the GPS.
Then count how many times you've used frequencies in that
range and further, asses the risk to comfortable conduct
of the flight if you DO happen to whack the GPS signal
on occasion.
I've flown a lot of GPS aided miles and never noticed
a loss of nav data event. Even if it had occurred, I might
not have noticed it. I think it's a good thing to be
aware of . . . and watch for . . . but not sure it's worth
the price of this notch filter. That assumes that it costs
more than $0.50 and the top off a box of Wheaties.
If you find that you don't have noteworthy interference,
let us know what you find. I've been aware of the potential
for this issue but I can't recall it rising up in conversations
at HBC. Wayyyyy back when, we had some problems with
signals radiated from the RECEIVER oscillators interfering
with GPS. That required fabrication of a shield screen to
stack between the two radios.
jappie
Posted: Sun Nov 04, 2012 12:49 pm Post subject: Re: vhf transponder interference |
Hello
Just got back from the hangar, did some test with my VHF radio, (outside)
Looked at the Satellite strength signal, my average was 7.8,
TX on freq. 131.20 up to 131.35 and did see a decrease in strength signal averaging 3.7, at one point, I got the poor coverage warning.
So, next step, inspect my connectors, coax, antenna, ground plate...etc. Winter project.
Posted: Sun Nov 04, 2012 4:12 pm Post subject: vhf transponder interference |
At 02:49 PM 11/4/2012, you wrote:
| Quote: | --> AeroElectric-List message posted by: "jappie" <jappie(at)videotron.ca>
Hello
So, next step, inspect my connectors, coax, antenna, ground plate...etc. Winter project. |
Not sure there's anything 'wrong' with your as-installed
transceiver. The VHF comm transmitter WILL have harmonic
content in its output. It's an expected condition that's
tested during the TSO qualification process.
You're probably seeing a manifestation of a special
case were the transmitter might be very good in the
world of terrestrial communications and navigation
but offers insult to the very tiny GPS satellite
signals . . . but only in a narrow range of circumstances
and intermittently at that.
I think you're golden. Adding the suggested 'notch filter'
in your transceiver's antenna feeder will no doubt
improve on your observed interference in the range of
interest so if you don't mind the expense off adding the
filter . . .it's not a big thing
Aircraft Spruce has the one above for about $110.
Found this one on eBay for $25 plus too much shipping (by it
now).
http://tinyurl.com/c3e68jf
You could make a best offer of say $25 if he
ships it first class in a padded envelope for $2.00.
I went to the workbench and fiddled with a 'po man's
notch filter.
[img]cid:.0[/img]
While you're hammering on the airplane this winter, you might
conduct the experiment above. Let us know what your final dimension
is. Yes, the 'active dimension' includes conductors inside the
coax T-connector. You'll want to do some look-see at the 13th
harmonics too . . . near and either side of 121.25 Mhz. In fact,
do the initial experiments at the 13th harmonic values . . . odd
harmonics from transmitters tend to be much stronger than
even ones.
I see that Comant is now offering VHF antennas with GPS notch
filtering built in. Cool move.
Here's a thread on VansAF forum where a builder was experiencing
severe interference
http://tinyurl.com/a3em5l2
362.39 KB |
20309 Time(s) |
jappie
Posted: Wed Jan 16, 2013 5:56 pm Post subject: Re: vhf transponder interference |
hello
Went to my hangar last week, started to remove radio equipment. Took the coax cable and brought it to work to show to the "experts", Electronic Dept.
One BNC connector is a twist (screw-in) type, I find that cheap to use on aircraft (personal opinion). Anyway, we started un-twisting the connector and wow, no crimp with the middle pin, is that normal ? and shield was almost gone !! see picture.
Coax is (was) RG58C/U and will be replaced by RG142.
206.59 KB |
20187 Time(s) |
Posted: Thu Jan 17, 2013 7:52 am Post subject: vhf transponder interference |
At 07:56 PM 1/16/2013, you wrote:
hello
Electronic Dept.
It was time to replace that connector before it
flew for the first time!
jappie
Posted: Fri Jan 18, 2013 9:26 am Post subject: Re: vhf transponder interference |
ha !
I've just learned that Twist Type BNC connectors should be use with solid center conductor only....
JP
Posted: Fri Jan 18, 2013 9:56 am Post subject: vhf transponder interference |
ha !
I've just learned that Twist Type BNC connectors should be use with solid center conductor only.... |
I would argue further that twist on connectors should
not be used for any connector. Well, with one exception.
Those 'wire nuts' favored by electrical contractors for
the wiring of buildings are very interesting examples
for the achievement of high-pressure, gas-tight contact
with wires using low force, solderless techniques.
[img]cid:.0[/img]
This type of twist-on connector brings a number of circular
cross-sections into contact with each other. Two circles
contact each other with zero-area . . . i.e. relatively
small forces can produce very high pressures that will
offer good electrical connection as long as there are no
extra-ordinary environmental effects. This is why
wire-nuts are not recommended for any vehicular application.
Twist-on connectors for coax attempt to develop long
lasting, high pressure connection to copper strands being
backed up by PLASTIC. Further, environmental
stresses on the made up joint are much more severe
than the protected confines of your house's breaker
and switch boxes.
Contrary to the inventor's fondest wishes, the twist-on
coax connector was designed to fail.
83.75 KB |
20142 Time(s) |
jappie
Posted: Tue Mar 05, 2013 6:07 pm Post subject: Re: vhf transponder interference |
Here is my new RG-142 cable.
pictures are in the wrong order
JP
247.71 KB |
20005 Time(s) |
285.61 KB |
20005 Time(s) |
281.23 KB |
20005 Time(s) |
276.25 KB |
20005 Time(s) |
jappie
Posted: Fri Mar 15, 2013 4:18 pm Post subject: Re: vhf transponder interference |
Hello again
After making a new comm cable , I decided to replace the x-ponder cable also, GTX-320, so I removed the old one and found my BNC connector (coax panel mount) to be a TED 9-30-11 ( look at the picture) but can't find anything on 9-30-11, instead everything I find is 9-30-10....
JP
71.08 KB |
19938 Time(s) |
Bob McC
Posted: Fri Mar 15, 2013 6:18 pm Post subject: vhf transponder interference |
Just did a Google search for "ted 9-30-11".
Very first hit was this link: http://tinyurl.com/aatlnmk
12th item down the list was this item: http://tinyurl.com/au3o3q7
Appears to be the part you're asking for, not the -10 alternate which is the
6th item down the same list. http://tinyurl.com/a7yyv3z
Bob McC
[quote] --
_________________ Bob McC
Falco #908
(just starting) |
jappie
Posted: Sat Mar 16, 2013 5:25 am Post subject: Re: vhf transponder interference |
[quote="Bob McC"]Just did a Google search for "ted 9-30-11".
Bob McC
yup. that is the only site I found too ( I lied !!). wonder what is the difference between them. (-10 -11)
Could I replace it by DBA-600 ???
JP
jappie
Posted: Wed Mar 20, 2013 7:34 am Post subject: Re: vhf transponder interference |
what is the importance of the Impedance bushing inside this connector TED 9-30-10 ?
I've been told to use use it only with a certain type of cable ...
My old one had none, maybe one of the many reasons I have interference...
JP
Posted: Thu Mar 21, 2013 9:07 am Post subject: vhf transponder interference |
JP
I wrote to TED Mfg to ask for their published instructions
on assembly of this connector. An excerpt from their reply
is shown below:
[img]cid:7.1.0.9.0.20130321120308.048a19f0(at)aeroelectric.com.0[/img]
I'll publish the entire document in the Manufacturer's data
folder of aeroelectric.com later today.
The bushing you asked about is used for smaller coaxes.
The .2" diameter coaxes like 58, 400, 142, etc do not
require it.
65.17 KB |
19845 Time(s) |
jappie
Posted: Wed Mar 27, 2013 12:03 pm Post subject: Re: vhf transponder interference |
Thank you Bob
I did my soldering last weekend with RG-142 but I installed the impedance bushing not knowing better, anyhow, I don't think it will be harmfull.
JP
