rv10free2fly(at)yahoo.com Guest
Posted: Sat Sep 29, 2012 2:36 pm Post subject: RV-10 Fibreglass Overhead Console |
Hi guys,
I'm installing a fibreglass overhead console which I purchased from the late Tony Sustare some years ago now.
I never received any instructions with the console, so I'm mainly using Deems website as a guide as he also installed the same overhead console. The console installation is generally fiddly but not 'rocket science'.
If anyone has any instructions that would be appreciated but not essential, however I'd really like to know what people used to seal the aft flange of the overhead console to the aft bulkhead in the baggage bay please?
For information purposes, I'm using the same vents as Deems did, the black anodised aluminium vents from Stein, however I'm using the touch activated and touch dimming lights from Aveo, which can be selected from white to red LED in the same light. They are 'wicked'. No switches need to be installed, as the switching is touch sensitive. Also reduces wiring too.
I'm also using LED's in the baggage bay, rather than the standard light.
Warm regards from Oz
Patrick
rleffler
Posted: Sat Sep 29, 2012 3:45 pm Post subject: RV-10 Fibreglass Overhead Console |
I have Geoff's overhead. Mine fits almost flush against the baggage
bulkhead. I just used some standard weather stripping as a seal.
bob
_________________ Bob Leffler
N410BL - Phase I
Posted: Sat Sep 29, 2012 4:08 pm Post subject: RV-10 Fibreglass Overhead Console |
Thanks Bob
Warm regards
Patrick
bob
Posted: Sat Sep 29, 2012 6:10 pm Post subject: RV-10 Fibreglass Overhead Console |
I used mold release on the baggage wall, cut the overhead as close as I could, then laid up epoxy/flox/glass to fill the gap. Then I removed the top, built an aft wall in the overhead plenum to seal it off and make it a pressurized chamber (ie, it doesn't need to seal against the aft baggage wall). Installed two 2" ducts and ran those to the naca inlets.
I can send Picts in a few days if necessary.
-Mike Kraus
On Sep 29, 2012, at 6:32 PM, Patrick Pulis <rv10free2fly(at)yahoo.com.au> wrote:
Hi guys,
Patrick
Posted: Sat Sep 29, 2012 6:32 pm Post subject: RV-10 Fibreglass Overhead Console |
Mike I was thinking of doing that installation technique, thereby eliminating the need for a seal.
Pictures would be appreciated when you are able please.
Many thanks.
Warm regards
Patrick
On 30/09/2012, at 11:34 AM, Michael Kraus <n223rv(at)wolflakeairport.net> wrote:
-Mike Kraus
> Hi guys,
> Patrick
Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Sat Sep 29, 2012 6:58 pm Post subject: Re: RV-10 Fibreglass Overhead Console |
I have the same console. I can tell you that the instructions are not that good. I will try and get to the hanger tomorrow and see if I still have them. If I can find them I will get them posted here for you.
Posted: Sat Sep 29, 2012 9:46 pm Post subject: RV-10 Fibreglass Overhead Console |
Eric, I can't seem to get enough clearance with the front vents (Steins) as they hit the cabin top when positioned in the front holes which re pre-recessed into the fibreglass molding of the overhead console.
Any suggestions would be appreciated please?
I've considered positioning the front vents further aft.
Warm regards
Patrick
On 30/09/2012, at 12:28 PM, "Eric_Kallio" <scout019(at)msn.com> wrote:
http://forums.matronics.com/viewtopic.php?p=384288#384288
Eric_Kallio
Posted: Mon Oct 01, 2012 12:07 pm Post subject: Re: RV-10 Fibreglass Overhead Console |
Patrick, I dug through the hanger and the garage and do not have the 'instructions' for the overhead. You aren't missing much though by way of guidance from them though. On my installation I had no issue with the vent clearance. I tried to attach a close up picture of my vent so you could compare. Were I really had trouble was the joggle on the canopy cover over the back seats. Not even close is an understatement. Not only was it not in the ballpark, but we were playing different sports. I had to do remove the sides for about 8 inches forward and aft of the joggle and reshape it all. Minor work in the grand scheme of things. I did not however have an issue with clearance. With the vents installed there is no restriction of movement and with about 3/4" between the vent and the canopy I get plenty of airflow. Never had the vents fully open in cruise. Getting a whole lot of air out of them. Feel free to PM me if there are any specifics I can try to help you with.
Eric
2.71 MB |
20014 Time(s) |
![Close up of vent[1].jpg](files/close_up_of_vent1_364.jpg)
Posted: Tue Oct 02, 2012 1:41 am Post subject: RV-10 Fibreglass Overhead Console |
Eric, I had no issues down he back, it's the front that's giving me grief.
I'll need to build up he front with a small base in order to lower the vents away from the overhead and the cabin top on order for the vents to clear the cabin top.
I'll get there, however progress is slow.
Warm regards
Patrick
On 02/10/2012, at 5:37 AM, "Eric_Kallio" <scout019(at)msn.com> wrote:
Eric
http://forums.matronics.com/viewtopic.php?p=384406#384406
http://forums.matronics.com//files/close_up_of_vent1_364.jpg
Posted: Tue Oct 02, 2012 4:37 am Post subject: RV-10 Fibreglass Overhead Console |
Guys
Can you tell someone that doesn’t know anything about this overhead console, where does the fresh air to these vents come from?
Carlos
[quote] --
aerosport1
Posted: Tue Oct 02, 2012 5:02 am Post subject: RV-10 Fibreglass Overhead Console |
Carlos here are some pictures that might help. Just put a NACA scoop as in the photo 2" scat tubing from the NACA
to the bulk head fittings as in the pictures.
Hope this helps
Geoff Combs
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo
Sent: Tuesday, October 02, 2012 8:36 AM
Subject: RE: Re: RV-10 Fibreglass Overhead Console
Guys
Carlos
[quote] --
555.62 KB |
19991 Time(s) |
353.41 KB |
19991 Time(s) |
350.79 KB |
19991 Time(s) |
431.92 KB |
19991 Time(s) |
320.91 KB |
19991 Time(s) |
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
glastar(at)gmx.net Guest
Posted: Tue Oct 02, 2012 5:06 am Post subject: RV-10 Fibreglass Overhead Console |
Carlos,
there are several ideas around however at the end it is always the need
to create an outside air opening going into that overhead console, that
could be an NACA inlet on the top (do not forget to care for the water
entering it or you have a shower or some other opening bringing via a
duct some fresh air to that console.
For Iberia you could look into an aircon as well instead?
Cheers
Werner
On 02.10.2012 14:35, Carlos Trigo wrote:
[quote] Guys
Carlos
Posted: Tue Oct 02, 2012 6:27 am Post subject: RV-10 Fibreglass Overhead Console |
Thanks Geoff
Indeed a picture (several pictures is even better) is worth a million words....
They sure helped.
Carlos
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Geoff Combs
Sent: terça-feira, 2 de Outubro de 2012 14:01
Hope this helps
[b]Geoff Combs [/b]
Guys
Carlos
[quote] --
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Tue Oct 02, 2012 6:45 am Post subject: Re: RV-10 Fibreglass Overhead Console |
Carlos,
I have 260 hours with Aerosport's overhead console. It is one of the few must have's in my opinion. Really nice haveing multiple areas to adjust air instead of one blasting your left kneecap.
128.59 KB |
19981 Time(s) |
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Posted: Tue Oct 02, 2012 6:53 am Post subject: RV-10 Fibreglass Overhead Console |
That’s right Werner
I will consider the aircon option, but I need to know prices and weights......
Carlos
[quote] --
Tim Olson
Posted: Tue Oct 02, 2012 7:08 am Post subject: RV-10 Fibreglass Overhead Console |
Sure Sean, I wish I had the console, but you've got to admit
it's kind of nice having that vent on the side...you can
blast the air right up one leg of your shorts, and then
that jungle air comes flowing right out the other leg hole.
What a relief in summer! I can't let the wife do that...
the whistling noise is at the wrong freq. for my ANR
headsets. (sorry, couldn't resist)
On 10/2/2012 9:45 AM, Strasnuts wrote:
Carlos,
-------- 40936 RV-10 SB N801VR Flying
Strasnuts
Posted: Tue Oct 02, 2012 7:22 am Post subject: RV-10 Fibreglass Overhead Console |
Touche!
780 Hours
aerosport1
Posted: Tue Oct 02, 2012 7:31 am Post subject: RV-10 Fibreglass Overhead Console |
Tim that made me LOL. Good reply
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
philperry9
Posted: Tue Oct 02, 2012 8:34 am Post subject: RV-10 Fibreglass Overhead Console |
Sounds like you need to have another kid, Tim. That'll shift the frequency a couple of octaves lower and it should get caught in the headset with the engine noise.
On Oct 2, 2012, at 10:08 AM, Tim Olson <Tim(at)MyRV10.com> wrote:
> Carlos,
Tim Olson
Posted: Tue Oct 02, 2012 9:52 am Post subject: RV-10 Fibreglass Overhead Console |
I never get a chance to use these acronyms, but...
ROTFLMAO!
do NOT archive
On 10/2/2012 11:31 AM, Phil Perry wrote:
