lcfitt(at)sbcglobal.net Guest
Posted: Thu Sep 20, 2012 6:00 am Post subject: Back in the Air |
I've been flying my new Model IV for the past couple of weeks and thought it
timely to post some thoughts.
It seems to fly pretty much exactly like the old one. After about four
hours tweaking the engine and pitching the prop, the Hobbs now shows just
shy of 14 hours. Tests show that the ASI reads about 9% low so that will
give give bragging rights with stall speed, but cruise will need an
explanation. I get not quite 1200 ft. per minute on intitial climb. Temps
are all in the green and my home brew rudder trim system seems to take out
the need for right rudder in cruise. I still don't know for sure if I have
a heavy left wing - it likes to make a very slow bank to the left, but
really slow. I will probably put a half turn on the right wing aft lift
strut rod end and see. the first flight was heavy stress on me as I had
made a few mods - home brew engine mount with the engine a couple of inches
forward to provide some room for a lower mounted oil tank. Aluminum Leading
edges on the wings vs. the upper false ribs, the rib warping rudder trim and
a few other mostly cosmetic things. The empty weight came in at 667 lbs.
Unfortunately, I have an hour commute both ways to the flight test area, the
best part of that, though, is that Lincoln Regional is a hotbed of
experimental activity. I have met some great guys - mostl rag and tube, but
up to a Thunder Mustang - and was offered a hangar on a monthly basis, so
the pressure to get back home is gone.
The flight test area is flat as flat farm area in the Central Valley and
gorgeous and the winds tend to be very light to non existent this time of
year.
Lowell
222.91 KB |
21453 Time(s) |
Guy Buchanan
Posted: Thu Sep 20, 2012 6:16 am Post subject: Back in the Air |
Beautiful Lowell. Can't wait to get back up to your place to see it. I
see you did a standard radiator install, do you have any pictures of
your oil cooler install? Is it below the prop spinner as before? Did you
do the vanes on the radiators? How about thermostats on the oil and/or
water. Your tailwheel looks different too. Did you custom the spring?
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded
Now a glider pilot, too.
Deceased K-IV 1200
A glider pilot too. |
propellerdesign(at)tele2. Guest
Lynn Matteson
Posted: Thu Sep 20, 2012 8:20 am Post subject: Back in the Air |
Good show, Lowell....
Remember to look for "missing parts" on the oil bottle when tending
to that task. : )
Lynn Matteson
Jabiru 2200, #2062
Prince prop 64 x 30, P-tip
Rotec TBI-40 injection (sleeved to 36mm)
Status: flying with 1360 hrs... (since 3-27-2006)
On Sep 19, 2012, at 6:46 PM, Lowell Fitt wrote:
| Quote: | I've been flying my new Model IV for the past couple of weeks and
thought it timely to post some thoughts.
four hours tweaking the engine and pitching the prop, the Hobbs now
shows just shy of 14 hours. Tests show that the ASI reads about 9%
low so that will give give bragging rights with stall speed, but
cruise will need an explanation. I get not quite 1200 ft. per
minute on intitial climb. Temps are all in the green and my home
brew rudder trim system seems to take out the need for right rudder
in cruise. I still don't know for sure if I have a heavy left wing
- it likes to make a very slow bank to the left, but really slow.
I will probably put a half turn on the right wing aft lift strut
of inches forward to provide some room for a lower mounted oil
tank. Aluminum Leading edges on the wings vs. the upper false
ribs, the rib warping rudder trim and a few other mostly cosmetic
area, the best part of that, though, is that Lincoln Regional is a
hotbed of experimental activity. I have met some great guys -
mostl rag and tube, but up to a Thunder Mustang - and was offered a
hangar on a monthly basis, so the pressure to get back home is gone.
Valley and gorgeous and the winds tend to be very light to non
existent this time of year.
Lowell
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Guy Buchanan
Posted: Thu Sep 20, 2012 10:46 am Post subject: Back in the Air |
On 9/20/2012 9:20 AM, Lynn Matteson wrote: | Quote: | Good show, Lowell....
Remember to look for "missing parts" on the oil bottle when tending to that task. : ) |
You're so mean. . .
Guy Buchanan Normal Guy Buchanan 2 21 2011-09-20T05:05:00Z 2011-09-20T05:05:00Z 1 31 183 1 1 213 14.00 <![endif]--> 59 false false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]--> <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} <![endif]--> <![endif]--> <![endif]-->Guy Buchanan
Ramona, CA
Deceased K-IV 1200
Lynn Matteson
Posted: Thu Sep 20, 2012 1:10 pm Post subject: Back in the Air |
And here I thought I was being really subtle. : ) (We'll let the
uninformed puzzle over what this is all about, eh?)
Lynn Matteson
Jabiru 2200, #2062
Status: flying with 1361 hrs... (since 3-27-2006)
You're so mean. . .
Guy Buchanan
Ramona, CA
contribution_-
N369LM |
markdonahue(at)earthlink. Guest
Posted: Thu Sep 20, 2012 4:28 pm Post subject: Back in the Air |
Way to go Lowell! She looks great.
I cant remember, did you put the 80 hp 912 on or the 100?
Look forward to flying with you.
Mark Donahue
Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Thu Sep 20, 2012 4:59 pm Post subject: Back in the Air |
Congrats Lowell!
On Thu, Sep 20, 2012 at 7:25 PM, mark donahue <markdonahue(at)earthlink.net (markdonahue(at)earthlink.net)> wrote:
[quote]--> Kitfox-List message posted by: "mark donahue" <markdonahue(at)earthlink.net (markdonahue(at)earthlink.net)>
Mark Donahue
_________________ Tommy Walker
N25A - Anniston, AL |
aero(at)rwaltman.com Guest
Posted: Thu Sep 20, 2012 6:41 pm Post subject: Back in the Air |
Lowell,
The plane looks beautiful, congratulations!
Care to share details on the rudder trim?
Roberto.
Pat Reilly
Posted: Thu Sep 20, 2012 7:15 pm Post subject: Back in the Air |
Lowell, Glad to hear your airborne again. It's also good to see all the replies. I thought Team Kitfox, or whatever that other site is, took all the Kitfoxers. I haven't seen much activiy on Matronix. I like the Matronix format 10 times better. The few times I went to the Team Kitfox site I had to memorize pin #'s and go to this file or that file. KISS is the principle when it comes to websites as far as I'm concerned. Matronix is as simple as it gets. The more #'s I have to remember and damn buttons I have to push is inversely propotional to how much I use a site.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Thu, Sep 20, 2012 at 9:39 PM, Roberto Waltman <aero(at)rwaltman.com (aero(at)rwaltman.com)> wrote:
| Quote: | --> Kitfox-List message posted by: Roberto Waltman <aero(at)rwaltman.com (aero(at)rwaltman.com)>
Lowell,
Roberto.
target="_blank">http://www.matronics.com/Navigator?Kitfox-List
http://forums.matronics.com
le, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Posted: Thu Sep 20, 2012 9:34 pm Post subject: Back in the Air |
Thanks for all the replies. Today was a busy day. I got there early an put a couple of hours on the Hobbs. Then spent some time with the guys. One of them - the guy I sub hangar space from is working on some sort of Parasol. I need to check. But it seems his hangar doubles as a hangout. It makes me wonder how he gets anything done as there are always a couple of guys kibitzing. Then again his slow progress is what gives me his hangar as he is only taking a little space. After that I took the Kitfox to the avionics shop to get the transponder squared away. My area is between Beal AFB and SMF and I guess a transponder would be a good idea. This put me in the evening commute. Tomorrow is a no fly day as there is a TFR because the 747 mounted shuttle is planning a fly by over Sacramento and they don’t want tons of airplanes trying to get a better look.
Guy, - The radiator is standard. I had the speedster cowl like housing last time. I think eventually that will be done again. No shutters on the radiator - opted for a thermostat. It works great - contact Mark. The oil cooler is in the same place with shutters. The first picture is the mount style, but this is a V that I helped a guy finish. The shutters have half inch vanes instead of the one inch on the last one. The spring you saw on the picture was an attempt to put on a stinger type spring, but despite protecting the spring on the trailer ride to Lincoln, the stinger was damaged as we rolled the airplane onto and off of the trailer - lots of weight back there with the wings folded and the angle up the ramp so I put the two leaf back on.
Jan - No fire, but Lynn's suggestion relates to my oil tank swallowing an oil bottle cap and trying to pass the melted plastic through the engine. One thing related to that. It took a year for the FAA to finally determine what the issue was. During that time, there was the gnawing question of whether I destroyed my airplane because of a faulty gauge. This time, I teed an idiot light into the system, so I have redundancy there now. It seems to work fine so far - flashing red on master on, switching to steady green as pressure rises.
Lynn - It is on my checklist. This is the plan and I didn't make this up. Spread white towel on table. Put four bottles of oil on the towel. Take one cap off and put it on the towel in front of the bottle. Clip the security ring off and put it in front of the cap. Repeat three more times. Before closing anything up, count four times three. If all checks out, button up. One of the guys today said it is the second time he heard of this particular issue. And a guy that opens oil filters for a living said on a mag article that plastic is not uncommon in the oil filter.
Mark, it is a 80 hp. KISS.
Roberto - The rudder trim was something I had been thinking about for about five years before the crash. (emergency landing) With the opportunity, I though I would try it. It consists of the lower two ribs in the rudder being made of carbon fiber arrow blanks - one on each side. (I have the speedster type gap seal in the hinge area so the vertical is an airfoil) There is a cam between each controlled by a servo and by energizing the servo I can warp the ribs. With the rudder in cruise trim, there is an airfoil on the left side and the right side is virtually flat. Picture attached of the mechanism.
Patrick - I couldn't agree more. I am on the site, but with all the screen names or whatever they call them, I don’t sense the camaraderie that I feel here. The names that responded here all have meaning to me with real people behind them and I feel like I am among friends. I struggle a bit with the idea that a hobby like ours that really thrives in the social setting would have us essentially hiding behind a made up name. I guess I could understand it better if we were hiding from something. Then again, my error, as Lynn reminds me, might be a good reason to re-subscribe to this list with a made up name.
thanks again
Lowell
Sent: Thursday, September 20, 2012 8:15 PM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Subject: Re: Back in the Air
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
Lowell,
Roberto.
le, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
83.61 KB |
21428 Time(s) |
88.5 KB |
21428 Time(s) |
170.31 KB |
21428 Time(s) |
Pat Reilly
Posted: Thu Sep 20, 2012 11:47 pm Post subject: Back in the Air |
Lowell, You better not resubscribe with a ficticious name. There are about
5 guys on this list that are right next to God when it comes to Kitfoxes as
far as I'm concerned. I couldn't have rebuilt mine without their help. Your
one of them and Lynn is another one.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Fri, Sep 21, 2012 at 12:33 AM, Lowell Fitt <lcfitt(at)sbcglobal.net> wrote:
[quote] **
Lynn Matteson
Posted: Fri Sep 21, 2012 2:49 am Post subject: Back in the Air |
Besides all that, that site seems like a bunch of people who have
"jumped ship", or went for the newest gadget, as it were. I like the
Matronics venue because it gets mailed to my computer and I don't
have to go hunting for it....my visits there are infrequent at best.
Lynn Matteson
Jabiru 2200, #2062
On Sep 20, 2012, at 11:15 PM, Patrick Reilly wrote:
| Quote: | Lowell, Glad to hear your airborne again. It's also good to see all
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
<aero(at)rwaltman.com> wrote:
Lowell,
Roberto.
le, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
www.matronics.com/contribution _-
N369LM |
Guy Buchanan
Posted: Fri Sep 21, 2012 6:58 am Post subject: Back in the Air |
On 9/20/2012 10:33 PM, Lowell Fitt wrote: | Quote: | | I struggle a bit with the idea that a hobby like ours that really thrives in the social setting would have us essentially hiding behind a made up name. I guess I could understand it better if we were hiding from something. |
Nah. We'd just use our call-signs everywhere; like the fly boys do. Instead of Viper and Maverick, it would be "49aero" and "I love pizza". (Random sample.) Wouldn't you like to walk around the Desert Fox Fly-in being called "I love pizza"?
| Quote: | | Then again, my error, as Lynn reminds me, might be a good reason to re-subscribe to this list with a made up name. |
HAHAHAHA! Like we wouldn't know.
Guy Buchanan
Ramona, CA
Deceased K-IV 1200
Guy Buchanan
Posted: Fri Sep 21, 2012 7:05 am Post subject: Back in the Air |
On 9/20/2012 10:33 PM, Lowell Fitt wrote: | Quote: | | No shutters on the radiator - opted for a thermostat. It works great - contact Mark. |
Yeah. I'm trying that too. Got an interesting one from the web that's very clean. Installs in-line. (http://shop.watt-man.com/Thermo-Bob-1-Universal-Kit-with-One-Inch-Fittings-TB1.htm)
| Quote: | | The oil cooler is in the same place with shutters. The first picture is the mount style, but this is a V that I helped a guy finish. The shutters have half inch vanes instead of the one inch on the last one. |
Your mount is sexy. Glad I hadn't made mine yet. And I just bought a new tube bender. Do you still market the vanes? What's the time lag on a temperature change after you adjust them?
Guy Buchanan
Ramona, CA
Deceased K-IV 1200
Posted: Fri Sep 21, 2012 7:35 am Post subject: Back in the Air |
Lynn, I agree.
I started on the email list in about 1994. It was after seeing some print
outs from the list at one of the first factory fly-ins after starting my
first Model IV. I read every post - 532s, 582s, 912s Model Is - everything.
I learned a ton about Kitfoxes and the guy with the model I flying behind a
532, just might have the answer you were looking for. With all the
compartmentalizing there is a lot that gets missed. I was having the rough
running band between 3 and 4000 RPM and found the answer in the Matronix
archives after a long search on the other site. I just wish there was more
activity, but the other site is way down now as well.
Lowell
Sent: Friday, September 21, 2012 3:49 AM
Besides all that, that site seems like a bunch of people who have "jumped
ship", or went for the newest gadget, as it were. I like the Matronics
venue because it gets mailed to my computer and I don't have to go
Lynn Matteson
Jabiru 2200, #2062
> site.
> Pat Reilly
> Mod 3 582 Rebuilt
> Rockford, IL
> On Thu, Sep 20, 2012 at 9:39 PM, Roberto Waltman <aero(at)rwaltman.com>
> wrote:
> Lowell,
> Roberto.
> le, List Admin.
> ="_blank">http://www.matronics.com/contribution
> Pat Reilly
> Mod 3 582 Rebuild
> Rockford,IL
Posted: Fri Sep 21, 2012 7:57 am Post subject: Back in the Air |
Interesting you ask. I don't know and that bothers me a bit as I have been playing with them some, but have never watched through an entire cycle. The reason - I have an intermittent issue with the oil temp gauge. It is in the Quad gauge from Westach and occasionally it will peg at max reading. According to their trouble shooting guide pegging at max is due to the gauge ground being faulty. I did find a poor crimp and fixed that and it was fine until I started playing with the shutters in flight. I did find that I can get about a 50° differential reading open and closed - OAT ~ 95. But, and this is interesting, if I close them in flight I can watch the temp climb and then pow, it might peg at max. Then by opening the shutters, it will suddenly give the correct reading. I seem to have an issue that is only triggered at higher temps. I have decided that it is the sender and plan on installing a new one - probably later today or tomorrow. Not trying to be commercial, but we make an inline thermostat as well. We don't use the bleed line. It is similar to what is in a car. We do enlarge the bleed hole through the diaphragm in the thermostat. That is the one I use and it is a 180° thermostat and works very well.
Lowell
Sent: Friday, September 21, 2012 8:04 AM
Guy Buchanan
Ramona, CA
Guy Buchanan
Posted: Fri Sep 21, 2012 8:11 am Post subject: Back in the Air |
On 9/21/2012 8:56 AM, Lowell Fitt wrote: | Quote: | | Not trying to be commercial, but we make an inline thermostat as well. We don't use the bleed line. It is similar to what is in a car. We do enlarge the bleed hole through the diaphragm in the thermostat. That is the one I use and it is a 180° thermostat and works very well. |
Didn't know you guys made one. Oh well. Maybe we should allow and encourage "press releases" so everyone would know what was out there. Did see the oil louvers, though, so I'll contact you off-line about that.
Guy Buchanan
Ramona, CA
Deceased K-IV 1200
Posted: Fri Sep 21, 2012 9:07 am Post subject: Back in the Air |
Lowell Fitt wrote:
| Quote: | Building at home can be a lonely experience.
As is my "KF fixing up" in an airport one hour away, were it often seems
I am the only person around. (Not counting the planes taxiing by and
forcing me to stop working to move my plane around.)
Hey, at home at least you have the fridge and bathroom nearby!
Roberto.
sourdostan(at)aol.com Guest
Posted: Fri Sep 21, 2012 9:27 pm Post subject: Back in the Air |
Hi Lowell-
I'm pleased to hear of your recent success, and what a beauty it is!! I'm looking forward to seeing it in person one of these days. Please keep posting as your fly-off proceeds.
Secondarily, it's nice to see this list become active again. I was starting to fear it had dried up and flown away! I, too, enjoy it much better than the other list in that it is more personable and interactive. Let's keep it humming, guys and gals!
Hey, pretty good---I didn't even pick on Lynn!!!
Stan Specht
Kitfox Model IV Speedster 912 UL with over 1935 hours
Denver, Colorado
