CH601-HD baggage floor
carlossa52(at)gmail.com
PostPosted: Mon Oct 29, 2012 6:09 pm    Post subject: CH601-HD baggage floor Reply with quote
Hello gang (assuming you are still out there...?)I am doing a trial fitting of the (CH601-HD) baggage floor. So far, everything fits nicely, rear fuse to centre wing, firewall, alignment, etc. I am a bit puzzled by the baggage floor: it seems to be about 20 - 25 mm (one inch or so) too long: according to the plans, the baggage floor should end at the continuation of the seat's back (or 6F13-3, same thing).
Did any of the HD(S) builders out there have to trim the from edge of the baggage floor?
I did a search of the archives, but did not find a similar case...
Actually, I found someone's post talking about a "perfect fit" (i.e., trim required only to fit the longeron curve).
Comments/suggestions?
(PS: hope everyone is safe out there.)
Carlos
CH601-HD, plans
rear fuse, centre wing, firewall in place
PostPosted: Mon Oct 29, 2012 6:34 pm    Post subject: CH601-HD baggage floor Reply with quote
Here's a picture, might help explain the situation.
On 29 October 2012 22:07, Carlos Sa <carlossa52(at)gmail.com (carlossa52(at)gmail.com)> wrote:
Hello gang (assuming you are still out there...?) I am doing a trial fitting of the (CH601-HD) baggage floor. So far, everything fits nicely, rear fuse to centre wing, firewall, alignment, etc. I am a bit puzzled by the baggage floor: it seems to be about 20 - 25 mm (one inch or so) too long: according to the plans, the baggage floor should end at the continuation of the seat's back (or 6F13-3, same thing).
Carlos
CH601-HD, plans
arget="_blank">http://www.matronics.com/Navigator?Zenith-List
tp://forums.matronics.com
 Filesize:  139.28 KB
 Viewed:  3987 Time(s)
jlatimer1(at)cox.net
PostPosted: Tue Oct 30, 2012 7:33 am    Post subject: CH601-HD baggage floor Reply with quote
Carlos,
I don't recall having to trim 6F13-3. I reviewed my building log and photos from that time and there were no notes about having to trim 25mm from the front edge.
Jerry
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Carlos Sa
Sent: Monday, October 29, 2012 7:08 PM
Subject: CH601-HD baggage floor
Hello gang (assuming you are still out there...?)I am doing a trial fitting of the (CH601-HD) baggage floor. So far, everything fits nicely, rear fuse to centre wing, firewall, alignment, etc.I am a bit puzzled by the baggage floor: it seems to be about 20 - 25 mm (one inch or so) too long: according to the plans, the baggage floor should end at the continuation of the seat's back (or 6F13-3, same thing).
Carlos
CH601-HD, plans
PostPosted: Tue Oct 30, 2012 7:50 am    Post subject: CH601-HD baggage floor Reply with quote
Thanks, Jerry - It seems I am in a unusual situation.Maybe the seat back angle is off... I sent a note to ZAC, as this could be a symptom of some major issue.. Carlos
On 30 October 2012 11:32, Jerry Latimer <jlatimer1(at)cox.net (jlatimer1(at)cox.net)> wrote:
[quote] Carlos,
Jerry
From: owner-zenith-list-server(at)matronics.com (owner-zenith-list-server(at)matronics.com) [mailto:owner-zenith-list-server(at)matronics.com (owner-zenith-list-server(at)matronics.com)] On Behalf Of Carlos Sa
To: zenith-list(at)matronics.com (zenith-list(at)matronics.com)
Carlos
CH601-HD, plans
PostPosted: Tue Oct 30, 2012 8:06 am    Post subject: CH601-HD baggage floor Reply with quote
Carlos,
When I go to the airport next, I will measure the baggage floor and see if I've removed some material from it. I know I had to make some modifications to rear turtle deck when I installed the front opening canopy, but I don't think I had to trim the baggage floor.
Jerry
Sent: Tuesday, October 30, 2012 8:49 AM
Subject: Re: CH601-HD baggage floor
Thanks, Jerry - It seems I am in a unusual situation.Maybe the seat back angle is off... I sent a note to ZAC, as this could be a symptom of some major issue...Carlos
[quote] Carlos,
Jerry
Subject: Zenith-List: CH601-HD baggage floor
Carlos
CH601-HD, plans
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
