Posted: Fri Sep 21, 2012 9:13 am Post subject: Pitot tube slightly plugged... |
At 06:21 PM 9/20/2012, you wrote:
<snip>
Called the factory in OH, and related a new-to-them technique of
removing the obstacle. Good feeling to re-invent the wheel, a bit.
BTW, the manufacturing process and subsequent internal road map
knowledge IS proprietary... short of destroying the $600 p-tube.
It would be really interesting to know the
makeup of the obstruction.
The interior passages for a pitot tube are
a maze of holes, turns, drains and baffles
designed to strip high velocity moisture
(wet or frozen) from the air sample, keep
it warm enough remain liquid, and allow
a real sample of dynamic pressure to be
impressed upon ship's instruments.
http://aeroelectric.com/Pictures/Pitot_Tube/Pitot_Tube_Heater.jpg
The fact that you were unable to physically
dislodge it suggests it was buried around
a sharp turn or hiding behind a baffle. I'm
thinking that it was probably a spider nest
where adult but tiny creatures carried a succession
of materials inside and built an obstructing
volume. Pitot tube covers are a GOOD thing
and it wouldn't hurt if they were TIGHT. Perhaps
a piece of slip-fit hose or tubing.
I got to work with the folks at Aero Instruments
when HBC was wrestling with what appeared to
be 'clear air' blocking of one and sometimes
both pitot tubes on airplanes cruising a
high altitude. The instruments always recovered
at lower altitude/warmer atmosphere.
It had to be ice accumulating in a poorly
deiced volume within the tube. The problem
was to figure out exactly where and how.
Not all spaces within the dynamic pressure
vessel are held above freezing when the
OAT is -50C or so.
Interesting story . . . and I'm please to
hear that you were able to salvage an otherwise
useless piece of expensive hardware!
wynaire(at)citlink.net Guest
Posted: Fri Sep 21, 2012 8:45 pm Post subject: Pitot tube slightly plugged... |
Thanks for the illustrative cutaways and info Bob. These PT's are much more
sophisticated than at a 2nd glance. And your pix do indicate the same
pathway my safety wire probe was trying to navigate. The "remains" are
stored for photo-micro graphing later on in the slightly "green" depleted
battery acid. However, the heater elements still perform per Aero
Instruments test-for-certification specs on element amp draw and resistance.
So, despite a little brightening of the copper and identical air-flow based
on a non-plugged same model p-tube, all is well. Life is interesting.
Heater element test specs on Aero Instruments' Pitot Tube model PH502
series: 12 vdc pitot element should draw 6.34 to 8 amps after 2 minutes
operation.
A 24 vdc pitot element [same model] should draw 3.17 to 4 amps after 2
minutes operation.
Resistance in ohms should range from 0.1 to 400. This info is also available
as a .pdf at their web site: www.aero-inst.com/products/aeroph502.php.
Posted: Sat Sep 22, 2012 10:20 am Post subject: Pitot tube slightly plugged... |
. . the heater elements still perform per Aero Instruments test-for-certification specs on element amp draw and resistance. So, despite a little brightening of the copper and identical air-flow based on a non-plugged same model p-tube, all is well. Life is interesting.
Those heater elements are pretty complex. They appear to be
semi-rigid, linear, tube heaters not unlike those one might buy
from Cal-Rod . . .
In fact, there heater wire is wound around a core but with
variable spacing such that x watts are dissipated in one
segment, y watts in another, and z watts elsewhere. The
probability for ice accretion and risk therefrom varies
throughout the geometry of the assembly. The hammer-n-tongs
approach is to simply put enough heater in to warm the whole
thing up so that adequate calories are always delivered to
the worst case location. This would probably double the
current draw and make for a very hot tube.
On the ground and zero air flow, a heated pitot will achieve
cherry red emissions temperatures. In clear air, 300kts,
41K feet and -40C . . . the tube merely heats up to
100C or so. See:
http://tinyurl.com/74yr5q8
At 41K, we can see the effect of increase velocity.
At 200Kts, certain parts of this particular device
rose to about 90 and 110C . . . but as IAS went up
sharply in descent they quickly dropped before there
was much. Ram Air Temp rise sharply during that maneuver
too.
Now, pile some super cooled water on or in the tube
that becomes hard ice on impact and the tube temperature
drops WAaayy down and quickly. At the same time, the
heater-resistance goes down causing the tube to draw
much more current. That 4 amp current on the bench goes
to 10A under heavy icing conditions. Here's some data
I gathered on about a half dozen, exemplar 28v tubes.
http://tinyurl.com/cnndlub
even thought the surface of the tube is firmly
locked at 0C in stirred ice, the heater inside
was still running about 140C . . . due to limits
on how low the thermal resistance could be for
an electrically insulating medium around the
heater wires.
Getting a pitot tube to perform well in the icing
tunnel is an almost frenetic hat-dance around limits
and goals. There is more to those devices than meets
the eye.
After being tasked with participating in one
such a hat-dance, I took a hint from Weller
soldering guns, HV supplies in CRT/vacuum
tube TV, and modern microwave magnetron
power supplies and proffered this idea:
[img]cid:.0[/img]
Suppose you made a pitot tube out of concentric
stainless steel tubes like this and excited
the assembly with very low voltage, high
current energy from a switchmode power supply
built into the base of the tube. I hypothesized
that one could distribute heating energy between
inside and outside tubes by controlling wall
thickness.
The tube WAS also the heater. No temperature drop
across heater/tube insulation. Plenty of heat
thoughout such that tailored distribution
issues might go away. No independent heater to
fabricate, no heater-tube insulation issues . . .
or LOSSES.
I proposed that to my boss who was willing
to take it up the ladder . . . but the immediate
response was, "We get our pitot tubes from Aero
Instruments. They build pitot tubes, we build
airplanes."
There was a time when I worked my first projects
with Beech that somebody would have taken this
ball down-court to at least see if it bounced.
I hear the Russian space program is turning blue
with loss of grey-mater. See:
http://tinyurl.com/blzjvu3
Some connectors-of-dots in the world wide
aerospace industry have noted that the glow
is off the rose for working on 'rockets and
airplanes'. Young bucks fresh out of school
know they can make more money in information
technologies and consumer materials . . . the
lure that brought many of us to aviation years
ago doesn't work the magic it did back then.
Hot hangars, grease, JP, hydraulic oil and
gouges all over your body have been replaced
with brightly lit, air conditioned, keyboards
and tech benches . . . and low risk of
discomfort.
Russia, like the US, is losing it's intellectual
horsepower and as the grey-beards retire, the
effects are showing.
So, perhaps there's an opportunity for somebody
out there with some metal working skills and
a curious nature. I'd be willing to stroke
the electronics if some one of you could acquire,
bend and weld alloys of steel that might make
good heaters cum pitot tube.
It would be interesting to see if this ball
would at least bounce. Could we learn to "build
the better pitot tube" for MUCH less than
$600?
36.13 KB |
22431 Time(s) |
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Sat Sep 22, 2012 3:48 pm Post subject: Re: Pitot tube slightly plugged... |
I flew one of those flights where you just KNEW we already had two strikes. And gosh I learned a lot.
I took off from Furnace Creek into a rapidly approaching (astonishing!) black sandstorm. But the sandstorm quickly outran and engulfed us. Made a 180 out of the sandstorm to find I had no airspeed indicator. The winds were ferocious and making Santa Monica with fuel onboard was dicey, KWJF Fox Field (our normal fuel stop) was closed due to winds. So we stopped in Aqua Dulce...using the stall warning.
We tried to clear the pitot tube with a coat-hangar wire but no dice. We had inadequate tools. Next day the mechanic cleared it. Analysis--Mud dauber wasp.
Jeeeze....the thing you learn and shouldn't do again.
But three points: Cover the pitot tube when parked--always. Unless you have one of those airspeed-operated flapper valves.
A way of ram-rodding the tube would be a step forward in design. But the problem is usually only discovered after getting airborne. So glancing at the ASI during the takeoff run will be in my scan, even if Cessnas easily fly themselves off the ground.
Some bug biologist-psychologist should invent a neat way to keep out dauber wasps. It would make a good science project. Mud daubers bring down heavy iron too.
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
rparigoris
Posted: Sat Sep 22, 2012 4:13 pm Post subject: Pitot tube slightly plugged... |
Hi Eric
Thx. for sharing your experience.
You mentioned "Unless you have one of those airspeed-operated flapper valves".
I owned a 1948 Cessna 170 ragwing for 19 years. Twice I got mud dapper nest in the Pitot tube.
The second time it happened, the wind was howling and I noticed right after take off, so landed and cleared it. When putting tools away and a little worried the plane may roll in a pretty big gust (even though I had wheel chocks in place), I just happened to notice that the airspeed actuated flapper Pitot cover was fully opened, hmm. Then a few seconds later I observed a dapper wasp somehow manage in this wicked gusty wind to land on and crawl inside!
I replaced flapper with a cover and never had another problem.
Ron Parigoris
raymondj(at)frontiernet.n Guest
Posted: Sat Sep 22, 2012 4:43 pm Post subject: Pitot tube slightly plugged... |
We have a bad problem with the mud daubers around here. If I leave an
air tool outside for a day, they find it, and build in the inlet. Got
me to thinking, Has anyone had problems with them building in static
intake ports, fuel vents on gas caps, or the drains on collators.
Starting to think my preflight should include all the above.
Raymond Julian
Kettle River, MN.
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
On 09/22/2012 07:13 PM, rparigor(at)suffolk.lib.ny.us wrote:
Hi Eric
valves".
Ron Parigoris
deej(at)deej.net Guest
Posted: Sat Sep 22, 2012 4:55 pm Post subject: Pitot tube slightly plugged... |
On 9/22/2012 8:42 PM, rayj wrote:
| Quote: | Has anyone had problems with them building in static intake ports,
Yes, multiple times I've had bugs build a nest in my fuel drains
and vents. My cheap solution:
Go to Walmart and buy a 100 pack of bright orange "fuzzy sticks" for
$0.99. Used to be commonly known as "pipe cleaners". You can find them
in the fabric and crafts section.
http://www.walmart.com/ip/Kids-Craft-100pk-Fuzzy-Sticks-Neon/19525338
Cut off a 4 inch section. Fold in half, then on each leg halfway up
fold outward.
You end up with something shaped like this: _/\_
Stick the "V" end up in the hole in the fuel drain, gascolator, fuel
vent, etc, with the legs sticking out to the side.
Remove before flight, but in theory air would be able to pass if you
accidentally left them in the fuel vent.
Been doing this for a few years now and no more bug problem in the fuel
drains.
-Dj
Dj Merrill - N1JOV
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
Posted: Sat Sep 22, 2012 5:19 pm Post subject: Pitot tube slightly plugged... |
Great idea!! I was starting to think about covers for everything and
imagining a whole bag full.
I'll definitely be doing this.
THANKS!!
Raymond Julian
Kettle River, MN.
On 09/22/2012 07:55 PM, Dj Merrill wrote:
them in the fabric and crafts section.
fold outward.
fuel drains.
-Dj
Posted: Sun Sep 23, 2012 10:10 am Post subject: Pitot tube slightly plugged... |
fuel drains.
An elegant solution Dj . . . how about some photos
of these critters in place. Let's do a little one-pager
for the AEC website archives.
Posted: Sun Sep 23, 2012 4:10 pm Post subject: Pitot tube slightly plugged... |
On 9/23/2012 2:07 PM, Robert L. Nuckolls, III wrote:
Hi Bob,
I did a quick little write-up on my website at:
http://deej.net/aviation/bug-plug/
Feel free to use the pictures and info on that page if you want to
put something up on the AEC site.
-Dj
Dj Merrill - N1JOV
N20DG
Joined: 02 Jan 2008 Posts: 61 Location: lancaster, texas
Posted: Sun Sep 23, 2012 4:41 pm Post subject: Pitot tube slightly plugged... |
Can you convert the document to PDF format so it can be easily saved
Dick
In a message dated 9/23/2012 7:11:01 P.M. Central Daylight Time, deej(at)deej.net writes:
| Quote: | --> AeroElectric-List message posted by: Dj Merrill <deej(at)deej.net>
Hi Bob,
-Dj
Dj Merrill - N1JOV
Glastar Flyer N866RH - = Use ilities ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
harley(at)AgelessWings.co Guest
Posted: Mon Sep 24, 2012 4:42 am Post subject: Pitot tube slightly plugged... |
I have Firefox, and am not sure how to do it with other browsers, but it allows me to download and save the page directly as it is in two steps.
First, when on the page, select "File" then "Save Page As...", and select the location where you want to put it. It will sutomatically save the text and html code as an htm file.
Second step, go back to the online page, select ANY image, RIGHT click on it and select "Download All Images". Firefox will pick the folder that you last saved to by default, which is probably the one where you put the htm file, and download all the images there as well.
To view it, simply click on the htm file on your computer and it will load offline in your browser just as the original page did.
Harley
On 9/23/2012 8:40 PM, RGent1224(at)aol.com (RGent1224(at)aol.com) wrote:
[quote] Can you convert the document to PDF format so it can be easily saved
Dick
In a message dated 9/23/2012 7:11:01 P.M. Central Daylight Time, deej(at)deej.net (deej(at)deej.net) writes:
| Quote: | --> AeroElectric-List message posted by: Dj Merrill <deej(at)deej.net> (deej(at)deej.net)
Hi Bob,
-Dj
Dj Merrill - N1JOV
Checked by AVG - www.avg.com
09/23/12 [b]
Eric M. Jones
Posted: Mon Sep 24, 2012 5:23 am Post subject: Re: Pitot tube slightly plugged... |
Mud dauber wasps are the bane of small holes everywhere. I want to suggest that an enterprising individual do the following long-term experiment (Actually, you might try searching the USPTO first):
Let's see what attracts mud dauber wasps. Do many experiments with enough time to allow the wasps to build nests (and taking the weather into account.):
1) Drill a grid of different size holes in a board. Mount the board in a location know for having a known problem with the wasps. Do the WMDs (Wasps, Mud Dauber) prefer a hole size? Log the result.
2) Repeat with a spectrum of different colors. Do the WMDs prefer a color? How about in the UV? Log the result.
3) Repeat with various contrasting patterns around the holes (e.g. starburst, concentric circles, snowflake, spirals, flower petals, angry jagged shapes...whatever you can think of). Log the result.
4) Put a colored LED behind a series of the same size holes. Log the result.
5) Put a blinking LED behind a series of the same size holes. Try various colors. Log the result.
6) Keep going until you find a solution.
7) Patent it. "Method of Preventing Aircraft Pitot Tube Obstruction by Mud Dauber Wasp."
Pick up your Nobel prize in Stockholm.
9) Your MacArthur Genius Prize will be waiting when you return home.
Okay, perhaps that is going too far. But the airlines and pitot tube makers would be very happy to pay for any workable results. Remember, every jet engine you see has that curly snake on the nose cone. This reliably prevents birds from nesting in the inlet. A bird will never come near anything that (in its tiny bird brain) might possibly be a snake. I put a rubber snake on my rear deck which absolutely keeps bird and their mess away.
The goal is to find something in the WMDs brain that works similarly. There are myriad odd insect habits. Perhaps they won't ever come near a yellow pitot probe, or one with UV-bright flower petals or a blinking LED...nobody knows. Several solutions might be possible.
This would be a great science project, even for a whole classroom.
Good luck, and tell us what happens.
Addendum: See my website for a pitot tube of interest:
http://www.periheliondesign.com/downloads/thermopitot.pdf
113 Brentwood Drive
(508) 764-2072
Posted: Mon Sep 24, 2012 5:34 am Post subject: Pitot tube slightly plugged... |
Very interesting idea, Eric! As a start to whoever wants to attempt this, I had several two foot long pieces of 3/16 inch shrink tubing hanging from a shelf in my garage. The daubers plugged up the black tubing, but NOT the yellow, white or red! Not very definitive, but all the openings were hanging in the same location, bunched together. The black looked like it had several years of nests in it, going a couple of inches up the tubing on both ends, but the others were absolutely clear.
Harley
On 9/24/2012 9:23 AM, Eric M. Jones wrote:
[quote] | Quote: | --> AeroElectric-List message posted by: "Eric M. Jones" <emjones(at)charter.net> (emjones(at)charter.net)
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
http://forums.matronics.com/viewtopic.php?p=383883#383883
| [b]
klehman(at)albedo.net Guest
Posted: Mon Sep 24, 2012 5:56 am Post subject: Pitot tube slightly plugged... |
Similar here. They like the black but not the clear transparent tubing.
Ken
On 24/09/2012 9:33 AM, Harley wrote:
| Quote: | Very interesting idea, Eric! As a start to whoever wants to attempt
Harley
> Eric M. Jones
> 113 Brentwood Drive
> (508) 764-2072
millner(at)me.com Guest
Posted: Wed Sep 26, 2012 12:05 pm Post subject: Pitot tube slightly plugged... |
>> I'm please to hear that you were able to salvage an otherwise
Let me warn that there appears to be an error in the repair
description. The OP wrote battery acid, HCl. But of course, battery
acid is H2SO4.
I can believe a weak (3 molar?) solution of HCl, as is often used as
swimming pool acid or brick cleaning acid might dislodge organic
material from a pitot tube without dissolving the pitot tube itself. I
would be very surprised (would not likely believe) that battery acid,
full strength, undiluted sulfuric acid was able to do anything but
significantly dissolve a pitot tube...
Hopefully the OP can clarify what he meant, since his acid description
was internally inconsistent.
Paul
Posted: Wed Sep 26, 2012 12:46 pm Post subject: Pitot tube slightly plugged... |
Thanks, Paul. I stand corrected. The acid used was obtained directly from a
surplus supply left over from filling a new dry lead-acid car battery. The
container had been capped, but was at least one year old. I do not know the
strength of the solution. FWIW: The vinegar actually brightened the visible
copper more than the battery acid.
And thanks to all who contributed their improvised techniques to thwarting
insects from creating homes in small holes. Especially interesting was the
comment about using different colored tubing. With a bug-plugged
scupper-ring at the fuel fill port on a C337, the rain-water level will rise
above the lip of the fuel cap neck. Until the owner [me] realizes that he
has a plugged scupper vent line, the appearance of water in the fuel
tank/test is an interesting and humbling mystery. My fix in 2001 was to add
2 inches of clear Tygon tubing to each vent outlet. I figured that if the
bugs were there, I'd at least see them the next time. However, they never
returned. Now I know why. Thanks guys.
