pmather
Posted: Wed Oct 17, 2012 4:53 am Post subject: SWR meter(s) NAV/COM/DME/TPD |
Bob
Can you recommend one or more SWR meters that between them can cover the
full range of avionics antenna. I'm looking for units that generate the
signal themselves
Peter
Posted: Wed Oct 17, 2012 11:41 am Post subject: SWR meter(s) NAV/COM/DME/TPD |
At 07:52 AM 10/17/2012, you wrote:
Bob
signal themselves
Peter
Hmmmm . . . that's a broad range of test equipment. Further,
it covers frequencies outside those of amateur radio/experimenters
interests. The MFJ259/266 are the gold standards for antennas
up to 175 MHz (and 400 MHz; MFJ266). Single devices that
cover the full range of interest are $kilo$ pieces of
equipment.
Probably the least expensive approach is a Bird 43 watt meter
with appropriate elements driven by an RF power oscillator
or signal generator/amplifier. I used to have a 3 watt broadband
amplifier that would drive from my HP generator. I had a few
1 watt elements for the B43. This combination allowed some
economical look-see experiments with antennas in the VHF/UHF
domains.
The amplifier died some years ago and I never did get it fixed.
Are you looking to build some antennas or just troublehoot?
Antennas that ever worked are generally pretty robust and unlikely
to benefit from any sort of 'testing'. Feedline connectors are
the most likely source of problems with antennas in service.
dlj04(at)josephson.com Guest
Posted: Thu Oct 18, 2012 10:41 am Post subject: SWR meter(s) NAV/COM/DME/TPD |
On 10/17/12 11:57 PM, AeroElectric-List Digest Server wrote:
Conventional SWR meters require an external generator and power amp, as
Bob mentions. The MFJ meters he suggests work fine for nav/com, but for
L band (DME, transponder, UAT) you need something else. There is a good
analysis of the various approaches at
http://www.rigexpert.com/index?s=articles&f=aas ... they also make
handheld devices that go to 1000 MHz but not far enough for transponder
and DME (1215 MHz to get all of it.)
The preferred approach is an antenna analyzer like the Anritsu Site
Master series, which was developed for people installing cell phone base
stations. The earlier versions go to 1200-1300 MHz and are being phased
out because many cell phone networks now use frequencies at 1700 MHz and
above. They sell for a little over $1,000 on ebay (or much more for the
latest ones that go to 6 GHz or more.)
In my toolbox now instead of an MFJ is a "Times Technology" T100+
network analyzer, which you can buy from the Hong Kong manufacturer for
$250 on ebay, or see his website at http://timestechnology.com.hk. It is
fiddly to use and seems rather fragile but works well, runs on two AA
cells and fits in a shirt pocket. It will even draw a low resolution
Smith chart to give you some idea of what your antenna is actually
doing. It has a USB port and the fellow keeps promising to release a
full PC control program but hasn't, although the demo example gives full
details on what would be required if someone were to write one
themselves. It only goes to 500 MHz though.
David Josephson
