mburbidg(at)gmail.com Guest
Posted: Sat Sep 22, 2012 12:04 pm Post subject: ACF-50 Anti-corrosion between block and alternator mount... |
When I took the old alternator mount off the engine, I noticed there was some corrosion on the engine block under the alternator mount. My new alternator (B&C) gets its ground through the mount. Can I use and anti-corrosion film such as ACF-50 on the block before bolting the mount to the engine? Or will that place resistance in the ground path for the alternator?
Michael-
fvalarm(at)rapidnet.net Guest
Posted: Sun Sep 23, 2012 12:34 am Post subject: ACF-50 Anti-corrosion between block and alternator mount... |
Michael,
Since nobody has responded yet...I will offer my .02
It is my understanding that products like ACF-50 are used to prevent
oxidation/corrosion from developing. If the part is already corroded, I
would suggest removing the corrosion and then use the ACF-50 to prevent it
from returning anytime soon. You may also look for a electrically
conductive paste that will seal out the oxygen. There should be plenty of
electrical pathway capacity through the mounting bolts regardless.
Bevan
Posted: Sun Sep 23, 2012 8:44 am Post subject: ACF-50 Anti-corrosion between block and alternator mount... |
That's what I did. I cleaned off the corrosion and then put ACF-50 in between before bolting the new mount to the block.
Sounds like that should be ok.
Mike
On Sep 23, 2012, at 1:32 AM, "B Tomm" <fvalarm(at)rapidnet.net> wrote:
Michael,
Bevan
