Dennis Thate
Posted: Thu Sep 27, 2012 4:37 am Post subject: Seat frame brace |
A very light thin walled piece of tubing solved the Firestar II weak frame issue.
59.87 KB |
6216 Time(s) |
_________________ Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern |
209GS
Posted: Thu Sep 27, 2012 3:31 pm Post subject: Re: Seat frame brace |
What issue is that?
_________________ Gerry Uebbing
Firestar II 503 b-box
(not flying yet) |
Dennis Thate
Posted: Thu Sep 27, 2012 3:54 pm Post subject: Re: Seat frame brace |
Gerry,
Hands down..... the Kolb Firestar is probably the most fun aviation experience you will most likely ever have. [ But the little Kolb is a bit frail in places.] But nothing that can't be resolved if you are resourceful.
I flew nearly two hours today and shared a heavy thermal with a bunch of rising corn leaves and a couple migrating hawks within fifty feet of me . My little Firstar II moaned and groaned a bit but the seat back brace never bent a bit this time.
And Remember.......
29.85 KB |
6177 Time(s) |
pj.ladd(at)btinternet.com Guest
Posted: Fri Sep 28, 2012 1:46 am Post subject: Seat frame brace |
shared a heavy thermal with a bunch of rising corn leaves >>
Engine OFF, throttled back, cruise revs?
Pat
Dennis Thate
Posted: Thu Oct 04, 2012 2:10 pm Post subject: Re: Seat frame brace |
This quick fix worked out well, with just a quick touch-up of black paint.
There are 3 basic types of spray paint formulas 1. Lacquer- Most spray paints are acrylic or nitro-cellulose based lacquer, such as Krylon. It dries fast and can be re-coated quickly and bonds to itself. Even some paints labeled enamel are actually lacquers. 2.Oil based -enamels and polyurethane. They dry much slower but generally more are more durable.3. Water based acrylic lacquers which are fairly new to the market. Water is used as a solvent instead of chemical solvents in regular lacquers.
48.58 KB |
6103 Time(s) |
