Michael Wynn
Joined: 10 Jan 2006 Posts: 148 Location: San Ramon, CA
Posted: Mon Oct 08, 2012 9:22 am Post subject: Right Angle Fast-on |
Hi all,
I am installing an electronic ignition in my RV 8 and have a place where a coax wire is split to two fast-on's and then into a coil. The turn is a right angle. Someone posted on VAF that the right angle bend caused the wire to fatigue at the fast-on and fail. They suggested re-routing the wires so that the right angle is eliminated. I have looked at my installation and can do that, but it will require a lot of brou-ha. The question is, does anyone make a right angle adaptor for fast-ons? Something like a female end, right angle, male end so you could plug one into the coil and then the coax into the adaptor. I am not sure how you would crimp one that was just a right angle. The other option is to crimp it and then bend the fast-on 90 degrees. I am afraid that would weaken the connector in an unacceptable manner.
Thoughts?
Michael Wynn
RV 8 Finishing
San Ramon, CA
_________________ Michael Wynn
RV 8
San Ramon, CA |
james(at)etravel.org Guest
Posted: Mon Oct 08, 2012 10:05 am Post subject: Right Angle Fast-on |
Hi Michael,Â
I think I see what you're saying...Â
Could you introduce an extra loop of coax shortly before the two connectors, so that the mechanical stress and vibration  is taken out of the bend -- like the loop you might put into a copper capillary line from the engine to the panel?Â
Alternatively, is there some way of forcing the 90 bend in the coax into a particular shape with some mechanical support? Â In bonsai you wrap thick copper wire around young branches to guide them, and it strikes me that something similar might be fashioned for your coax?
FWIW.Â
James
On 8 October 2012 18:20, Michael Wynn <mlwynn(at)aol.com (mlwynn(at)aol.com)> wrote:
[quote] Hi all,
Â
Â
Thoughts?
Â
Michael Wynn
RV 8 Finishing
San Ramon, CA
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
tp://forums.matronics.com
| [b]
Posted: Mon Oct 08, 2012 11:19 am Post subject: Right Angle Fast-on |
At 01:04 PM 10/8/2012, you wrote:
Hi Michael,Â
FWIW.Â
James
Good thought. I was going to ask if he could "drive past"
the termination points on the coils and then do a 270-degree
turn to bring the fast-ons back around to the coils with a more
generous bend relief. Say about 2" diameter circle?
I'm really sorry that this system got coax cable speced into
it. Klaus and I got into a little tiff some years back when
I suggested ordinary tefzel shielded wire . . . MUCH more
user friendly. Got into a 'discussion' about nano-second
rise time differences between coax and shielded wire.
IMHO insignificant to the design goal of lighting fires
in the cylinders. The measurable and demonstrable difference
between coax and shielded wire STILL left the system
about 100 times better than a magneto . . . which
runs the engine just fine but with fixed timing. Be
that as it may, your choices are restricted by
the selection of wire between power supply and the
coils.
There ARE right angle fast-on terminals
[img]http://i.ebayimg.com/t/100-PCS-22-18-AWG-NYLON-FEMALE-FLAG-TERMINAL-RIGHT-ANGLE-ELECTRICAL-CONNECTOR-/00/s/ODg5WDE0MzI=/,iME+QBErs-NBP6lN4UNt60_1.JPG[/img] [img]cid:.0[/img]
But they are not PIDG and I'd be reluctant to use them
under the cowl.
70.72 KB |
8503 Time(s) |
JLuckey(at)pacbell.net Guest
Posted: Mon Oct 08, 2012 11:28 am Post subject: Right Angle Fast-on |
Michael,
Would something like pictured here: http://www.elliottelectric.com/Products/Detail.aspx?v=TAB&c=RA18250A
Do what you want?
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Michael Wynn
Sent: Monday, October 08, 2012 10:21
Subject: Right Angle Fast-on
Hi all,
Thoughts?
Michael Wynn
RV 8 Finishing
San Ramon, CA
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
Checked by AVG - www.avg.com
10/08/12 [quote][b]
Michael Wynn
Posted: Mon Oct 08, 2012 5:46 pm Post subject: Right Angle Fast-on |
Thank you all for your insights. I have scratched my head about this a bunch. I don't really have two inches from the baffle to coils. It is a little late to try to put them in a different spot. Too much re-engineering. Considering what Bob is saying about the discussion with Klaus, maybe I should terminate the coax an inch or two away and crimp or solder on a short piece of 18 gauge tefzel and us that to make the bend. Add a couple of supports and I should be okay. Does that seem reasonable?
Michael Wynn
RV 8 Finishing
San Ramon, CA
In a message dated 10/8/2012 12:22:08 P.M. Pacific Daylight Time, nuckolls.bob(at)aeroelectric.com writes:
| Quote: | [img]res://C:\Program Files\Nuance\NaturallySpeaking10\Program\web_ie.dll/QMARK.GIF[/img][img]res://C:\Program Files\Nuance\NaturallySpeaking10\Program\web_ie.dll/ARROW.GIF[/img]At 01:04 PM 10/8/2012, you wrote:
Hi Michael,Â
FWIW.Â
James
coils.
under the cowl.
Bob . . . |
70.72 KB |
8492 Time(s) |
RV 8
San Ramon, CA |
Posted: Mon Oct 08, 2012 8:33 pm Post subject: Right Angle Fast-on |
At 08:45 PM 10/8/2012, you wrote:
| Quote: | | Thank you all for your insights. I have scratched my head about this a bunch. I don't really have two inches from the baffle to coils. It is a little late to try to put them in a different spot. Too much re-engineering. Considering what Bob is saying about the discussion with Klaus, maybe I should terminate the coax an inch or two away and crimp or solder on a short piece of 18 gauge tefzel and us that to make the bend. Add a couple of supports and I should be okay. Does that seem reasonable? |
I wouldn't do that. All coax or all shielded. At the time
I published this Shop Note
http://www.aeroelectric.com/articles/RG58/RG58.html
several folks had already replaced RG-58 (suffering
from temperature effects under the cowl) with Tefzel
shielded wire and were satisfied with the results.
I can't speak to the value of sparks jumping 1.5"
gaps between coil towers but if that's a performance
benchmark, be aware that shielded wire substitution
may pollute that particular test result.
Bob . . . [quote][b]
Hmmm. . . I overlooked the obvious question: How
much room DO you have between coil and baffle?
Michael Wynn
Posted: Tue Oct 09, 2012 6:52 am Post subject: Right Angle Fast-on |
I amazed as always. Thank you for this article. I think that's what I'm going to do with my installation.
Michael Wynn
RV 8 Finishing
San Ramon, CA
In a message dated 10/8/2012 9:34:12 P.M. Pacific Daylight Time, nuckolls.bob(at)aeroelectric.com writes:
| Quote: | [img]res://C:\Program Files\Nuance\NaturallySpeaking10\Program\web_ie.dll/QMARK.GIF[/img][img]res://C:\Program Files\Nuance\NaturallySpeaking10\Program\web_ie.dll/ARROW.GIF[/img]At 08:45 PM 10/8/2012, you wrote:
Bob . . . |
RV 8
San Ramon, CA |
Michael Wynn
Posted: Tue Oct 09, 2012 6:55 am Post subject: Right Angle Fast-on |
For the baffle to coil distance, I will have to go measure but I think about two inches, perhaps an inch and a half. I am not concerned about it shorting out, but couldn't see how I could get the coax to coil up in the space present.
Michael Wynn
In a message dated 10/8/2012 9:34:41 P.M. Pacific Daylight Time, nuckolls.bob(at)aeroelectric.com writes:
| Quote: | [img]res://C:\Program Files\Nuance\NaturallySpeaking10\Program\web_ie.dll/QMARK.GIF[/img][img]res://C:\Program Files\Nuance\NaturallySpeaking10\Program\web_ie.dll/ARROW.GIF[/img] Hmmm. . . I overlooked the obvious question: How
Bob . . . |
RV 8
San Ramon, CA |
Posted: Tue Oct 09, 2012 11:33 am Post subject: Right Angle Fast-on |
At 09:54 AM 10/9/2012, you wrote:
| Quote: | | For the baffle to coil distance, I will have to go measure but I think about two inches, perhaps an inch and a half. I am not concerned about it shorting out, but couldn't see how I could get the coax to coil up in the space present. |
. . . not the coax . . . but connections
to the coax.
Try this:
[img]cid:7.1.0.9.0.20121009142330.01e26930(at)aeroelectric.com.0[/img]
Take your coax stripper and prepare a end as if you were
going to install a crimp connector. Except you crimp a
fast-on to the center conductor. Then fold the shields
back over the outer jacket and solder a 20AWG pigtail
to the shield. Put a nice string tie on the pigtail for
insulation insulation support and install another
fast-on. See if you can't install this termination
in the space you described.
As you can see here, the COAX can come STRAIGHT up to
the terminals without bending. Only the more
compliant conductors need be shaped to the task.
178.54 KB |
8481 Time(s) |
