numbers on wires
teamgrumman(at)yahoo.com
PostPosted: Sat Sep 29, 2012 12:51 pm    Post subject: numbers on wires Reply with quote
Any suggestions for getting wire that has numbers on them or a reasonable way to put numbers on wire I already have. I need to stretch a few wires and replace even more.
aa5_driver(at)yahoo.com
PostPosted: Sat Sep 29, 2012 1:42 pm    Post subject: numbers on wires Reply with quote
Check barnstormers, I've seen several wire labelers listed. Also, you can purchase wire labor kits at an electronics supply.
Kevin
BARRY CHECK 6
PostPosted: Sat Sep 29, 2012 2:20 pm    Post subject: numbers on wires Reply with quote
Gary:
There are two ways home builders do it:
1 - Purchase a plasticized paper/label from Avery Labels and print out what you require and
2 - Use a stand or the above item and then use CLEAR heat shrink sleeveing to go over the printed label.
The choice is up to location - If out side the cockpit you can use the plastic label with clear heat shrink.  If inside the cockpit then yo can get away with just either the labels plastic or paper.  Of course plastic is preferred.
Of course you can use a BROTHER Label maker for the one'z  and two'z along with the Clear Hear Shrink.
Barry
On Sat, Sep 29, 2012 at 4:51 PM, Gary Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:
[quote]Any suggestions for getting wire that has numbers on them or a reasonable way to put numbers on wire I already have.  I need to stretch a few wires and replace even more.
st" target="_blank">http://www.matronics.com/Navigator?TeamGrumman-List
tp://forums.matronics.com
Discover
PostPosted: Sat Sep 29, 2012 4:59 pm    Post subject: numbers on wires Reply with quote
See bottom of this page
http://www.matronics.com/forums/viewtopic.php?t=62540&sid=671cc22fb30c3b9b8dbbcf933f2dd3d5
<pre><b><font size=3D2 color="#000000" face=3D"courier new,courier">
 Filesize:  39.91 KB
 Viewed:  11162 Time(s)
Discover
PostPosted: Sat Sep 29, 2012 5:04 pm    Post subject: numbers on wires Reply with quote
[quote]http://www.buyheatshrink.com/dymo-label-writer/rhino-5200-heat-shrink-tubing-printer.htm
PostPosted: Sun Sep 30, 2012 12:08 pm    Post subject: numbers on wires Reply with quote
Ned, I see there is a Rhino 4200 that is half the price. Do you know anything about that one?
To: "teamgrumman-list(at)matronics.com" <teamgrumman-list(at)matronics.com>
Sent: Saturday, September 29, 2012 6:03 PM
Subject: Re: numbers on wires
Discover
PostPosted: Sun Sep 30, 2012 3:54 pm    Post subject: numbers on wires Reply with quote
Sorry I don't
After I get back home I can look up some of the
Ones the experimental guys use
On Sep 30, 2012, at 3:07 PM, Gary Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:
[quote]Ned, I see there is a Rhino 4200 that is half the price. Do you know anything about that one?
To: "teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)" <teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)>
t">http://www.matronics.com/Navigator?TeamGrumman-List
ums.matronics.com">http://forums.matronics.com
http://www.matronics.com/contribution">http://www.matronics.com/contribution
Discover
PostPosted: Mon Oct 01, 2012 11:08 am    Post subject: Re: numbers on wires Reply with quote
http://www.cableorganizer.com/rewards/rhino-printer-promo.htm?utm_source=HP_Bnr_DR4200&utm_medium=Banner&utm_campaign=DymoR4200
At this link it says if you buy 10 tape cartridges you get the 4200 label Pinter for free. If you go to the link scroll down and you fnd heat shrink tubing labels that the 4200 can print on. Might be worth a try. May not be good in the engine compartment as I thnk the 4200 is a thermal printer thus the labels may turn black eventually in a hot environment?????
PostPosted: Mon Oct 01, 2012 11:09 pm    Post subject: numbers on wires Reply with quote
I wondered about the "thermal" part of it. Jeff was telling me about a company that does laser printing on the wire. Not sure what company or the price. Too bad this is so difficult and expensive.
Gary
http://forums.matronics.com/viewtopic.php?p=384399#384399
