raymondj(at)frontiernet.n Guest
Posted: Thu Sep 27, 2012 4:11 pm Post subject: Resurrecting a battery |
Greetings list,
I have a couple of dead batteries. Not discharged but killed. They show
only approx 10.5-11 volts when taken off the charger. Ron was
discussing his experience with putting 15V at .5 amps on some batteries
and resurrecting them to some degree. I have a bench supply that I
could set at 15 V and .5 amps. My question is whether it will likely
damage the bench supply to hook it to a battery. My limited knowledge
says that it shouldn't make any difference to the power supply what is
hooked to it as long as it doesn't feed electrons to the supply.
I've got nothing to loose as far as the batteries are concerned, but I'd
hate to cook my bench supply. It's an old Heathkit IP-28 and says 30V
and 1amp so it shouldn't tax the supply too hard.
Just checking with the experts so I don't kill my power supply.
Raymond Julian
Kettle River, MN.
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
rparigoris
Posted: Thu Sep 27, 2012 6:05 pm Post subject: Resurrecting a battery |
Hi Ray
How many aH battery are they?
If close to 12 to 18aH aqnd AGM, the good bet would be to try and use the 500mA transformers and circuit board I sent along with the batteries I offered. They limit current to ~ 500mA and the control board will turn off once they reach ~ 15.4 volts. I would try a few cycles where you bring down the batteries to ~ 12.4 volts. It may take several days to get the control board to turn off, especially the first time.
If you have an adjustable power supply, set it to constant current ~ 350 to 500mAs and monitor the voltage. This is not going to be a very fast process, it may take days to get to 15 volts. Once you get to 15.4 volts, let it dwell there for 2 hours at least.
I Please report back if you were able to revive.
I did this with AGM batteries, if you have a flooded cell battery, you don't have much to lose, but listen carefully and decrease current if things get too bubbly. I tried putting two of the 500mA chargers in parallel on the 12ah batteries and didn't like the noises too much when the voltage got to the upper 14s on some of the batteries. Using only one 5600mA charger kept things happy.
I have a sneaky suspicion that when I took two of the bad batteries I had, after they reached the 15.4 volts and the controller turned off and put them in parallel on just one 500mA charger and let them reach 15.4 volts (which took a long time) it may have helped a little, the first time anyway. I didn't run a capacity test, but the voltage seemed to hold up better after I let the batteries sit for several days.
Ron Parigoris [quote][b]
Posted: Thu Sep 27, 2012 6:44 pm Post subject: Resurrecting a battery |
Ron, these are flooded cell auto batteries. One I think is a
deep-cycle. I put one of your transformers across the terminals and "It
don't work no more". That is what leads me to worry about the power supply.
I don't think that the power supplies I have are constant current. I
think the current setting is a max allowable setting, but I'm not sure.
By the way. I'm getting good use out of those batteries. Thanks again
for offering them here, even though it was more headache for you.
Raymond Julian
Kettle River, MN.
On 09/27/2012 09:01 PM, rparigor(at)suffolk.lib.ny.us wrote:
Hi Ray
first time.
Ron Parigoris
rparigoris
Posted: Thu Sep 27, 2012 10:24 pm Post subject: Resurrecting a battery |
Hi Ray
You mention that the transformer no longer works after you put it across the battery. Was that with the circuit board connected to the transformer? All you need to do is connect the board in reverse to the battery for a split second and it fries the board. If that's the case, I would say there is a good chance the transformer is still good. You can connect the transformer directly to the battery without the board. Just to make sure, connect a volt meter to the transformer to see it's working and you get the polarity correct, if you have a meter that can measure current, make sure you are pumping in 500m As or there about. You will need to monitor the voltage, once you get to ~15.4, let it go for another two hours.
How many amp hours are the batteries? If they are 35aHs, put two of the 500mA transformers on them in parallel.
Posted: Fri Sep 28, 2012 10:13 am Post subject: Resurrecting a battery |
At 07:09 PM 9/27/2012, you wrote:
Greetings list,
show only approx 10.5-11 volts when taken off the charger. Ron was
batteries and resurrecting them to some degree. I have a bench
supply that I could set at 15 V and .5 amps. My question is whether
it will likely damage the bench supply to hook it to a battery. My
limited knowledge says that it shouldn't make any difference to the
power supply what is hooked to it as long as it doesn't feed
Correct. Charging batteries with a bench supply is not without
some risk . . . depending on the design of the supply. I was
charging a 24 v battery with a big HP 40A supply when the power
went off. The HP's crowbar ov protection circuitry lost its reference
voltage and triggered. Unfortunately the crowbar system assumed
that the energy to be stood-off was coming from AC mains, not
from the load. Hence, the fuse was on the wrong side of the
crowbar and I burned some circuitry. I now charge batteries
through a fuse.
I'm not aware of any specific instances of potential hazard
to small bench supplies . . . I suspect it's very low.
I'd hate to cook my bench supply. It's an old Heathkit IP-28 and
says 30V and 1amp so it shouldn't tax the supply too hard.
A brief look-see at the IP-28 schematic
http://tinyurl.com/ydhkrky
reveals no sneak paths that might make the supply vulnerable
to battery back-feed.
No biggie . . . but since you're not depending on the
supply for anything but boosting . . . don't really need
accurate regulation . . . putting a diode in series
with the supply totally eliminates any risk.
Now, probability for successful recovery with ANY supply
is problematic. The OVERVOLTAGE boost technique described
in Concorde literature and elsewhere is designed to stir
up chemistry that refuses to accept a charge at standard
voltage levels.
You can put a 100w light bulb in series with a diode
bridge rectifier and use this as a current limited source of
high voltage to hook to your battery(ies). Watch the voltage across
the battery. If the chemistry is coming awake, the voltage
should begin to drop and ultimately level off at normal
levels expected for a 1 amp constant current charge.
If the voltage doesn't show signs of dropping, the
chemistry isn't asleep but dead. By the way, the ol'
light-bulbs and rectifier ploy has an ancient history going
back to selenium rectifier days.
The rectifier need not be rated at any voltage greater
than terminal voltage for the battery. Charging current
is controlled by how many/big the light bulbs are.
I once built a battery charger with 4 bulb sockets on
a board along with a selenium bridge rectifier. With
200, 200, 100, and 50 watt bulbs in the sockets, I could
set charge rate between .5 and 5.5 amps by seating/unseating
the lamps in their sockets.
Of course, this is NOT regulated so you have to watch
terminal voltage and shut the critter off when charge
is complete. Left unattended it will boil off a battery.
Posted: Fri Sep 28, 2012 12:46 pm Post subject: Resurrecting a battery |
I had just taken a battery charger off the battery and used just the transformer, with correct polarity.
They don't give an amp/hr rating but it is 675 cold cranking amps. It's a marine starting/deep cycle battery.
| Quote: | Raymond Julian
Kettle River, MN.
and all I'd have to lose is my point of view." - John Prine | On 09/28/2012 01:21 AM, rparigor(at)suffolk.lib.ny.us (rparigor(at)suffolk.lib.ny.us) wrote:
Hi Ray
Ron Parigoris [b]
Posted: Fri Sep 28, 2012 1:43 pm Post subject: Resurrecting a battery |
On 09/28/2012 01:12 PM, Robert L. Nuckolls, III wrote:
| Quote: | You can put a 100w light bulb in series with a diode
Here's where my ignorance starts showing. Is this setup using mains
voltage? Rectified and current limited? 120+ volts DC, current limited
to 1-2 amps?
Raymond Julian
Kettle River, MN.
Posted: Fri Sep 28, 2012 6:36 pm Post subject: Resurrecting a battery |
| Quote: | | Here's where my ignorance starts showing. Is this setup using mains voltage? Rectified and current limited? 120+ volts DC, current limited to 1-2 amps? |
Yes. Suppose the power coming into the back of your
house was being supplied by one of the honorable
T.A. Edison power stations . . . 120 volts DC.
Okay, 150 watt bulb will draw about 1.30 amps.
Now hook a 12v battery in series with this setup
such that current flowing through the lamp tends
to CHARGE the battery. Voltage across the
lamp drops by 12v or so the current drops a bit.
But the lamp still burns brightly and current
through the lamp is charging the battery . . . the
lamp becomes a 100W resistor.
[img]cid:.0[/img]
Horribly inefficient?
Yes . . . unless you want to sit down and read a book
while the battery is charging and can make use of
the light output.
Now, consider a similar design goal but the power
delivered to the back of the house is AC. We can
add the rectifier such that reversal in the applied
voltage is rectified so that it always charges the
battery irrespective of line polarity . . . the lamp(s)
still limits the current . . . want a stronger charge
rate? More or bigger lamps.
[img]cid:.1[/img]
Again, only 10% of total energy consumed goes into
the battery . . . but it IS current limited. Probably
not a charger you want to build for routine battery
maintenance but it is an option for generating a
current limited VOLTAGE source that will RISE to what ever
level the injured battery will accept. If it goes to more
than 2X battery rating and/or if it doesn't begin to
fall in a few minutes, then this resuscitation gambit
is futile and should be discontinued.
47.24 KB |
5410 Time(s) |
75.8 KB |
5410 Time(s) |
Posted: Fri Sep 28, 2012 7:07 pm Post subject: Resurrecting a battery |
Posted: Fri Sep 28, 2012 8:46 pm Post subject: Resurrecting a battery |
Posted: Sat Sep 29, 2012 8:51 am Post subject: Resurrecting a battery |
At 12:34 AM 9/29/2012, you wrote:
| Quote: | Very clear now. 1 picture=1k words. I had the lamp on the DC side in my mind. I'll report back when I have something to report.
I assume there is no reason to put in a cap to try to limit ripple. |
Naw . . . those molecules of lead and acid aren't picky.
There's some school of thought that impressing clumped
up molecules with bursts of high frequency energy tends
to break them up and increase surface area . . . i.e.
restore active chemistry. This prompted a constellation of
product development in 'battery de-sulfators'.
http://tinyurl.com/9c4gwk8
I've yet to see a well crafted laboratory study that confirms
any claimed efficacy for such devices.
Actually, about 1965 there was a rash of articles in
popular 'technical' publications suggesting that one
could recharge the carbon-zinc cell if the energy replacement
profile was half-wave rectified DC (Figure 2 with only
one diode). This 'rattling' of the chemistry was suppose
to make things happen that the original designers of
the carbon-zinc cell never imagined.
I'll forward a copy of the previous post to Skip Koss along
with this one . . . he may have additional insights to
contribute.
Bob . . . [quote][b]
